The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
63 registered (49 3100, 1953 panel, 51cowboy, 2-Ton, 3B, 42465967, 2 invisible), 575 Guests and 4 Spiders online.
Forum Stats
39,395 Registered Members
48 Forums
105,329 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
48silverado, Anthony M, Big Tike, brown12202, CRexRun, Jim Meier, jkully, kruisin53, paul 49, shaxinator, Steven T, ultimatezlover
Image Posting Policy
New Reply
Topic Options
#709693 - Thu Jan 06 2011 11:56 PM Brake Conversion on a '69 C50
Locust_Cutter Offline
Loc: Kansas
Are there any readily available (under $2K) ways to convert a C50 from Flintstone brakes to either boosted or Bendix brakes? Air maybe? What about Heavy duty discs for the front-end? I have dealt with replacing boosters before, but I've never worked on a larger truck brake system and am unaware if there are any major differences between it and any smaller 60's Chevy truck. For what it's worth I've driven this particular truck about 10 time and am inheriting it in a few months from a good friend. I did a search on this but didn't see anything in a close year/model to mine. Thanks in advance to any who may answer me,
-Bryan
_________________________
Bryan
Equal opportunity truck employer
2x - Ford Superduties
'92 Toyota
'05 Silverado 1500
'69 C50 "Grumpy" 350/SM420 flatbed
Top
#709696 - Fri Jan 07 2011 12:46 AM Re: Brake Conversion on a '69 C50 [Re: Locust_Cutter]
crenwelge Offline
Loc: Fredericksburg, Texas
A 50 series should have a hydrovac. If it is working like it should, you will have good brakes
Top
#709708 - Fri Jan 07 2011 02:45 AM Re: Brake Conversion on a '69 C50 [Re: crenwelge]
Loc: Kansas
I'll have to look at it when I get back home (currently deployed courtesy of the USAF) and see if it has that or not. I know that it's a bare master cylinder bolted onto the fire wall, as I'm the one who installed it,...
Bryan
'92 Toyota
'05 Silverado 1500
Top
#709767 - Fri Jan 07 2011 10:41 AM Re: Brake Conversion on a '69 C50 [Re: Locust_Cutter]
3B Online
Loc: B. C. Canada
Hy Locust_Cutter, welcome, unfortunately the mid to late 60s were a time of change in braking systems for the larger trucks. Some were single systems with boosted masters mounted on the firewall, others were dual systems with two frame mounted hydrovacs, or single masters with a single hydrovac mounted on the frame. It can be very tricky trying to determine what is correct for a given brake system during this period. When you get back to the truck, have a good look at what equipment is on it, then you can tell us, and ask your questions with more information on what is on the truck now, hope that helps.
Top
#710002 - Sat Jan 08 2011 07:31 AM Re: Brake Conversion on a '69 C50 [Re: 3B]
Mearl Offline
Loc: So. Central Mo.
My dad bought a new 50 series truck in 67 for his log truck. He said until the day he died that it had the worst brakes of any truck he ever owned. When they moved the booster up to the firewall, he always thought that was when they got worse.
The older 64 -66 trucks had better brakes but with the 2 wheel cylinders per drum, they are a real pain to bleed.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
Top
#710176 - Sat Jan 08 2011 06:24 PM Re: Brake Conversion on a '69 C50 [Re: Mearl]
Loc: Kansas
I had heard of having 2 wheel cylinders per wheel, on some of the older ones. I could see that being a real pain to bleed, when it was time to service them. I'll take a hard look when I get back home, and try to call out what's there and see what my options are.
Thanks everyone!
Bryan
'92 Toyota
'05 Silverado 1500
Top
Moderator:  69Cuda, Grigg
