The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
47 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 376 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
New Reply
Topic Options
#612346 - Fri Jan 22 2010 08:05 AM Dwell meter hookup
YEL 53 CHEVY PU Offline
Loc: TEMPE ARIZONA
I purchased a Sears dwell tach meter and it has 2 leads. I can get the tach to work by hooking blk to neg and red to the coil. What is the hookup procedure for measuring "Dwell".
Bill S
Tempe, AZ
_________________________
Bill S.
Tempe, AZ
Top
#612393 - Fri Jan 22 2010 11:12 AM Re: Dwell meter hookup [Re: YEL 53 CHEVY PU]
Hookalatch Offline
Loc: Cottonwood, CA
Mine is at least 2 decades old now but it has a switch that you position for one or the other. Look for some kind of switch on yours.
Chuck
1952 Chevy 3100 1/2-Ton
More pictures on Photobucket
Top
#612394 - Fri Jan 22 2010 11:12 AM Re: Dwell meter hookup [Re: YEL 53 CHEVY PU]
Harvester Offline
Loc: Tucson, Arizona
Bill,
The positive lead of the meter goes to the coil negative terminal, or to the wire terminal on the distributor- either connection will do, but the coil connection is a better choice. The negative meter lead goes either to an engine ground or to a battery ground- not to the coil.
There probably is a 'Cal' position on the function selector knob. If so, turn the selector to that position, then before you connect the meter to the engine, connect the meter leads together and adjust the pointer to whatever set or calibration line is marked on the meter scale. That step calibrates the meter circuitry. Usually the set line is a black line at the high end of the scale, and might be marked 'Set' or 'Cal.' There usually is a second knob for the calibration adjustment. Also, there should be a black bar at the high end of the meter scale, and may be identified as 'Distributor Resistance.' When you connect the dwell meter and turn on the ignition switch, with the points closed, the meter pointer should settle in the black bar. That tells you that the primary resistance in the distributor is at an acceptable level (0.2 volts or less) for getting an accruate dwell reading.
After everything is set up, don't forget to set the function selector to the proper cylinder position if the meter has that setting- it probably has- I haven't looked at a Sears dwell meter for quite a while.
Hope this helps.
Harvester
Top
#612397 - Fri Jan 22 2010 11:17 AM Re: Dwell meter hookup [Re: YEL 53 CHEVY PU]
Hotrod Lincoln Online
Loc: Dellrose, TN
Dwell is measured by connecting the red lead to the coil (-) terminal, the distributor side, and connect the black lead to ground. A dwell meter is actually a voltmeter, and it's reading an average of the points-open voltage (full charging system voltage) and zero volts when the points are closed. It's expressed in "degrees of dwell" since a set of points that stay closed (dwell together) all the time would be 60 degrees of distributor rotation, and open all the time would be zero degrees of dwell. A 66% dwell reading would be 40 degrees on a 6-cylinder engine.
"It is better to be feared than loved, if one cannot be both"
Machiavelli
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#612584 - Fri Jan 22 2010 11:22 PM Re: Dwell meter hookup [Re: Hotrod Lincoln]
Loc: TEMPE ARIZONA
Thanks for all the info.
Bill S.
Tempe AZ
Bill S.
Tempe, AZ
Top
Moderator:  Rusty Rod
