The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
30 registered (53 green 1- ton, BC52, Chilidogg, Bills Auto Works, Cosmo, DinoKruzOrdinanc, 2 invisible), 443 Guests and 4 Spiders online.
Forum Stats
39,277 Registered Members
48 Forums
104,811 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
Jimmymack68, kc0kfg, Nic-Rebel450CA, tommy65gmc
Image Posting Policy
Page 1 of 3 1 2 3 >
New Reply
Topic Options
#627534 - Tue Mar 09 2010 09:02 PM Patch panel and cab corner install
Doug5558 Offline
Loc: Converse, TX
I just unpacked my welder and I got these great panel clamps that I ordered. At some point I'll order the cab corners and patch panels to start. My question is, how do you measure them out to cut? I've seen where people place the new panel over the old and use a Sharpie to mark out the lines. I assume you cut on the scrap side of the line. What thickness of cutting whell do you use? Have a .040 wheel. I'm going to practice first. I've got plenty of scrap. Input please!
Top
#627641 - Wed Mar 10 2010 07:43 AM Re: Patch panel and cab corner install [Re: Doug5558]
Pete52 Offline
Loc: melrose pk. il.
When I cut out old stuff to replace with a patch panel I outlined the patch with a sharpie than on the frist cut ,cut it maybe a 1/2 inch below the line , one trick is to get the patch to fit tighter and have a closer fit so you want to make the final cut "mark" as close to the new panel fit as it will be when your done .
that cut off wheel is fine
Practice is the key and common scense
Pete
_________________________
1952 Chevy 3100
More pix on Photobucket
Top
#627707 - Wed Mar 10 2010 12:54 PM Re: Patch panel and cab corner install [Re: Pete52]
crenwelge Offline
Loc: Fredericksburg, Texas
It is not as simple as marking and cutting. The initial cut is simply that, but I cut it a little lower the actual line will be. I use a nibbler where I can to prevent distortion from heat. I make a jig to get a reference for the bottom of the corner panel. I then remove as much metal as needed to get the proper fit and gap to weld. The little clamps are nifty, but they are not a fix all. The patch panels are not always the same contour as as the parent metal. You will want to weld in small stitches to prevent warping. Quite often you will have to bend the metal a little between the stitches to be a proper match. Time you spend aligning the two pieces will greatly reduce the amount of grinding later on. Practice a lot on some junk first. Weld 2 curved pieces together and then grind and then lay a something over the splice with the same curvature. With practice and patience, you can make a patch you can be proud of.
Top
#627931 - Thu Mar 11 2010 07:30 AM Re: Patch panel and cab corner install [Re: crenwelge]
Doug5558 Offline
Loc: Converse, TX
Thanks for the ideas. I'll probably wind up winging it on the cuts a little more because the cab corners are so rusted that the have collapsed. The cab was on the ground when I bought it. I have abit to drill out some of the spotwelds. It's a 3/8 spotweld cutter. I think it may be a little big. Do you use the cutters?
Top
#628246 - Fri Mar 12 2010 07:57 AM Re: Patch panel and cab corner install [Re: Doug5558]
Doug5558 Offline
Loc: Converse, TX
Has anybody ever heard of leaving the inner cab corner out? I saw an article on a old truck magazine website that said they had left them out. If so, is there some type of patch that would go in to fill the odd shaped hole so you don't have to listen to the road go by?
Top
#628248 - Fri Mar 12 2010 08:21 AM Re: Patch panel and cab corner install [Re: Doug5558]
truckernix Offline
Loc: Bracebridge Ontario Canada
I wouldn't leave the inner corner out. They all go together to form a strong structure. You will want the cab sitting exactly as it will be on the truck so that it isn't distorted. I always try and use only as mutch of the patch as needed. If you mees up and have to do another fitting, you can buy a new patch but not a new cab.
1951 1 Ton Completed
Top
#628348 - Fri Mar 12 2010 01:44 PM Re: Patch panel and cab corner install [Re: truckernix]
KC in NH Offline
Loc: NH
I take a different approach. I only use as much of the patch metal as I have to, as others have stated. Then I work the patch metal to have the same contours as the body, next hold the patch in place and mark the outer edge. Cut the body about 1/2" shy of the mark. At this point using clecos I attach the panel along the very edge. Using a end post grinder and a cut off wheel I start cutting through both the patch and the truck removing clecos and tacking as I go. You must be carefull to get the metal in the same plane as you advance. I stay about three inches behind the cut. After all the cutting and tacking is complete I skip around mig welding the seam and the cleco holes until it's all one piece. Grind the welds and more times than not, the resulting fit up requires no filler
A posse ad esse
http://s890.photobucket.com/albums/ac102/chiefbobber
Top
#628366 - Fri Mar 12 2010 03:29 PM Re: Patch panel and cab corner install [Re: KC in NH]
enigmaT120 Offline
Loc: Falls City, OR
KC I would love to see a video of that technique.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Top
#628417 - Fri Mar 12 2010 06:00 PM Re: Patch panel and cab corner install [Re: enigmaT120]
Brad Allen Offline
Loc: Salt Lake City, Utah
Here are some pictures of mine when I did it. I Tig welded mine in but KC in NH's procedure is basically how I did it.
http://community.webshots.com/photo/2373924850102454676QqDeNK
Top
#628427 - Fri Mar 12 2010 06:47 PM Re: Patch panel and cab corner install [Re: Brad Allen]
Donn Offline
Loc: US
Super pictures Brad
Top
Page 1 of 3 1 2 3 >
Moderator:  Fourbrads, HandyAndy1947
