The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
15 registered ('54 3600, blu1964, 5 Window 9434, Brad Allen, Bill Marlow, chaz71), 460 Guests and 5 Spiders online.
Forum Stats
39,419 Registered Members
48 Forums
105,448 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
250supersix, 48 Chevrolet 1 Ton Panel, 59lover, Alan de la Garza, Mark Lewis, preacherman
Image Posting Policy
New Reply
Topic Options
#674189 - Mon Aug 30 2010 03:23 PM 1951 Gauges use 6 volt with a 12 volt system
phantom1094 Offline
Apprentice
Loc: chicago, il
does anyone know if I can use my original speedometer and cluster guages with a 12 volt system? If so what do I need to do to make it work? I really want to keep my old guages
thanks
_________________________
1951 Chevy 1/2-Ton
Pictures on Photobucket
Top
#674196 - Mon Aug 30 2010 03:40 PM Re: 1951 Gauges use 6 volt with a 12 volt system [Re: phantom1094]
FriedGreenTmater Offline
Loc: colorado
You'll find that the gas gauge is the only one to worry about. The AMP gauge doesn't care if it is 6v or 12v, and will work exactly the same on either.
Temp is mechanical, oil is mechanical and the light bulb replacements can be had from the parts store or radio shack. I ran a voltage reducer (Runtz, probably did not need it), on my gas gauge until the gauge went bad. You need to make sure the sending unit in the tank has the same ohm range as your gauge. Not a problem if you are using the original tank and sending unit. I've been told that the gas gauge will work on 12V, but I have not tried it and makes it makes no difference to me now that it is broken.
Fried Green T'mater (Vern)
1953 Chevrolet 3600
More pix on Photobucket
Caution: Political Statement
Top
#674224 - Mon Aug 30 2010 05:42 PM Re: 1951 Gauges use 6 volt with a 12 volt system [Re: FriedGreenTmater]
phantom1094 Offline
Apprentice
Loc: chicago, il
Thanks T'mater, what about the speedometer? will that work?
1951 Chevy 1/2-Ton
Top
#674259 - Mon Aug 30 2010 08:36 PM Re: 1951 Gauges use 6 volt with a 12 volt system [Re: phantom1094]
Loc: colorado
Absolutely. That's a cable that runs to the transmission.
1953 Chevrolet 3600
Top
#674375 - Tue Aug 31 2010 08:40 AM Re: 1951 Gauges use 6 volt with a 12 volt system [Re: FriedGreenTmater]
Tiny Offline
Loc: South Central Kansas
My one experience with converting a 6v vehicle to 12v was a LONG time ago when I bought a 55.1 Chevy panel truck. I did the usual changing of the coil & bulbs but I never put a resistor on the gas gauge (never occurred to me that I needed to). In over 100000 miles I put on the truck after the conversion I never had an issue with the gas gauge not working right. It certainly won't hurt if you do put one on the truck and in actuality it's probably a good idea, but my experience is that the world won't end if you don't.
Sweetie Before
Sweetie Now
Sweetie In Skirts
Top
#682902 - Sun Oct 03 2010 03:56 PM Re: 1951 Gauges use 6 volt with a 12 volt system [Re: Tiny]
52Dave3600 Offline
Loc: Renton, WA
I'll give ya'll a little secret I figured out years ago. My first vehicle was a 53 Chev 3100 in 1990.
Here's how you make the gas gauge 100% accurate on 12 volt. Converting to 12V from 6V doesn't require a resistor. IF you don't believe me, remove the fuel sender after you install a resistor in the sender to gauge line. Move the tank sender up and down and it'll be innacurate.
SO, do this. Cut the sender line under the dash. Temporarily install a very small light bulb (like another instrument panel bulb). Operate the sender up and down. You may have to try a few different bulbs until you find one that is 100% accurate. This will work. You will actually notice the bulb will glow a little. It won't fully light up. It's the only thing I found to actually work. Solder the wires to the lightbulb in series with the sender wire when you find one that makes the gauge read E when down and F when up. Reinstall the sender in the tank.
One word of CAUTION. When the gauge reads E, you are not low on gas. YOU ARE OUT!! NO JOKE. Ask my sister. She had to help me push the truck into a gas station.
Top
Moderator:  Rusty Rod
