The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
50 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 372 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
New Reply
Topic Options
#671193 - Wed Aug 18 2010 12:01 AM Vapor Lock? - Chevy 350
REAL_RAT_FINK Offline
Loc: Rexburg, Idaho
I have a chevy 350 in my 58 Apache. After driving for 10 minutes, the engine randomly shuts off. I try and start it but can't. The starter cranks the motor freely and when the gas pedal is pressed, gas does indeed shoot into the intake.
I have fuel. I do not have combustion issues becuase it runs fine for the first 10 minutes. I have spark.
After waiting 25 minutes, the motor usually fires up. I live in a high altitude location in Idaho.
Conclusion: Vapor lock or possible carb issue? Need help on this one....
_________________________
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
Top
#671198 - Wed Aug 18 2010 12:34 AM Re: Vapor Lock? - Chevy 350 [Re: REAL_RAT_FINK]
FriedGreenTmater Offline
Loc: colorado
Vapor lock is caused by the gas boiling en-route to the carburetor creating a situation which starves the engine of fuel. If you are getting good gas when it's hot then you likely have a problem in the ignition. Points, Condenser, or coil.
Fried Green T'mater (Vern)
1953 Chevrolet 3600
More pix on Photobucket
Caution: Political Statement
Top
#671495 - Thu Aug 19 2010 02:43 AM Re: Vapor Lock? - Chevy 350 [Re: FriedGreenTmater]
Loc: Rexburg, Idaho
What do you mean "good gas"? The engine is getting gas, but there is some rust in the gas. My filter proves that, it clogs it all the time.
Could this be the culprit?
I just went through all the electrical recently including rotor,cap, curve kit, module,and plugs. BUT I haven't changed the coil. Could it be the coil?
---Casey---
Top
#671512 - Thu Aug 19 2010 06:30 AM Re: Vapor Lock? - Chevy 350 [Re: REAL_RAT_FINK]
Avette4me Offline
Loc: Tuttle, OK
That's where I'd place my bet.
Top
#671535 - Thu Aug 19 2010 09:22 AM Re: Vapor Lock? - Chevy 350 [Re: REAL_RAT_FINK]
Loc: colorado
Good gas is clean and with 5-7 lbs pressure.
Think of a snow-globe. if it is sitting on a shelf idle it appears to have clear clean liquid in it. shake it up and stuff floats all over the place.
Introduce all that floating matter into a running engine and I'm surprised you got out of the driveway. grin
1953 Chevrolet 3600
Top
#671866 - Fri Aug 20 2010 05:43 PM Re: Vapor Lock? - Chevy 350 [Re: FriedGreenTmater]
Loc: Rexburg, Idaho
I guess it could be the rust in the gas tank, but that sure seems odd.
The truck always start when the motor is cool. I run it for 10 minutes and the idle is fine, everything is fine. Then, it just randomly dies. If I check the carb at this point, it still shoots gas into the engine just fine. With gas in the motor, it should start up regardless of a little rust. I'm starting to think it must be the coil.
---Casey---
Top
#671872 - Fri Aug 20 2010 06:14 PM Re: Vapor Lock? - Chevy 350 [Re: REAL_RAT_FINK]
squeeze Offline
Loc: Vancouver Island
could be something like the coil, but considering you've seen the filter plug, might clean the carb inlet screen if it has one [should] and try popping the top of the carb to see how much sediment is in the bottom of the bowl - a "little rust" can cause "little spaces" to plug up when things vibrate for awhile, as in a few minutes of running with the attendant fuel flow agitation, the fact that the accelerator pump works doesn't mean jets aren't plugging up
Top
Moderator:  53moneypit, Woogeroo
