The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
8 registered (78buckshot, dunfire, 5 Window 9434, coilover, Jimmie D, Justhorsenround), 450 Guests and 4 Spiders online.
Forum Stats
39,646 Registered Members
48 Forums
105,730 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
big 51, chevypanel52, ray1958, RickA
Image Posting Policy
New Reply
Topic Options
#742457 - Mon Apr 25 2011 05:43 PM 250 mods... what makes the biggest difference
Conductacator Offline
Loc: Florida
I'm rebuilding a 250 from the ground up. What modifications make the biggest difference for gaining power? The engine will be going in a truck which will occasionally pull a trailer but mainly be a daily driver. Should I use I use a 4bbl carb or two singles? what cam? any other helpful hints to get the best all-around performance out of the old girl.
_________________________
1950 Chevy 3600
More pix on Photobucket
"How can you say I'm not normal? ...I go out of may way Every day to do things that appear normal!!!!"
Top
#742626 - Tue Apr 26 2011 10:51 AM Re: 250 mods... what makes the biggest difference [Re: Conductacator]
Joe H Offline
Loc: Lee's Summit Mo. 64086
The cheapest and easiest is to add 307 Chevy flat top pistons to raise the compression up around 9 to 1. They bolt right in with out any modifications. Add a 292 exhaust manifold, 3 bolt outlet are 2 1/2" diameter pipe. A small 450 cfm four barrel may help and a little head work, add bigger valves if doing a valve job, not worth it if head is OK.
Joe
1937 Chevrolet Inline-powered Streetrod
Top
#742761 - Tue Apr 26 2011 08:13 PM Re: 250 mods... what makes the biggest difference [Re: Joe H]
Loc: Florida
bad news... got the the engine completely torn down today... its already been born .40 over. Its a piece of junk. back to the drawing board.
1950 Chevy 3600
Top
#742836 - Wed Apr 27 2011 12:58 AM Re: 250 mods... what makes the biggest difference [Re: Conductacator]
panic Offline
Loc: Long Island
They bolt right in?
You mean, after taking the engine apart down to the bare crankshaft? Not my idea of "bolt in".
Top
#742887 - Wed Apr 27 2011 10:39 AM Re: 250 mods... what makes the biggest difference [Re: Conductacator]
Hotrod Lincoln Offline
Loc: Dellrose, TN
How much taper wear do the cylinders have? If there's less than .005" of taper, a re-ring job at .040" oversize won't be a problem. I've built a few 250's to .060" oversize, but they were short-life race engines so a long-lasting rebuild was not a concern. The 307 pistons have all the same dimensions as the 250, including weight, so they're a direct swap. They just have flat tops instead of dished, which raises the compression. I've also done a .050" head mill job on a few engines along with the 307 pistons without getting into piston/valve interference problems with a stock-lift cam, and the engines still ran regular gas without detonation problems. The 292 exhaust manifold is a good suggestion, but they're a little hard to find. If you decide to find another block, the 230 can be used to build up a 250, with just a crankshaft change. The bore size is the same.
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#742888 - Wed Apr 27 2011 10:42 AM Re: 250 mods... what makes the biggest difference [Re: panic]
Joe H Offline
What I mean is, they fit with out any modification to the rod or piston, they are a direct replacement for the stock piston only they have provide more compression.
Joe
Top
#743529 - Fri Apr 29 2011 05:01 PM Re: 250 mods... what makes the biggest difference [Re: Joe H]
Loc: Florida
Water in the cyls and pretty bad scoring. I just junked it and cut my losses. But if any one has a 230/250/292 for sale near by let me know.
1950 Chevy 3600
Top
#743684 - Sat Apr 30 2011 10:11 AM Re: 250 mods... what makes the biggest difference [Re: Conductacator]
Joe H Offline
Since you are on the hunt again, go for a 292. It will make more power and torque right off the bat.
Joe
Top
#743709 - Sat Apr 30 2011 01:40 PM Re: 250 mods... what makes the biggest difference [Re: Conductacator]
Loc: Dellrose, TN
Not nearby, but I've got a rebuildable 250 long block, serial # FO421CAB in south central Tennessee. Standard bore, no rust, with what appears to be a good cylinder head. IM me if you're interested. I love to horsetrade- - - -what ya got?
Top
Moderator:  53moneypit, Woogeroo
