The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
40 registered (3B, agedhorse, Bills Auto Works, carbking, 42465967, 1 invisible), 527 Guests and 5 Spiders online.
Forum Stats
39,635 Registered Members
48 Forums
105,677 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
/NC\ TechY, brujones1, Daniel_Clark, doddi, Fla54Chevy3100, GeneWiseman, TylerLarson55
Image Posting Policy
New Reply
Topic Options
#745800 - Sun May 08 2011 09:28 PM Source for Delco Remy part/serial# reference
51sub Offline
Loc: Plymouth, MN
I have a few 6 volt starters, generaors and regulators that I am trying to identify what they are for and the specs of each. I looked in the old car project Chevy master parts guide and was only able to identify one generator, any other sources for referencing these items?
_________________________
Mike
Top
#746599 - Wed May 11 2011 09:45 PM Re: Source for Delco Remy part/serial# reference [Re: 51sub]
Kennethw Offline
Loc: Ellis County Texas
let me know some numbers and I can tell you whatever you need to know about them.
Ken
Top
#746639 - Thu May 12 2011 12:11 AM Re: Source for Delco Remy part/serial# reference [Re: Kennethw]
51sub Offline
Loc: Plymouth, MN
Thanks for the help!
Generators:
#1100028 4g22 - appears to be for a 54-55 comm vehicle and 40 amp, what do you think?
#1102793 4J15
#1102788 2F
Starters:
#1107061 4123
#1107108 3C27
regulators:
#1118 827E 6VN 5L appears to be for a 52-55 truck and corvette? 45 amp
#828 6V-P 5D
Mike
Top
#746688 - Thu May 12 2011 08:24 AM Re: Source for Delco Remy part/serial# reference [Re: 51sub]
rgie Offline
Loc: abilene, tx
kennethw
how aboout the application of a delco distributor model 1112393?
i can't find out which engine it was used on
thanks
rolf
53 3600
63 c10
66 c10
Top
#747787 - Tue May 17 2011 01:50 PM Re: Source for Delco Remy part/serial# reference [Re: rgie]
Kennethw Offline
Mike, sorry I have been tied up and just now getting back on here. I will do some number searching and post back soon.
Ken
Top
#748290 - Thu May 19 2011 12:41 PM Re: Source for Delco Remy part/serial# reference [Re: Kennethw]
Kennethw Offline
Ok. here is the scoop on the numbers you ask about.
1100028 was a 6 volt 45 amp. short case Delco gen. Used in 53 and 54 on all 216s and 235s. Standard generator on all Chevrolet passenger cars and 1/2, 3/4 and 1 ton trucks. Also used on Corvette but took a different pulley supplied specifically by Chevy and not Delco, for Corvette. Also, Delco #1100018 was also used in 53 and was basically the same generator as the 028 unit.
1102793 was used on 53-54 Taxi, 1 1/2 ton trucks and 2 ton.
1102788 52-53 Larger GMC Trucks, many different models.
These units may be able to interchange with other applications by changing pulley etc. I would have to pull up the complete parts breakdown on both and see what they are actually made of. This takes lots of time and currently I am short on that..sorry.
1107061 starter was basically the same starter that was used on Chevy trucks from around 1942-1953 before the case and end plate changed up.
1107108 pretty much the same starter as 1107061
1118827 voltage reg. was used in 54 on chevy cars and trucks. Could NOT have been used from 52-55 due to the voltage change from 6-12 volt.
1118725 was used in 53 on cars and trucks.
1118828 was used on 1955 GMC with 1102793 Generator and on GMC models 100, 150, and 250 as well as many other GMC applications.
1112393 Distributor, I dont have a clue. I just looked in the Chevy section of the Original Delco Master catalog for the late 40s through mid 50s and its not listed under Chevy in those years. Could be Pontiac, Olds, Caddy etc. for certain years. Would take lots of time to look and if I get a chance I will look some more.
This information is how Delco Remy list it out by specific year models etc. Hope it helps.
Ken
Top
Moderator:  Rusty Rod
