The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
49 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 380 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 2 of 6 < 1 2 3 4 5 6 >
New Reply
Topic Options
#658930 - Thu Jul 01 2010 04:07 PM Re: Headers and Dual carbs on a 6 cyl [Re: webstershotrods]
John53 Offline
Loc: ca
30 yrs ago I had a shoebox nova with a 250 6cyl, it ran good with a clifford cam and intake w/450 holly, and a header. Google Clifford Performance, they're in Corona Ca.
_________________________
1942 Chevy Firetruck project 1 1/2-Ton
More pix and video
1941 Chevy 1/2-Ton -- Now gone
More pix on Photobucket
Top
#658943 - Thu Jul 01 2010 05:23 PM Re: Headers and Dual carbs on a 6 cyl [Re: Greg_H]
ErikDaViking Offline
Loc: Arlington, WA
Hey there, Greg, thanks for posting that link. I'm putting the same setup on my 250, only with Langdons cast iron headers. Nice to see how you ran all the linkages and fuel lines, plus hearing it in teh videos was a great motivator to get 'er done. Hopefully th esetup I bought from Tom will work well together...
1966 Chevy C10 Stepside
Top
#659266 - Fri Jul 02 2010 04:12 PM Re: Headers and Dual carbs on a 6 cyl [Re: Hotrod Lincoln]
coolerthanethan Offline
Loc: Miami, FL
Originally Posted By Hotrod Lincoln
Lots of these setups are out there, but very few of them work as well as an original 1-carb system. Dual carbs are mostly eye candy, unless you're dealing with a highly-modified race-only engine. You'll encounter flat spots, backfires, and generally very twitchy low speed and midrange performance, to get a slight improvement in top-end horsepower. It will take a different camshaft, valve and head work, and probably a modified spark advance curve, plus a matched set of the correct size (small) carbs to make a dual-carb/header system work almost as well as a stock setup. Large dollars and LOTS of hassle!
eye candy is right on, and i couldn't agree more!!!! i tried running a offy 2x1 with rochesters, ran like crap, then went to newly refurbished and matched carter w1's ran like garbage. i put the original single rochester and stock intake with duals and it runs better than ever. the only other combo i wanted to try is the clifford intake and a brand new holley 390cfm. only to get away from old carbs which get rebuilt over and over and over.
a stock inline 6 needs exactly the fuel/air that the factory put on it. slapping on duals and more gas isn't going to do anything but give you more headaches. i speak from experience. if you can't live without the multicarb look, buy a 3x1 intake block off the outer carbs and only run the center.
Edited by coolerthanethan (Fri Jul 02 2010 04:17 PM)
Top
#659321 - Fri Jul 02 2010 07:43 PM Re: Headers and Dual carbs on a 6 cyl [Re: coolerthanethan]
bigbadswingdaddy Offline
Loc: san francisco
I have ran a clifford 4bbl intake with a 390 holly on a 270 gmc. It did quite well, and woke that 270 up a bit. I do believe the primaries are too big, and the secondaries are too small on that carb. There is no comparison between the 4bbl and the 5 stromberg 97s on my 302 gmc. I have had many vehicles with multi carbs. I have had straight linkages and progressive linkages. Let me say there is nothing like running a multicarb setup with a progressive linkage. When those secondaries open up, the engine howels and the smile can not be knocked off the face with a 2X4.
My advice run a 3X1 intake progressively. And remember ... "The person who says it can't be done should never interupt the person who is doing it!"
Top
#659337 - Fri Jul 02 2010 09:09 PM Re: Headers and Dual carbs on a 6 cyl [Re: bigbadswingdaddy]
Mr. Lang Offline
Loc: Brentwood Bay, BC Canada
I have the offy manifold, and fenton headers on my 216, daily driver. I've put on about 8,000 miles on the set up. I ran it for several thousand with Rochester b's, and then rest has been with Carter W-1s. I have aluminum pistons, and my 216 is over-bored. I was careful in setting them up, and syncing the carbs. I get slightly better mileage, and a little more power. Another 10,000 miles, and it will have paid for itself. It looks cool, sounds cool, and cost money. I probably wouldn't do it again though. But it is cool.
Christopher
Pictures in Photodork
1949 GMC Panel Truck
1926 Model TT Truck
Top
#659454 - Sat Jul 03 2010 10:01 AM Re: Headers and Dual carbs on a 6 cyl [Re: Mr. Lang]
panic Offline
Loc: Long Island
Top
#659463 - Sat Jul 03 2010 10:37 AM Re: Headers and Dual carbs on a 6 cyl [Re: panic]
JiMerit Boltr#43 Offline
Loc: olTruck(Turlock), CA
A major problem with this set up is finding a usable matched pair of carbs. I like the Stromberg BXOV-2s, hard to find and making 60 year old carbs new again is difficult. I've switched to Langdon's Holley-Webers which are progressive 2 barrels. Only issue with these was needing a bit bigger jets, now with that solved she runs super. These are on my 261 with a cam from Patrick's, Edelbrock manifold, Vette dual exhaust, milled head and powerglide intake valves. It can be frustrating setting the carbs, a buddy of mine that's done dozens of these made it all work.
1946 1/2-Ton Chevy
Top
#659600 - Sun Jul 04 2010 07:00 AM Re: Headers and Dual carbs on a 6 cyl [Re: panic]
Old Dollar Offline
Loc: Free State of Jones, Mississip...
10-4
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Top
#661301 - Sat Jul 10 2010 01:41 PM Re: Headers and Dual carbs on a 6 cyl [Re: Old Dollar]
crenwelge Offline
Loc: Fredericksburg, Texas
Almost 50 years ago, my favorite setup on a 302 GMC was 3 x 2 with progressive linkage. GMC 302 was born with a 2 barrel.. either a 4 bolt Stromberg or a 3 bolt Holley. My choice was the Ford 3 bolt Holley which as actually designed for a 272. I ran off the center one which actually gave me improved throttle response at the low end and just puttering around town. The other two opened quickly a little past half throttle. I think a lot of it is in how you drive them. I never opened the end two up until I had my rpm's up so I would get some velocity through them. If I tried giving it too much throttle at low rpm, I had better have a fire extinguisher handy. I think it is a lot in how you drive. I was 35 years old before I drove an automatic. Today there are a lot of 35 year olds who have never driven a standard.
Top
#661316 - Sat Jul 10 2010 02:33 PM Re: Headers and Dual carbs on a 6 cyl [Re: crenwelge]
webstershotrods Offline
Loc: Temple ,TX
I have been researching and favoring the GMC 302,Just need to find one that I can afford and runs .Looked at the 3 carb set up also.Also going to use a turbo ,just looking for low boost , nothing more than a strong street engine with good manners .Any other info or pictures you have would be great to add to what Im gathering. I would like to use all parts from the 50's to 60's
Edited by webstershotrods (Sat Jul 10 2010 02:36 PM)
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Top
Moderator:  KCMongo
