The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
40 registered (aggie jon, 69Cuda, 55 SHAKER, 29tons, 3 invisible), 468 Guests and 4 Spiders online.
Forum Stats
39,264 Registered Members
48 Forums
104,747 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
58NAPCOGMC, boom construct, buddeal, Cal78, meanmim, RT1
Image Posting Policy
New Reply
Topic Options
#748083 - Wed May 18 2011 04:00 PM Accelerator pump problem Edelbrock 1405 1898
Barsteel Offline
Loc: Monroe, CT
Hello!
My '59 Apache has a 1970 350/300hp in it, a stock 4bbl intake manifold, and an Edelbrock 1405 1898 4bbl carb on it. When I got the truck, it was very hard to start and it stumbled when I accelerated. I found that the accelerator pump was not working...no shot of gas down the carb when you flicked the throttle. If I poured a shot of gas down the carb, the engine fired right up.
So...I replaced the accelerator pump plunger (along with the air horn gasket). The old plunger looked a bit cockeyed, so I figured that that was the problem.
Reinstalled the carb, same problem. Still no shot of gas down the carb.
I have no experience with Edelbrock carbs, so what else could be the problem? A schematic shows that there is a weight and spring in the accelerator pump circuit. Could this have gotten gummed up or ?
I'd appreciate any help on this one.
Thanks...
Chris
Top
#748174 - Wed May 18 2011 11:06 PM Re: Accelerator pump problem Edelbrock 1405 1898 [Re: Barsteel]
gotgasd Offline
Loc: Nanaimo Vancouver Island
There's a check ball in the discharge line from the pump well into the carb. They get gummed up and stuck in place.
There should be a threaded plug in the front of the float bowl that you unscrew for access. Sometimes need a small screwdriver to dislodge it.
Top
#748566 - Fri May 20 2011 01:54 PM Re: Accelerator pump problem Edelbrock 1405 1898 [Re: gotgasd]
Z71Chevy Offline
Loc: Ohio,USA
Barsteel,have you checked your timing?I just put a 600cfm Edelbrock on my truck,it hesitated when I kicked it in to passing gear. I turned the distributor counter clockwise,just a little,and took it for a spin,cured my problem. We were going to check the timing,but just that little adjustment with the distributor cured the problem. Good Luck,and have a great weekend.
Top
#748639 - Fri May 20 2011 08:45 PM Re: Accelerator pump problem Edelbrock 1405 1898 [Re: Z71Chevy]
Barsteel Offline
Loc: Monroe, CT
Z -
Not yet, a full tuneup is the next project.
Pulled the air horn, then removed the small cap that holds the discharge jets for the accelerator pump, pulled out the weight and check ball. Then blasted the carb body out with carb clean then compressed air. Shot a wad of crap out of the accelerator pump passage whilst doing so. Reassembled and installed. Problem solved...nice strong jet of fuel, no stumble or bucking during acceleration.
Thanks for the help.
Chris
Top
Moderator:  53moneypit, Woogeroo
