The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (Gabes-trucks, Cosmo, 1 invisible), 408 Guests and 4 Spiders online.
Forum Stats
39,284 Registered Members
48 Forums
104,820 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
35pickup, 68haywagon, Bubbles, buxman66, Franklin C. Cooley, Larry Shaddy, LimeyC10, mark8544, mike boyle, Pee-Wee, peter 60 stepsid
Image Posting Policy
New Reply
Topic Options
#597768 - Wed Dec 02 2009 09:54 PM 6 lug wheels
bob fortner Offline
Loc: SC
will a late model colorado (chevy) 6 lug wheel fit a 50 chevy 3100 ? What wheels (stock)will fit?
Top
#597785 - Wed Dec 02 2009 10:16 PM Re: 6 lug wheels [Re: bob fortner]
Achipmunk Offline
Loc: Boiling Springs, S. C. 29316
I have NOT personally tried them but one of my friend says he has some on his..... but according to most reports they will rub the tie end rod unless you use a spacer...which most folks don't recommend but some run the spacers with no problems.
I think pickup rims up to about 1970 will work.
Maybe someone with "hands on" experience will be along shortly.
_________________________
Pictures in my Photobucket
Top
#597805 - Wed Dec 02 2009 11:00 PM Re: 6 lug wheels [Re: Achipmunk]
ZooKeeper
Unregistered
Can't say if the Colorado (chevy) 6 lug wheel is the same bolt pattern or not BUT I can tell you that late model(90 & up)6lug full size trick rims will only work w/the help of a 1/2inch spacer....Joe
Top
#597825 - Wed Dec 02 2009 11:25 PM Re: 6 lug wheels [Re: ]
1953 panel Offline
Loc: Oakwood, Ontario Canada
The bolt pattern from my 2003 3/4 ton Savana is the same as my '53 half ton panel. I only used the wheels to roll the chassis around in the shop.
1953 Chevy Panel
More pix on Photobucket
Top
#598095 - Thu Dec 03 2009 10:44 PM Re: 6 lug wheels [Re: 1953 panel]
LONGBOX55 Offline
Loc: DANVILLE IL
The backspace is too deep for use on the earlier trucks, especially on the 1/2 tons and even moreso on the Colorado. The bolt pattern on the '88 and up Silverado as well as the Colorado is the same as the earlier trucks. Up to '87 4x4 uses the same bolt pattern and backspace as the early trucks. 3/4 ton used a mix up to about '00, some have the deep backspace, some have the mid backspace (about 4"). The mid backspace wheels will work on the IFS trucks, might rub on a hard turn on the I beam trucks.
Bill Burmeister
Top
#598154 - Fri Dec 04 2009 08:16 AM Re: 6 lug wheels [Re: bob fortner]
Hot Rod John Offline
Loc: Central Colorado
Spacers work if you buy the correct spacers for the application.
The spacers that bolt to the lugs then have new lugs to bolt the wheels to are good. http://adaptitusa.com/6x550to6x550wheeladapter.aspx
Spacers that simply use longer than stock studs and a disc with holes in it, not as good. http://www.jegs.com/i/JEGS/555/65054/10002/-1
Check this link. Last guy actually had 2006 wheels on his 1966. http://67-72chevytrucks.com/vboard/showthread.php?t=374891
Edited by Hot Rod John (Sat Dec 05 2009 07:48 AM)
Top
Moderator:  cletis
