The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (jacksont, Super55, 1 invisible), 433 Guests and 5 Spiders online.
Forum Stats
39,267 Registered Members
48 Forums
104,774 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
1 Dollar, aerotruk63, GTA Scott, mb53, Norman Meloche, pauldumont, rscott, steven simpson, thor
Image Posting Policy
New Reply
Topic Options
#742924 - Wed Apr 27 2011 12:43 PM Heater core pressure testing
magfarm51 Offline
Loc: Kuna, Idaho
I know heater cores have been a frequent topic but I couldn't find much on doing your own pressure test. I saw Denny's setup but I'm not a machinist and was wondering if anyone else successfully pressure tested their own heater core.
_________________________
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Here's the most recent one
Synthetic Lubricants
Top
#742935 - Wed Apr 27 2011 01:06 PM Re: Heater core pressure testing [Re: magfarm51]
Hookalatch Offline
Loc: Cottonwood, CA
The local radiator shop only charged me $8.00 to test mine.
Not something I expect to do again so I went that route.
Chuck
Chuck
1952 Chevy 3100 1/2-Ton
More pictures on Photobucket
Top
#742946 - Wed Apr 27 2011 01:50 PM Re: Heater core pressure testing [Re: Hookalatch]
51 ashton Offline
Loc: kempton,pa
yeah, i did with mine in the 40. i hooked up a rubber hose to one connection with a pipe nipple with a tee in the end of the hose i put a 0-15lb gage on a port of the tee and a ball valve on the other port. i took my garden hose and made it to fit the other connection on the core open the ball valve and slowly supply water to the core at 5 psi and when all the air stops coming out close the ball vavle and slowly pressurized the core to 5psi and turn off water supply. if its still holding pressure 15 minutes later and the core is still dry then it doesnt leak. if its sitting in the sun while your doing this the presuure will rise
Top
#742948 - Wed Apr 27 2011 02:05 PM Re: Heater core pressure testing [Re: 51 ashton]
Denny Graham Offline
Loc: Sandwich, IL
All I can add is don't go over about 7-8 psi or you will warp or pop the cooling tubes. 5 psi would be ideal pressure for a test. Using air pressure and a dip tank will pin point any leaks better than water pressure.
DG
Edited by Denny Graham (Wed Apr 27 2011 02:06 PM)
Top
#743637 - Sat Apr 30 2011 01:34 AM Re: Heater core pressure testing [Re: Denny Graham]
magfarm51 Offline
Loc: Kuna, Idaho
I found an older radiator shop with a young man running it and he charged me $10 to pressure test it, using air pressure and a tank just as Denny suggested. No leaks! dance
Allan
1951 GMC 1/2-ton
Top
#743649 - Sat Apr 30 2011 06:25 AM Re: Heater core pressure testing [Re: magfarm51]
Loc: Sandwich, IL
Ten bucks well spent Allan. I had a friend that ran a radiator shop in town here for forty years. He's the one that told me about over pressurizing the heater cores. The old cores tubes were extreamly thin and even a few pounds over can damage them.
DG
Top
#745420 - Sat May 07 2011 08:20 AM Re: Heater core pressure testing [Re: Denny Graham]
twotone Offline
Loc: Iowa
I saw a nice Air Flow on Ebay I wanted to bid on but the guy said he pressure tested the core to 40 psi and it was good big_eek I either avoided a scam or missed out on one impossibly strong core. Yeah, right wink
'53 GMC 1/2 ton
Top
#745993 - Mon May 09 2011 06:37 PM Re: Heater core pressure testing [Re: twotone]
40casey Offline
Loc: NC
twotone, I think I saw that same heater on Ebay and when I saw that "40 psi", I said well, that's junk now!!! It didn't even occur to me that that might be a scam!! RED FLAG! We all need to be careful.....
A day without sunshine is like, well, ..... dark!
1940 Chevy 1/2 ton pickup "KC"
http://s1237.photobucket.com/albums/ff466/40casey/
Top
#746680 - Thu May 12 2011 08:02 AM Re: Heater core pressure testing [Re: 40casey]
mapleleaf Offline
Loc: NS
I just got one done here locally ..it was not cheap..but it did pass.
For that price I would do it myself next time and rig up some low pressure air system.
Top
Moderator:  Rusty46
