The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
1 registered (TGP), 498 Guests and 4 Spiders online.
Forum Stats
39,639 Registered Members
48 Forums
105,691 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
AndyLewis, brianpwalker, erik the wrench, frank chaney, halvaboy, HAYWARDCHEVY510, herb19592000, lastchancetowing, samuel, Trmiles7
Image Posting Policy
New Reply
Topic Options
#720719 - Sun Feb 13 2011 01:01 PM 1954 Hydramatic ???
Stick 54 Offline
Loc: Florida
Got a chance to get a 1954 hydramatic with torque tube to install in my 54. I currently run the 3 on the tree. What would be the advantage? Pros and Cons?
Top
#720734 - Sun Feb 13 2011 01:43 PM Re: 1954 Hydramatic ??? [Re: Stick 54]
Hotrod Lincoln Offline
Loc: Dellrose, TN
You'll need to get the frame and the cab of the truck it came from. There were several major modifications involved, crossmembers, different floor pan hole in the cab, etc. You might be able to make it fit into your chassis, but not without some pretty extensive changes.
_________________________
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#720745 - Sun Feb 13 2011 02:29 PM Re: 1954 Hydramatic ??? [Re: Hotrod Lincoln]
Greg_H Offline
Loc: Enid Okla
I did that exact swap. I bought a rolling chassis with what I thought was most everything. The frame is different as mentioned in that it has bolt in, heavier crossmembers so that the trans can be removed from under the truck. The brake line routing is different for the same reason. I was told that the master cylinders were different but they appeared the same although I did not risk it and used the H-M master cylinder. Make sure you have all linkage, the sterring column is actually the same except for the shifter, the indicator will bolt on where the 3 speed shifter mounted. There is also a neutral start switcj mount that clamps on the column under the hood. Starter is different because it uses a solenoid start. Driveshaft length is different. There will be a pushbutton starter swith above the headlight switch. The transmission cover plate is different to allow access to the bellhousing bolts. Although there were different cabs for this cover, your 3 speed cab can be cut to fit and will be close but without the recess for the cover and actually, there are some strengthening ribs that are slightly different. H-M used a different carb with an electric choke but that is ot really an issue. There is an adapter plate that goes between the engine and transmission. GMC and Chev use completely different linkage and shifters so your donor vehicle needs to be correct manufacturer. The pivot on the side of the block is different and in the other locating point. All this being said, I really enjoy the truck more now that it is H-M and would not consider having it any other way now. Here are a few of my webshots pics that show the switch process. If you look around my webshots, you will also find a display pic of everything needed for the swap on a GMC. Enjoy! http://rides.webshots.com/album/399976892eMbHYm?start=0
Top
#720858 - Sun Feb 13 2011 09:01 PM Re: 1954 Hydramatic ??? [Re: Greg_H]
cletis Offline
Loc: Parker County Texas
Here are pictures of the differences in a '54 GMC. The Chevy will be similar.
My TRUCKS website
Top
#720938 - Mon Feb 14 2011 07:22 AM Re: 1954 Hydramatic ??? [Re: cletis]
Stick 54 Offline
Loc: Florida
ok this seems like way more than i wanted to get into. From my understanding the tranny is from a 54 chevy and i am going to put into a 54 chevy. I thought this may have been a direct switch with just the linkage, torque tube etc to change, but this seems like a lot more than i am willing to get into right now. It doesnt help that the drive train is in seattle and i am south fla. Shipping??? Thanks for all of the advise I'll keep the 3 on the tree.
Top
#720974 - Mon Feb 14 2011 09:55 AM Re: 1954 Hydramatic ??? [Re: Stick 54]
Loc: Dellrose, TN
There's an adapter kit available to swap a Turbo 350 or 700R4 into your truck, and bolt it up to the original stovebolt engine. It does require switching to an open driveline, however. I believe a center chunk from a later model pickup will bolt into your existing housing, but you'll need to set the pinion angle correctly and weld the pivots at the rear springs to make that conversion work.
Top
#721149 - Mon Feb 14 2011 09:29 PM Re: 1954 Hydramatic ??? [Re: Hotrod Lincoln]
Greg_H Offline
Loc: Enid Okla
The H-M is a great switch but if you think locating the transmission puts you in the home stretch of having it done, you will be disappointed with the amount of work you get yourself into. I got lucky and found a guy that was cutting up an original truck to make a street rod. I got almost all of what I needed one stop shopping.
Top
Moderator:  SWEET
