The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (Drmike, Jose.a909, borpa11, tomctomc, apache3600), 380 Guests and 4 Spiders online.
Forum Stats
39,419 Registered Members
48 Forums
105,447 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
250supersix, 48 Chevrolet 1 Ton Panel, 59lover, Alan de la Garza, Mark Lewis, preacherman
Image Posting Policy
Page 1 of 6 1 2 3 4 5 6 >
New Reply
Topic Options
#616058 - Tue Feb 02 2010 11:52 AM 235 Engine Identification
Scout Offline
Loc: Bellevue, Washington
Hi All,
I have a 1953 3600, but it does not have the original 216ci engine. Rather, the engine is a 235ci. The most I've been able to determine is that the engine is a standard 235 model and was made on Feb. 6th, between 1957 and 1962. Apparently, from 1957 on forward, chevy 235ci engines stopped using serial numbers.
So, how do I determine the actual year of production for this engine? I have the following information from the engine block: Casting # = 3769716, Engine ID = F0206A, and two other strange things cast into the block and located below the Engine ID boss --> They are CON 4 and B52.
Can anybody shine some light on my confusion?
Thank you
Top
#616065 - Tue Feb 02 2010 12:00 PM Re: 235 Engine Identification [Re: Scout]
Hotrod Lincoln Offline
Loc: Dellrose, TN
There is a machined pad just behind the distributor with a stamped number on it. The letter prefix at the beginning of the stamped number should identify the year of manufacture, and other details about that specific engine. There are several websites available with engine number decoding information, just google "Chevrolet engine numbers".
EDIT: Try this link:
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/cast.html
Better re-check that casting number- - - -you might have a 261 engine instead of a 235. If so, that's a real find! The casting number you list differs one digit from either a 235 or a 261 number.
Found it! The Inliners' site lists your casting number as a 60/61 truck 235.
http://www.inliners.org/becks/BCN2.html
Edited by Hotrod Lincoln (Tue Feb 02 2010 12:19 PM)
_________________________
What would a bulldog cross-bred with a Shi Tzu be called?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#616089 - Tue Feb 02 2010 12:43 PM Re: 235 Engine Identification [Re: Hotrod Lincoln]
waldo53 Offline
Loc: ID
You're right about the serial no.s after '57, they just don't help much in ID'ing your engine. But, I think the B52 marking tells us the story, cast date of Feb 5, 1962.
If that's wrong, someone else will surely set the record straight.
Top
#616154 - Tue Feb 02 2010 04:08 PM Re: 235 Engine Identification [Re: waldo53]
tclederman Offline
Loc: Jarvisburg, NC
I think that the 3769716 block casting code (235 ci block) was used from 1958-63.
As waldo53 posted, the date casting code is the clincher (1962).
Top
#619874 - Sun Feb 14 2010 01:54 PM Re: 235 Engine Identification [Re: Scout]
BROTT Offline
Loc: California
hello all my first post, want to know what year my 235 is cast# 3886848 eng# F0408J
Top
#619884 - Sun Feb 14 2010 02:14 PM Re: 235 Engine Identification [Re: BROTT]
LONGBOX55 Offline
Loc: DANVILLE IL
The A code in the serial number denotes it's a Passenger application.
Bill Burmeister
Top
#630830 - Sun Mar 21 2010 10:59 AM Re: 235 Engine Identification [Re: LONGBOX55]
Scout Offline
Thanks to all for your help and information!
Looks like the engine block was cast in Flint, Michigan on February 5th, 1960/61/62 (conflicting websites abound) and that its intended role was "Standard" (as designated by the 'A' serial number suffix).
So this little truck rolled along for almost a decade and then had its original 216 replaced by a plain jane 235.
Excellent nostalgia!
Top
#677218 - Sat Sep 11 2010 08:46 PM Re: 235 Engine Identification [Re: Scout]
fosters51deluxe5 Offline
Loc: NE tacoma, Wa
hi all,
i have a 51 chev 5 window. it also has a 235. dont have the casting number but next to the distributor is #FO215JC. can anyone tell me what year the engine is from?? thanks
jeff
gig harbor wa
Top
#677242 - Sat Sep 11 2010 11:00 PM Re: 235 Engine Identification [Re: BROTT]
hoyt Offline
Loc: Kirkwood, MO
Brott,
Where was the casting number 3886848 found? The block casting number reference that I use do not have that number. However, 3836848 is the cylinder head number for most 1956 and later 235 engines. Look at this serial number reference for the FO408J decoding. The engine casting number is on the lower forward passenger's side of the block. The casting date code on the block by the starter is also useful. Look at Tim's great site for more useful information.
Hoyt
Top
#686489 - Fri Oct 15 2010 05:39 PM Re: 235 Engine Identification [Re: hoyt]
nrdesieyes Offline
Loc: Santa Cruz, CA
Hey all, I'm totally perplexed by this one. A guy is selling what he thinks is a 1952 Chevy 235. The numbers on it are:
N375583DAL
3701887
GM3
I can't find either "3701887" or "375583" on the list of casting numbers at http://www.inliners.org/becks/BCN2.html or http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/cast.html
Any ideas on what these numbers should be telling me? What the heck is this motor?
Best,
Nick
Top
Moderator:  53moneypit, Woogeroo
