The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
15 registered ('54 3600, blu1964, 5 Window 9434, Brad Allen, Bill Marlow, chaz71), 460 Guests and 5 Spiders online.
Forum Stats
39,419 Registered Members
48 Forums
105,448 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
250supersix, 48 Chevrolet 1 Ton Panel, 59lover, Alan de la Garza, Mark Lewis, preacherman
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#769339 - Sun Aug 07 2011 11:28 AM Fan Shroud Install on 1957
57 vroom vroom Offline
Loc: SE Michigan
Hey Guys,
Need some help/ advice with what I thought was going to be a simple install of a plastic fan shroud from Brothers for my 1957 that has a 350 in it.
The first is with installing it. I pulled the upper hose, let it drain and realized there was no way this shroud would slip between the radiator and the fan [about 2" clearance], so I have pulled the fan and space. Still not enough room as the forward edge of the water pump is interfering [about 5" clearance].
Second, is even if I could slip the shroud down in, the fan is gonna sit way forward and I am wondering how to get the fan assembly back on.
Is there a different water pump I should be looking at?
Help..... ohwell
http://www.brotherstrucks.com/techarticl...%20INSTALLATION
Edited by 57 vroom vroom (Sun Aug 07 2011 11:29 AM)
_________________________
1957 Chevy 3100 350sbc/t350
http://s327.photobucket.com/albums/k455/57vroom/
Top
#769352 - Sun Aug 07 2011 12:25 PM Re: Fan Shroud Install on 1957 [Re: 57 vroom vroom]
Hotrod Lincoln Offline
Loc: Dellrose, TN
To work properly, a fan shroud should only cover half the depth of the blade. The fan hub should align with the back of the shroud, so the blade is running half in and half out of the shroud. Any other position will result in less airflow through the radiator than if the shroud was not installed. Either install a water pump with a shaft length to position the fan in the right place, or modify the shroud mount so the back end of the shroud is positioned correctly.
What would a bulldog cross-bred with a Shi Tzu be called?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#769367 - Sun Aug 07 2011 01:11 PM Re: Fan Shroud Install on 1957 [Re: Hotrod Lincoln]
squeeze Offline
Loc: Vancouver Island
was your truck an original V8? [leading 'V' on the vin] if so, the rad may be mounted in the rearward position, and the aftermarket shroud won't work - and if so you should be able to get the fan within a 1/2" of the rad with a spacer and not need a shroud - otherwise you might have to make your own shroud .... here's the plastic shroud [also next pic] I put on a '56 with a 350, positioned as HRL describes, it required a spacer on the fan shaft and was installed just by removing the fan first
Top
#769382 - Sun Aug 07 2011 01:49 PM Re: Fan Shroud Install on 1957 [Re: squeeze]
Loc: SE Michigan
Thanks for the quick responses...
The truck was not originally a V8, but is there a way of telling if the rad/ support is from a V8?
So maybe I need to look at a shorter water pump and/or remove the existing spacer that I have on the fan right now?
Top
#769390 - Sun Aug 07 2011 02:26 PM Re: Fan Shroud Install on 1957 [Re: 57 vroom vroom]
squeeze Offline
the rad supports don't vary, but for the V8 it was mounted further back - I can't quite tell, but from this pic it does look like the rad is mounted further back than the 6 cyl position, which is about an inch behind the latch support cross bar ... the '56 is stored here so I got a pic for ya, the V8 mount points have a triangular reinforcing piece on the outside of the inner fender and the latch cross bar is moved back to there .... not sure you could get a water pump that would fix things if your rad was moved, but some measuring should figure out what's possible
Top
#769391 - Sun Aug 07 2011 02:31 PM Re: Fan Shroud Install on 1957 [Re: squeeze]
squeeze Offline
remembered I had a pic of the original V8 arrangement added here
Top
#769791 - Mon Aug 08 2011 07:47 PM Re: Fan Shroud Install on 1957 [Re: squeeze]
RATRODKING Offline
Loc: South Florida
i have that same shroud on my 57. i split it at the bottom and then bolted it together once installed. i had to trim around the alternator. my fan also was too far in the shroud, didnt notice any difference in engine temp, but i wanted it to keep my fingers safe when tinkering while engine is running.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Top
#770396 - Wed Aug 10 2011 04:30 PM Re: Fan Shroud Install on 1957 [Re: RATRODKING]
Loc: SE Michigan
Hey guys,
Snapped a few picutres that I posted to photobucket of the radiator and the clearance to the latch support as well as the water pump. Looks like removing the spacer from behind the fan will help the situation.
Two quick questions:
1. What should the the fore/aft position of the fan blade to the rear edge of the shroud?
2. What should be the max clearance between the fan diameter and that of the shroud?
@RATRODD: Can I find a pic of how you cut and bolted your shroud? Anything you would do different second time around?
Top
#770412 - Wed Aug 10 2011 05:22 PM Re: Fan Shroud Install on 1957 [Re: 57 vroom vroom]
squeeze Offline
the rad is in the factory 6cyl location, and it looks to me like the shroud should clear the fan hub for installation .... and if there was a spacer that got the fan a lot closer to the rad, yes it needs to go, the fan blades should be centered on the edge of the shroud opening and the dia of the blades should be as close as possible to the size of the opening
Top
#771295 - Sat Aug 13 2011 04:29 PM Re: Fan Shroud Install on 1957 [Re: squeeze]
Loc: SE Michigan
Hey guys, any concern with going down to a 17" fan that will fit in the shroud [the opening is 18" and my existing fan is 19 1/2"]? And.... any idea what model car/ truck I need to say I have so they can 'look it up' at the parts store since they seem to not be able to cross reference anything....
And given that I will need a diff diameter than what I am using how to determine the 'best'? I have read the more blades the better, but what about how deep they are?
I am just a litte leary of going from this big fan to smaller one and defeating the supposed benefit of a shroud...
Edited by 57 vroom vroom (Sat Aug 13 2011 06:23 PM)
Top
Page 1 of 2 1 2 >
Moderator:  KCMongo
