The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
50 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 372 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
New Reply
Topic Options
#736193 - Mon Apr 04 2011 03:14 PM 1963 c10 engine swap to 350
deluxe13 Offline
Loc: Auburn, CA. U.S.A.
I'm pullin the six out to put in a 350 married up to a saginaw 4 speed. what motor mounts do I use? What manufacturer? Anyone have pics?
Top
#736346 - Mon Apr 04 2011 11:20 PM Re: 1963 c10 engine swap to 350 [Re: deluxe13]
Torker Offline
Loc: Kansas
Sorry I don't have pics tonight. I have a 60 Chev lwb and mine has a 350 and a muncie 4-speed. My front engine mount is actually a horseshoe shape that bolts to the front of the block with 4 bolts and then one bolt at the bottom. On the rear it has mounts on the side of the bellhousing. There is no side motormounts like on a latermodel.
_________________________
1960 Chevy Long Wheel Base
When I die, I plan to slide in sideways yelling "Woohoo what a ride!"
Top
#736478 - Tue Apr 05 2011 12:01 PM Re: 1963 c10 engine swap to 350 [Re: Torker]
RJ Offline
Loc: S.E. Colorado
if you are pulling out a 230-250 6-cly motor you can use your old frame mounts, and use the rubber mount that are bolted to them, just take the mount apart and bolt the rubber mount to your block, if it is a 292 6-cly you will need the passenger side frame mount. Very easy install. email me if you still need pictures.
rjsisneros@ria.net
Top
#736582 - Tue Apr 05 2011 07:02 PM Re: 1963 c10 engine swap to 350 [Re: RJ]
Miner54 Offline
Loc: Farmington, Utah
You should also consider the cooling system. If you are replacing a 292 then you can use your old radiator. It is the same size as V8 equipped trucks. You will also need a fan shroud or aftermarket electric fan(s) due to the fact the V8 sits farther back than a 6. The 230-250 equipped trucks used a smaller radiator and may not provide sufficient cooling.
1963 Chevy C-20
More pix on Photobucket
Top
#737827 - Sun Apr 10 2011 05:51 AM Re: 1963 c10 engine swap to 350 [Re: Miner54]
deluxe13 Offline
Thanks RJ, mounts are in the mail...that was going to be my next question Miner...I do have the 230..guess I'll have to get a new radiator..aargh!!$$! What would be the best setup?
Top
#737956 - Sun Apr 10 2011 03:41 PM Re: 1963 c10 engine swap to 350 [Re: deluxe13]
Miner54 Offline
If you are planning on air conditioning then get a heavy duty 4 core or "Desert Cooler" If not then a standard 292/V8 radiator should work well. Brothers truck parts has a good selection or you could look for a used one. Of course with a new one , you know what you're getting.
1963 Chevy C-20
Top
Moderator:  Hambone, sixtyfive c-10
