The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (TPR57C, tomctomc, Mickey3100, Organbuilder, greenie-reddy), 523 Guests and 4 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#632339 - Fri Mar 26 2010 10:47 AM Positive cable
bud8541 Offline
Loc: Arizona
I have a 53 3100, and the truck runs fine it starts up but when it get's hot it acts like the battery is dead but after it cools down it starts right back up. I was told that my cable to the starter is not big enough. It still has the 6 volt system. Can anyone tell me what the cable diameter should be? I did add the ground strap from the engine to the frame and still same problem. Any help is appreciated.
Top
#632347 - Fri Mar 26 2010 11:14 AM Re: Positive cable [Re: bud8541]
truckernix Offline
Loc: Bracebridge Ontario Canada
Sometimes thes motors tend to be harder to turn over when they are warm. My 216 is one such case because I shimmed the main bearings with the minimum possible clearance. I would try turning it over by hand when it is cold and then when it is hot.
Another thing to look at is the size of the cables. There are a few posts on that. Also if the timing is too advanced, it can cause problems. You can check for this by turning it over with the ignition off.
_________________________
1951 1 Ton Completed
Top
#632365 - Fri Mar 26 2010 12:40 PM Re: Positive cable [Re: truckernix]
vtmlro Offline
Loc: California
You should try what truckernix suggested first. If then you do need to replace the cables then the forum by Randy Rundle under tech tips says the original 6 volt cables had 4ga wires from the battery. You can also do as he suggested and what I would do is use 1ga which is a bigger wire. To better understand it the cables act like pipes in a water system. The bigger the pipes are the more water will flow. The smaller they are the more it will restrict water flow. The water in the case of your truck would be your amps from the battery. I would suggest to replace both the negative and the positive. This will create even current(amps) flow from the battery.
Chevy 1956 3200
"So she said, "either I go or the truck goes!"....Hmm, I wonder what she's doing these days?"
Top
#632384 - Fri Mar 26 2010 02:08 PM Re: Positive cable [Re: vtmlro]
cletis Offline
Loc: Parker County Texas
If the truck has 12V cables, like the only ones available in the parts stores, your cables are too small. Lots of 6V users use 00 cables.
1954 GMC Suburban
My TRUCKS website
Top
#632395 - Fri Mar 26 2010 02:48 PM Re: Positive cable [Re: cletis]
bud8541 Offline
Loc: Arizona
That is what I heard they have to be 00.
Top
#632431 - Fri Mar 26 2010 05:16 PM Re: Positive cable [Re: bud8541]
vtmlro Offline
Loc: California
Yes, 00(2/0) is correct if you use aluminum cables. I aplogize for not making that clear and thanks guys for catching that. My calculations were based on copper wire which witstands higher amp capacity and has better durability then the aluminum. Most likely the stores will carry aluminum. If you do find some that are complete copper then it will be 1AWG. If you are confused then just search N.E.C. table 310.17.
Chevy 1956 3200
Top
#632502 - Fri Mar 26 2010 09:52 PM Re: Positive cable [Re: vtmlro]
tclederman Offline
Loc: Jarvisburg, NC
1 AWG copper would probably work fine. I use 00 AWG copper on my 6v vehicles (hot and ground wires from battery).
Top
#633079 - Mon Mar 29 2010 12:11 AM Re: Positive cable [Re: tclederman]
bud8541 Offline
Loc: Arizona
Installed the 00 cable, it made a big difference in the way it starts, just hit the starter and it fires right up no resistance.
Top
#633093 - Mon Mar 29 2010 01:29 AM Re: Positive cable [Re: bud8541]
vtmlro Offline
Loc: California
It looks like you had a fun productive weekend.
Chevy 1956 3200
Top
#633124 - Mon Mar 29 2010 09:04 AM Re: Positive cable [Re: vtmlro]
tclederman Offline
Loc: Jarvisburg, NC
Good news, Bud.
The order of importance in the starting system (with no wasted $$ spent):
After checking out the battery and all components in the ignition system, if the engine is cranking slowly, check out (or install/service) the following:
1. Good cables from the battery - both the positive lead and the negative lead (1 gauge to 00 gauge, copper).
2. And, clean/shiny contacts for the cable-connections - clean metal, protected with conductive, anti-oxidant grease ( Kopr-Kote, Kopr-Shield (no longer listed by Eastwood), or NAPA: BK 7652569.
Next to consider (although, I now do this first on my trucks):
3. From the battery: run the positive cable to the starter (the normal arrangement) AND the negative cable to a starter-to-clutch-housing bolt (not the normal arrangement). Be sure to still use other frame-to-block ground cables (and maybe a head-to-firewall ground cable).
4. Then, rebuild (or have rebuilt) starter, or buy a new/rebuilt starter (NAPA now has them, as low as $60).
If the above actions still fail, you will have good starting components (that you will need anyway). Unfortunately, you'd have to look elsewhere for the cause of the slow-cranking (too tight an engine?).
Top
Page 1 of 2 1 2 >
Moderator:  Rusty Rod
