The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
60 registered (5 Window 9434, 49nut, 3B, 48bigtrucks, 1953 panel, 3 invisible), 690 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,692 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#675939 - Mon Sep 06 2010 12:21 PM 235 bellhousing
55 SHAKER Online
Loc: 80 miles west of Joliet IL.
I picked up a 55 car 235 engine. I need a bell housing and flywheel, to get this thing fired up on my garage floor. So what year car or truck parts will I need to look for, that will bolt up to this engine?
TIA. Brian
_________________________
Brian
My 1955 Truck
My other 1955 Chevy
Top
#675946 - Mon Sep 06 2010 12:45 PM Re: 235 bellhousing [Re: 55 SHAKER]
Yakimabowtie Offline
Loc: Yakima, Wa.
Depends on what you are going to put the engine in? The bell housing from any 216, 235, 261 and early V8 will fit.
Top
#675955 - Mon Sep 06 2010 01:16 PM Re: 235 bellhousing [Re: 55 SHAKER]
Hotrod Lincoln Offline
Loc: Dellrose, TN
The car and truck bellhousings will both bolt on, but I believe the car type won't have bolt holes for the stomp starter linkage. Be sure and match up the flywheel and starter, for either 6 volt or 12 volt- - - -the tooth spacing is different.
"It is better to be feared than loved, if one cannot be both"
Machiavelli
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#675957 - Mon Sep 06 2010 01:18 PM Re: 235 bellhousing [Re: Yakimabowtie]
Loc: Dellrose, TN
The early V8 bellhousing will fit the 194-292 6-cylinder engines, not the 216-261 types.
Machiavelli
Top
#675958 - Mon Sep 06 2010 01:23 PM Re: 235 bellhousing [Re: Yakimabowtie]
garyg Offline
Loc: pembroke,n.h.
you will need a 235 flywheel and matching starter,216, 235, 261 car or truck bellhousing,, but i don't think a v8 bellhousing will fit as was previously mentioned. good luck. garyg
our garage is a non-profit organization
Top
#675967 - Mon Sep 06 2010 02:10 PM Re: 235 bellhousing [Re: Hotrod Lincoln]
tclederman Offline
Loc: Jarvisburg, NC
It is not just an issue of the clutch housing being able to bolt to the engine/block. The donor clutch housing should match the style for the year of the recipient truck. (Yakimabowtie's question is pertinent.)
The 1953 and earlier truck 216/235 clutch housing has a different motor-mount angle (and different motor mounts) from the 1954 and later 235/261 truck's clutch housing.
Also, I think that some 261 clutch housings might have been set-up for a hydraulic clutch (and maybe the throw-out bearing fork on the opposite side)? I dimly recall that I could not use my 1960 big-truck 261's clutch housing in my 1954 1/2 ton truck.
Brian, did your 55 truck not come with a clutch housing??
Top
#676021 - Mon Sep 06 2010 05:30 PM Re: 235 bellhousing [Re: tclederman]
55 SHAKER Online
First off thank you all for your replies.
Yakimabowte----Not putting the engine in anything, I'm putting it on the garage floor.
Tim,---- Yes my 55 truck has everything, but I don't want to tear it apart.
All I want to do is fire this engine up and see if it's any good.(it'll be a spare engine).
All I need is a flywheel, starter, and bellhousing. I know that 55-59 235 car or truck will work. I just need to know what else will work, to help in my search. "I won't" be using these parts to bolt it in my truck.
Brian
Brian
My 1955 Truck
My other 1955 Chevy
Top
#676046 - Mon Sep 06 2010 07:04 PM Re: 235 bellhousing [Re: 55 SHAKER]
Loc: Dellrose, TN
Just about any 216-235-261 bellhousing, flywheel, and starter will work, from the mid-40's to early 60's, as long as you don't mix up years and get a mismatch between the starter and flywheel. I think the early 40's flywheel had a different number and/or spacing on the crankshaft bolts. If you're using the car bellhousing, the solenoid-type starter would be needed, since there's no provision for the stomp start on the car bellhousings after 1948 or so.
Machiavelli
Top
#676057 - Mon Sep 06 2010 08:14 PM Re: 235 bellhousing [Re: Hotrod Lincoln]
tclederman Offline
Loc: Jarvisburg, NC
Jerry,
How will a 216 clutch housing (bell housing) work in a 1955 truck?
The clutch housing has a different angle for the rear motor mounts. And, because the motor mounts are in a different location, the 47-53 rear motor mounts are a different design relative to the 54-84 rear motor mounts.
The shape of the rear motor-mount frame cross-member changed in 1954 (that is why no frame cross-member and transmission mount was needed after 1954 for manual transmissions).
Yes, of course a 6v or 12v clutch assembly should be used, depending on which is intended to be used in the 1955 truck
Top
#676060 - Mon Sep 06 2010 08:17 PM Re: 235 bellhousing [Re: tclederman]
LONGBOX55 Offline
Loc: DANVILLE IL
Tim, I think that Brian is only looking to set the engine up so that it can be run on a stand, not necessarily installed in a truck at this time. That being the case, what the bellhousing is won't really matter, as long as it bolts up to the engine itself.
Bill Burmeister
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
