The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
58 registered (49nut, 3B, 5 Window 9434, 48bigtrucks, 1953 panel, 3 invisible), 690 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,692 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
New Reply
Topic Options
#607316 - Tue Jan 05 2010 07:20 AM radiator overflow problem
josie Offline
Loc: ks
hey guys i havent found my answer on the topic forum so my problem is i have a 49 pickup which i have had for years all original except motor which is a 235 62 chevy motor,it has always seemed to have antifreeze loss thru the radiator overflow tube,i have changed all hoses new radiator,new water pump,several thermostats,new heater hoses,fresh antifreeze and it will still lose water whether summer or winter especially just sitting there idling and i have lowered the level in the radiator it still wants to come out the overflow tube i have given up until i met this web site can you give me a clue josie
Top
#607319 - Tue Jan 05 2010 07:36 AM Re: radiator overflow problem [Re: josie]
Pete52 Offline
Loc: melrose pk. il.
How's the temp? If it's not overheating could be the rad cap needs to be replaced might not be seating against the rad inside lip where the rubber seals against the rad what pound rad cap are you running?Check to make sure your cap is sealing against the rad.lip inside the rad.
Pete
Edited by Pete52 (Tue Jan 05 2010 07:39 AM)
_________________________
1952 Chevy 3100
More pix on Photobucket
Top
#607335 - Tue Jan 05 2010 08:50 AM Re: radiator overflow problem [Re: Pete52]
Denny Graham Offline
Loc: Sandwich, IL
Josie, if you keep adding coolant you’re going to keep boiling it out. The level in a stock AD radiator when "cold" should be just barley above the baffle in the radiator. This is often mistaken as a low coolant level, if you add coolant to bring it up some it's just gonna puke it out. As Pete stated, if your temperature is running normal then let it seek it's own level, put the cap on and forget it. If the cooing system is stock then it is a zero pressure system, you can get away with a 4lb. cap but no more or you will be bending tubes in the radiator and heater coil. Running your cooling system at 4lb. will increase the boiling point slightly. Your '62-235 would have originally run a 160° to 180° thermostat depending on the season.
Denny Graham
Sandwich, IL
Top
#607344 - Tue Jan 05 2010 09:15 AM Re: radiator overflow problem [Re: Denny Graham]
dale937 Offline
Loc: NE Ohio
The simple fix is to install an overflow jug.It is natural for your radiator to overflow as the coolant heats up.
Top
#607345 - Tue Jan 05 2010 09:16 AM Re: radiator overflow problem [Re: Denny Graham]
Virginiafiretruck Offline
Loc: Virginia Beach
I agree with Denny. I run a zero degree cap and it doesn't overflow a single drip.
Top
#607421 - Tue Jan 05 2010 02:41 PM Re: radiator overflow problem [Re: Virginiafiretruck]
PapaJ Offline
Loc: Security, CO
I would make sure and check when the motor is idling if in fact that it is leaking out the overflow tube and not the water pump or hoses.You can do a pressure test to find out.
1953 Chevy Two-Ton
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Top
#607676 - Wed Jan 06 2010 12:57 PM Re: radiator overflow problem [Re: PapaJ]
truckernix Offline
Loc: Bracebridge Ontario Canada
I would check the temperature of the upper rad hose when the gauge says it is warm. If the rad hose is cool, you have an air lock behind the thermostat and the coolant in the block will form voids and expell coolant out the overflow. This situation will not alwayys cure itself and in that case the air needs to be removed.
1951 1 Ton Completed
Top
#607759 - Wed Jan 06 2010 05:41 PM Re: radiator overflow problem [Re: truckernix]
Spareparts2 Offline
Loc: Lansing, Ks
Check the cap if it has a "R" in the part # it is the wrong cap it is for a system with a coolant jug. It will expell coolant into the jug when when it gets up to temp and suck the coolant back into the radiator when it cools off. The coolant level should be about 2 knuckles down on your index finger(old country boy measurement).
You Learn more Listening than Talking
Top
Moderator:  cletis
