The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
10 registered (agedhorse, JWood, Eureka Jim, Aaron, 3 invisible), 504 Guests and 4 Spiders online.
Forum Stats
39,649 Registered Members
48 Forums
105,759 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
1968C50, BC52, Carl41, joerizz, mrpbarw, twarner
Image Posting Policy
Page 2 of 6 < 1 2 3 4 5 6 >
New Reply
Topic Options
#712996 - Tue Jan 18 2011 10:28 AM Re: 1940 dump truck trying to get bed off! [Re: Mikestem]
CORPO Offline
Loc: IL
I remember someone separating a very large tow truck bed on here using jacks and cribbing to get it high enough.. raised the bed just enough to separate it from the frame then rolled the truck out. Could be dangerous if not done carefully... but i would think its doable..
Top
#713074 - Tue Jan 18 2011 03:24 PM Re: 1940 dump truck trying to get bed off! [Re: CORPO]
Jungerfrosch Offline
Loc: Milford, VA
I would second the jack and cribbing. IF you stack everything up securely you can lift it very safely using this method. You can also work on the bed while it is raised and when you are done with the truck and the bed you can simply lower it back down. Just take it slow and plan ahead and you'll be fine.
Tad
_________________________
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
Top
#713089 - Tue Jan 18 2011 04:14 PM Re: 1940 dump truck trying to get bed off! [Re: Jungerfrosch]
53moneypit Offline
Loc: Smallville IN
The dump body is off the truck so if your only removing the hoist now you are OK with your engine hoist. The hoist only weights about 1000 lbs or so and if your engine hoist won't handle that it isn't mush of a shop crane. You'll know before you get the truck out from under it. Another option is to jack it up off the frame and put 4x4 lumber under it from and rear setting on top of barrels, then drive the truck out. I've changed 26' moving vans this way when I first started in the truck equipment business. Necessity is the mother of invention as they say. No money, few tools but lots of need, just be careful and think it thru first.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Top
#713162 - Tue Jan 18 2011 09:04 PM Re: 1940 dump truck trying to get bed off! [Re: 53moneypit]
brickman Offline
Loc: indiana USA
I am wanding if a grany crane would handle the weight of the dump bed. I wish I wish could figer out how to put pic on here so you guys could see the truck and the dump bed. To see if a grany crane would work.
1940 Chevy Dump Truck
More pix on Photobucket
Top
#713173 - Tue Jan 18 2011 09:32 PM Re: 1940 dump truck trying to get bed off! [Re: brickman]
CORPO Offline
Loc: IL
upload your pictures to a photobucket account and then give us the link to the picture.. simple..
Top
#713183 - Tue Jan 18 2011 10:22 PM Re: 1940 dump truck trying to get bed off! [Re: CORPO]
2-Ton Offline
Loc: Mokane ,Mo.
Different parts of the country have differnet names for things, So I have to ask, what is a grany crane? I assume you mean a gantry crane or a A frame hoist type of lifting device.
However you do it, take you time and think out your plan of action.
Pictures of the event would be a great insperation for the rest of us.
2-Ton
"The Flag Pole"
'46 2-Ton grain truck
'48 3/4-ton grain truck
'48 1-1/2-ton flatbed
'50 2-ton flatbed
'54 Pontiac Straight Eight
'54 Plymouth Belvedere
'76 TR-6
'82 Jeep CJ-8 Scrambler
'70 American LaFrance pumper fire truck.
Pix on Photobucket
Top
#713187 - Tue Jan 18 2011 10:30 PM Re: 1940 dump truck trying to get bed off! [Re: CORPO]
dmart Offline
Loc: massachusetts
Hire a local backhoe/loader to come pick it off and set it on the ground on blocks. Best bet is to have him turn it over so that you can work on the underside which is hard to get to later. If it is a Garwood or similar style then it will have the castings sticking out below the bed.
You will need a bunch of chains on hand for the lift and flip. Be very carefull !
Top
#713224 - Wed Jan 19 2011 06:14 AM Re: 1940 dump truck trying to get bed off! [Re: dmart]
kb3csw Offline
Loc: Pocomoke City, MD
When I took the body off the 38 I used the jacks 4x4 and 55 gal drum method. Make sure the ground is solid so barrels don't shift.
Top
#713260 - Wed Jan 19 2011 11:02 AM Re: 1940 dump truck trying to get bed off! [Re: Mikestem]
brickman Offline
Loc: indiana USA
I am getting ahold of a line truck to use to get the bed off. Just hope I can get the pins out easy. Thinking if I take the weight off the bed the pins should come out nice and easy
Top
#713329 - Wed Jan 19 2011 03:50 PM Re: 1940 dump truck trying to get bed off! [Re: brickman]
Loc: Milford, VA
You still may want to consider taking any weight off the pins you are planning on removing and either take them out ahead of time completely or at least getting them good and loose.
This way you won't have any chance of a pin not coming out while someone is sitting there waiting for you.
Good luck....and as asked for before...if you can get a chance we all love pictures smile
Top
Moderator:  69Cuda, Grigg
