The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
65 registered (49 3100, 1953 panel, 51cowboy, 2-Ton, 3B, 42465967, 3 invisible), 566 Guests and 4 Spiders online.
Forum Stats
39,395 Registered Members
48 Forums
105,329 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
48silverado, Anthony M, Big Tike, brown12202, CRexRun, Jim Meier, jkully, kruisin53, paul 49, shaxinator, Steven T, ultimatezlover
Image Posting Policy
Page 3 of 5 < 1 2 3 4 5 >
New Reply
Topic Options
#597862 - Thu Dec 03 2009 06:01 AM Re: Biggest 6-Cylinder Engine? [Re: spanky]
C10 - C90 Bill Offline
Loc: Moneta, VA
Originally Posted By spanky
There was also a 707ci. GMC 6 cyl. gas engine,first available in 1950.
While I was searching around, I did see something about a 707, but it was hard to believe.
I also read some interesting info about GMC back in the old days. There was some pretty impressive stuff. GM even won an award from the US Government for their contributions in WWII.
Read more here, along with some pretty good pictures:
http://wiki.gmnext.com/wiki/index.php/A_Brief_Outline_of_the_First_Century_of_GMC_Truck_History
_________________________
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Top
#597876 - Thu Dec 03 2009 08:03 AM Re: Biggest 6-Cylinder Engine? [Re: Grigg]
tclederman Offline
Loc: Jarvisburg, NC
Originally Posted By Grigg
Looks like a 49 or 50 2 ton. And another (conventional) one in the background.
Should have been a gas engine.
And a splash oil 235 right?
Hopefully Tim will come along and set us all straight.
Grigg
Late 1949 or 1950.
- hood side-emblems changed to two pieces in late-49
- door vent-windows started in 1951
The COEs most likely came standard with a 235 (low pressure) engine. A 1949 235 would have produced 93 hp and a 1950 235 would have produced 105 hp (due to larger intake/exhaust ports and larger valves).
Top
#597898 - Thu Dec 03 2009 09:06 AM Re: Biggest 6-Cylinder Engine? [Re: C10 - C90 Bill]
don stocker Offline
Loc: osceola, wi
International made a 501 Gas 6 cylinder.
Top
#597914 - Thu Dec 03 2009 10:04 AM Re: Biggest 6-Cylinder Engine? [Re: don stocker]
53moneypit Offline
Loc: Smallville IN
"International made a 501 Gas 6 cylinder."
Wasn't that the one they called the Black Diamond? I also recall a Red Diamond IH engine.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Top
#597945 - Thu Dec 03 2009 11:23 AM Re: Biggest 6-Cylinder Engine? [Re: 53moneypit]
don stocker Offline
Loc: osceola, wi
I think that your correct Dave. I had a old IHC semi tractor and it had the 450 6 cylinder which I recall to have been called a Super Red Diamond. Don
Edited by don stocker (Thu Dec 03 2009 11:51 AM)
Top
#597967 - Thu Dec 03 2009 12:42 PM Re: Biggest 6-Cylinder Engine? [Re: don stocker]
crenwelge Offline
Loc: Fredericksburg, Texas
The 707 was from back in the 30's. I'm not sure it was still available in 1950. I have only seen one in my life. It had a direct coupled air compressor and two spark plugs per cylinder. It was about the same size as the 855 block Cummins Diesel used for about 50 years. Fully dressed, a Cummins weights close to 4,000 lbs and were only used in the largest conventional cabs. A 302 was the largest engine that was feasible to retrofit into a Chev of the era pictured. However the 302 wasn't released until 1952. The International captured a large portion of the market in its class with the RD450 in the R190 series truck which was introduced in 1954.
Top
#598426 - Sat Dec 05 2009 01:27 AM Re: Biggest 6-Cylinder Engine? [Re: crenwelge]
spanky Offline
Loc: burlington, n.c.
I don't know if it's the same engine as crenwelge has mentioned, but i'm looking at a catalog titled, "GMC Heavy Duty Trucks- Gasoline-diesel", published 5/1949 that list a group of engines as new for 1950, & they are a 318, 360, 426, 503, & 707.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Top
#598484 - Sat Dec 05 2009 10:46 AM Re: Biggest 6-Cylinder Engine? [Re: spanky]
peytonmaterne Offline
Loc: SE Ohio
I think Mack had a 707ci six in the 50s also, just a coincidence?
Top
#598495 - Sat Dec 05 2009 11:13 AM Re: Biggest 6-Cylinder Engine? [Re: spanky]
Grigg Online
Loc: Lexington, VA
My 49-53 GMC truck master parts book number X-152002 (covers model 400-980) makes no mention of the 707 in the engine section, 503 is as big as it list.
Was there an even larger truck that would have used the 707?
Or did the catalog predict an engine that wasn't available after all?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Top
#598505 - Sat Dec 05 2009 11:52 AM Re: Biggest 6-Cylinder Engine? [Re: Grigg]
tclederman Offline
Loc: Jarvisburg, NC
Look at 1933 and 1936.
from Coachbuilt.com (707 used in Yellow Cab Co. bus - bought by GMC )
"Greyhound, the dominant U.S. intercity bus operator, arranged to sell its wholly owned bus manufacturing subsidiary C.H. Will Motors Corp. (see Will) to Yellow Coach during 1929, and Yellow subsequently designed and built a 250-inch-wheelbase Type Z parlor coach chassis to Greyhound specifications. This type of bus was the last conventional Yellow chassis to be introduced, as work was al. ready under way on new designs that enclosed the engine within the body. The big Z-250 used a 707-cubic-inch six-cylinder engine, while smaller Yellows were equipped with either 616 or 568-cubic-inch motors. After 1930, GM Truck engines were used in the smallest models in place of the earlier Cadillac or Buick automobile engines.
Between 1931 and 1934, Yellow built and sold a small number of city transit buses with rear-mounted engines that drove forward. These were not particularly successful, the largest types encountering 'significant clutch trouble because the largest engine that could be accommodated within the bus was too small for the size of the vehicle. In the meantime the small types U and W were superseded by front-engine forward-control buses.
The use of letter designations was given up, and buses (and a few trolley-coaches) of the new designs were labeled with model numbers in the 700 series. Production of types V and Z, especially the parlor versions, continued until 1936."
Top
Moderator:  69Cuda, Grigg
