The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
49 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 381 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 1 of 3 1 2 3 >
New Reply
Topic Options
#722455 - Sat Feb 19 2011 12:07 PM Radial tire size -> 6.50-16 ???
54Belair Offline
Loc: La Verkin, Utah
I bet this question has probably come up before, but; what is the modern radial size equivalent to the old 6.50-16 or 6.00-16 bias-ply tires?
I am trying to determine what size tire to put on the stock 16" wheels I recently received from a fellow stovebolter in Michigan
Many thanks in advance
Walt L. Williams
La Verkin, Ut.
Top
#722460 - Sat Feb 19 2011 12:21 PM Re: Radial tire size -> 6.50-16 ??? [Re: 54Belair]
tclederman Online
Loc: Jarvisburg, NC
I have LT215/85R16 Cooper tires on two sets of 1954 6.50x16 rims (4.5" rim section)
Top
#722470 - Sat Feb 19 2011 01:16 PM Re: Radial tire size -> 6.50-16 ??? [Re: tclederman]
46forme Offline
Loc: Laurens, SC
I'm running the same size on my 46 with 16" rims. Probably one of the best things I've done to my truck. Radials give you a much better ride.
George
Top
#722480 - Sat Feb 19 2011 01:54 PM Re: Radial tire size -> 6.50-16 ??? [Re: 46forme]
Tiny Offline
Loc: South Central Kansas
Size wise the closest is 185/75R16 but good luck finding them on this side of the pond.
_________________________
Sweetie Before
Sweetie Now
Sweetie In Skirts
Top
#722482 - Sat Feb 19 2011 01:59 PM Re: Radial tire size -> 6.50-16 ??? [Re: 54Belair]
coolchevy Offline
Loc: Parksville ,British Columbia C...
I'm also running LT 215-85 R16 with radial tubes on my 52 1300.Mine are made by Sigmae which I think are made somewhere in the southern USA.
1951 Chevy 1300 1/2-ton
Top
#722490 - Sat Feb 19 2011 02:21 PM Re: Radial tire size -> 6.50-16 ??? [Re: coolchevy]
cletis Online
Loc: Parker County Texas
I'm running 215/85LT16 Goodrich TA Commercial on my '54 burb, no tubes.
1954 GMC Suburban
My TRUCKS website
Top
#722709 - Sun Feb 20 2011 09:40 AM Re: Radial tire size -> 6.50-16 ??? [Re: cletis]
Huck Offline
Loc: Lake Toxaway, NC
I too have been looking for stock size radial tires for my 1952 GMC 1/2 ton, which is currently undergoing a body off restoration. When I purchased the truck, it came with old BF Goodrich Silvertown bias ply tires in the standard 6.00X16 tires on the front and 6.50X16 traction tread tires on the rear. I want to keep the original look but everything I have read here points to the superior driving characteristics and safety of the radials. My only concern with some of the radial tire sizes recommended by others here is that the tread width is much wider than the original tires, which increases the low speed steering effort.
I measured my original BF Goodrich bias ply 6.00X16 tires which are currently mounted on my 1950 Chevy 1/2 ton as I wanted to see how they look and drive. (When I purchased the Chevy, it had 215 75R15 and had very heavy steering effort when trying to park it, but drove with little effort at normal driving speeds. Now steering effort at low speed with the 6.00X16s is like driving with power steering compared to the 215/75R15s.)
The 6.00X16 tires measure a little over 27" in diameter mounted on the truck with a tread width of 4.63". I measured the diameter with the same tire off the truck and it was a little over 28". Compare this to the information on Coker Tires website where they give the following tire dimensions for their BF Goodrich bias ply 6.00X16: diameter - 28.3", section width - 6.25" and tread width of 4.63 " The 6.50X16 bias ply traction tires on the rear of my truck measure about 28.5" in diameter with a tread width of 5.88".
Diamond Back Tires has a radial tire that matches up closely with the original tire dimensions. Their information is as follows for their 195/754R16: height - 27.7", tread width - 5.4", section width - 7.6" and their 205/75R16 is slightly larger. Coker tires does not give a metric designation but instead gives the following dimensions for their Excelsior Stahl 6.00X16 radial: diameter - 28", cross section - 6.5", tread width - 4.6".
Tires from these two companies are not cheap at over $200 each plus shipping and local mounting. I still haven't figured out their controversy on whether or not you should use tubes with their radial tires. Diamond Back is states that you should not use them while Coker recommends them, adding even more to their cost. I haven't figured all this out myself, but hope this at least helps with your question as to what radial tire size matches up to the stock size tires.
Top
#722768 - Sun Feb 20 2011 12:39 PM Re: Radial tire size -> 6.50-16 ??? [Re: coolchevy]
Eninety2 Offline
Loc: FL
LT tires have a heavy ply rating. usually 8 to 10 ply. i think thats a little overkill, no? I work at a tire shop and they only ones that get those tires are HD trucks, 2500 and up.
Top
#722863 - Sun Feb 20 2011 06:11 PM Re: Radial tire size -> 6.50-16 ??? [Re: Eninety2]
WE b OLD Offline
Loc: marion, in. usa
I have had tubes in my Micheline X radial tires since aug. 1969, same tires. yes same tires. i replace a tube two years ago.
Ron, The Computer Greek
I love therefore I am.
1960 MGA Roadster
1954 3100 Chevy truck in the Gallery
2015 GMC terrain.
Pix on Photobucket
Top
#722865 - Sun Feb 20 2011 06:25 PM Re: Radial tire size -> 6.50-16 ??? [Re: Eninety2]
tclederman Online
Loc: Jarvisburg, NC
I'll pay for the overkill, when I can buy that tire for about @$120 delivered.
Top
Page 1 of 3 1 2 3 >
Moderator:  cletis
