The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (TPR57C, tomctomc, Mickey3100, Organbuilder, greenie-reddy), 523 Guests and 4 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
New Reply
Topic Options
#676787 - Wed Sep 08 2010 08:15 PM Electric choke for old Quadrajet?
Roadmarks Offline
Loc: Raleigh NC USA
Does anyone have any experience with an electric choke kit for the old coil in manifold style Quadrajets? What kit did you use? How dependable is it? Information, etc?
Also, don't bother telling me to dump my Quadrajets and get a real carb! In my book, nothing runs like a Qjet on an SBC!
Thanks and best wishes,
Les
_________________________
1956 Chevy Panel
1969 Chevy C20 Panel Truck
1971 Chevy C-10
More pix on Photobucket
"The Urban Home for Wayward Trucks"
Top
#676854 - Wed Sep 08 2010 10:56 PM Re: Electric choke for old Quadrajet? [Re: Roadmarks]
webstershotrods Offline
Loc: Temple ,TX
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Top
#676947 - Fri Sep 10 2010 06:22 PM Re: Electric choke for old Quadrajet? [Re: webstershotrods]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
I put Q-jet's on everything of mine. I use the later model with the round choke on the side.If it doesn't have electric on it it is easy to change the coil to an elec. heated one. These carbs are a dime dozen at the swap meets.
1956 Chevy 1/2-Ton Pickup
Top
#677087 - Sat Sep 11 2010 10:27 AM Re: Electric choke for old Quadrajet? [Re: Wrenchbender Ret.]
Joe H Offline
Loc: Lee's Summit Mo. 64086
Not sure about the "in manifold type" but the round ones on the side of the late model type work great. Just power them up and go. Never had a problem yet with one. Most of the time you can swap the whole choke system over to the older type carbs.
Joe
1937 Chevrolet Inline-powered Streetrod
Top
#677324 - Sun Sep 12 2010 09:32 AM Re: Electric choke for old Quadrajet? [Re: Roadmarks]
Hotrod Lincoln Offline
Loc: Dellrose, TN
Why mess with something that works? The manifold-heated choke is fully mechanical. Just bolt in a new coil assembly and set the linkage right. The only function of the electricity is to heat the coil and make the choke release, so with the choke coil in the heat riser passage in the manifold there's no reason for electric heat. If you're going with an aftermarket manifold without the choke well, just switch to a Q-Jet with the round choke housing integral with the carb, and install an electric-heated choke cover. You'll have to grind off a locating tab on the cover to make it adjustable, and install an oil pressure switch to keep it from heating and releasing the choke with the engine cold if it stalls.
You're right about the Q Jet being the best-engineered street carb available. Holleys are for race cars!
"It is better to be feared than loved, if one cannot be both"
Machiavelli
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#677411 - Sun Sep 12 2010 02:52 PM Re: Electric choke for old Quadrajet? [Re: Hotrod Lincoln]
Roadmarks Offline
Loc: Raleigh NC USA
Guys,
Thanks for the replys! My problem is I have an original and fully rebuilt 704 series Qjet from a 1972 C10. It used a heated element that sat in the intake manifold and worked the choke butterflys via linkage. The electric choke that I'm talking about is an after market type that bolts to the carb and has a sensor that bolts to the intake.
This would all be simpler, but the ProComp dual plane intake that I have doesn't have a place for the original type choke coil.
If it ain't one thing, its another!
best wishes,
Les
1956 Chevy Panel
1971 Chevy C-10
Top
#677423 - Sun Sep 12 2010 03:32 PM Re: Electric choke for old Quadrajet? [Re: Roadmarks]
Loc: Lenexa Ks.
Thats why we use the round choke models. The intakes & carbs have been so scrambled up through the years that generally they dont match.
Top
#678589 - Sat Sep 18 2010 08:27 AM Re: Electric choke for old Quadrajet? [Re: Wrenchbender Ret.]
carbking Offline
Loc: Missouri
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
Top
Moderator:  KCMongo
