The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
47 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 376 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 3 of 4 < 1 2 3 4 >
New Reply
Topic Options
#781495 - Sat Sep 17 2011 08:23 AM Re: Adjusting Valve Lash on 235 [Re: Duwem]
tclederman Online
Loc: Jarvisburg, NC
Sorry, Duwen, I missed your post with that block date code. I think you are correct with the 1958 interpretation (someone will correct us if we are wrong).
I248 = Sep 24 58
L248 = Dec 24 58
Nice photos of your truck that you linked-to on the other discussion board. Looks like you are very industrious. Pictures are nice to see - too bad none are allowed here.
It looks like you have a 54/55 235 valve cover (it has breathing slits in it).
Yes, the head date code is under the valve cover.
Top
#781523 - Sat Sep 17 2011 01:01 PM Re: Adjusting Valve Lash on 235 [Re: tclederman]
Duwem Offline
Loc: WI
Pulled the valve cover. Found these numbers on the head:
Seen with cover on:
3835913
GM 12
Once removing the cover found these:
CON 9 G14
Does this help any?
Wiggling the rocker arms there does not appear to be any lash right now.
Here are some pictures with the cover off:
http://i22.photobucket.com/albums/b309/duwem/DSC01951.jpg
http://i22.photobucket.com/albums/b309/duwem/DSC01950.jpg
Any tips for resealing the valve cover? It had a cork gasket with a ton of orange RTV on either side. Should I try to straighten out the parts where the 4 screws go as they are dished some?
Got a new cork gasket.
_________________________
1950 3100 Project-just getting started
Top
#782132 - Mon Sep 19 2011 08:23 PM Re: Adjusting Valve Lash on 235 [Re: Duwem]
Duwem Offline
Loc: WI
Anyone? Hoping to get this back together and running again.
Top
#782135 - Mon Sep 19 2011 08:32 PM Re: Adjusting Valve Lash on 235 [Re: Duwem]
tclederman Online
Loc: Jarvisburg, NC
Duwen,
I cannot figure out that code and it looks like you have posted it correctly (nice photos). Maybe someone will post an explanation/interpretation?
Top
#782162 - Mon Sep 19 2011 09:52 PM Re: Adjusting Valve Lash on 235 [Re: sm]
LONGBOX55 Offline
Loc: DANVILLE IL
Originally Posted By sm
what about this one Guys? I think it's a 58'ish 235. Not original to the truck, im sure.
FII03A - by the Distrib. (those are "i"'s not One's)
3769716 - casting code
thanks
stu
Stu, you'rs is a '58-'62 235 Passenger car with manual transmission engine, built at Flint on November 3rd. There should be a casting date near the sarter that will get you the year.
BTW, the "II" is supposed to be "11". I don't know whay they used I instead of 1, but I've seen it on several engines, including my own.
Bill Burmeister
Top
#782197 - Mon Sep 19 2011 11:32 PM Re: Adjusting Valve Lash on 235 [Re: LONGBOX55]
Duwem Offline
Loc: WI
I gota think looking at the rocker arms in the pictures someone can tell me if its hydraulic or solid lifters. One would think since there are adjusters it would be solid, but your saying even the hydraulics had adjusters?
Top
#782210 - Tue Sep 20 2011 12:09 AM Re: Adjusting Valve Lash on 235 [Re: Duwem]
Hotrod Lincoln Online
Loc: Dellrose, TN
The rocker arms on solid and hydraulic lifter engines are identical. The only way to be sure is to remove the side cover and look at the lifters themselves. Hydraulic lifters have a 2-piece construction with a small spring clip at the top which keeps the lifter parts from separating when the pushrod is removed. Solid lifters have 1-piece construction.
"It is better to be feared than loved, if one cannot be both"
Machiavelli
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#782230 - Tue Sep 20 2011 06:14 AM Re: Adjusting Valve Lash on 235 [Re: Hotrod Lincoln]
truckernix Offline
Loc: Bracebridge Ontario Canada
I don't know about the lifters but if you really have a hose going from the fuel pump to the carb, I would be replacing that now with a steel line.
1951 1 Ton Completed
Top
#782236 - Tue Sep 20 2011 07:43 AM Re: Adjusting Valve Lash on 235 [Re: truckernix]
tclederman Online
Loc: Jarvisburg, NC
Yes, it is a passenger car engine (from engine serial number).
Yes, it came from the factory with hydraulic lifters (all 56-62 235 car engines had hydraulic lifters).
Yes, it has a 1958 block date code (shown above).
Does anyone have an interpretation for the head date-casting code?
CON 9 G14 (it looks like Duwen got that code from the correct location - check his photos).
Duwen, Jerry's advice is the best advice to be be certain that your engine still has hydraulic lifters. Check a lifter. You'll most likely have to replace the side cover gasket.
Top
#782380 - Tue Sep 20 2011 08:31 PM Re: Adjusting Valve Lash on 235 [Re: tclederman]
Oilrag Offline
Loc: PA, USA
Tim,
Is G14 his head date code?
Head casting 3835913 was available in 54.
And as you pointed out his valve cover is a 54/55.
Duwem, Yes, straighten out the dished valve cover.
If you don't it will probably leak.
The "dish" comes from cranking the screws down too tight.
-Tom
1950 Chevy 3100 w/ 1956 235
Top
Moderator:  53moneypit, Woogeroo
