The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
46 registered (55 SHAKER, 66flea, 52Carl, Allen Lane, 4 invisible), 639 Guests and 4 Spiders online.
Forum Stats
39,736 Registered Members
48 Forums
106,167 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
52 pick-up, coppertinman, daviper1996, deimos540, Mr. Pickett, Rick In VA
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#592746 - Sun Nov 15 2009 04:26 PM How do I test my 6 volt generator?
Spencer Rogers Offline
Loc: Bath, PA
I have a 1949 3600 with the original motor and electrical system. I am trying to figure out the best way to verify if my system is charging the battery? I am sure it is something simple, but I am not sure how to do that.
Can someone kindly reply with the steps to rule out a bad generator?
Top
#592747 - Sun Nov 15 2009 04:31 PM Re: How do I test my 6 volt generator? [Re: Spencer Rogers]
FriedGreenTmater Offline
Loc: colorado
The proper way is to check it with a volt meter at the battery with the vehicle running. If you don't have one you can disconnect the negative battery terminal while the truck is running, if it dies you are not charging, if it stays running you are. Do not disconnect the positive, more potential for unwanted sparks.
_________________________
Fried Green T'mater (Vern)
1953 Chevrolet 3600
More pix on Photobucket
Caution: Political Statement
Top
#592749 - Sun Nov 15 2009 04:35 PM Re: How do I test my 6 volt generator? [Re: Spencer Rogers]
Hotrod Lincoln Online
Loc: Dellrose, TN
First, momentarily attach a jumper wire from the BAT terminal of the regulator to the ARM terminal, for no more than a second or two. This "polarizes" the generator, establishing "residual magnetism" in it. With all the wires removed from the generator, there should be at least 1/2 volt present at the ARM terminal of the generator with the engine running. If this voltage is not present after polarizing, don't bother with any other tests- - - - -you've got a bad generator. If the residual voltage is there, reconnect the wiring, and run the engine with a jumper wire connected between the FLD terminal of the generator and ground. The voltage at the ARM terminal should increase rapidly as you rev up the engine. Do not allow it to go above 8 volts or so. If it will do that, you've got a generator that's capable of charging the battery. If it's not charging, the trouble is in the regulator or the wiring. Do the same series of tests- - - -ground the Field wire and measure voltage at the ARM wire of the regulator to check the condition of the wiring.
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#592750 - Sun Nov 15 2009 04:42 PM Re: How do I test my 6 volt generator? [Re: Hotrod Lincoln]
Loc: Dellrose, TN
PLEASE don't disconnect battery terminals with the engine running- - - - -you can do major damage to anything that's voltage-sensitive when the generator voltage spikes to 50 volts or more momentarily. I've seen that on an oscilloscope dozens of times. Definitely don't do that on a vehicle with an alternator, and NEVER do it on one with a computer!
Top
#592753 - Sun Nov 15 2009 04:50 PM Re: How do I test my 6 volt generator? [Re: Hotrod Lincoln]
Loc: colorado
Hotrod is correct according to the books. However I have done this to just about every vehicle I have owned without mishap except for the once I pulled the positive cable instead of the negative. Turns out my alternator was over charging and the battery was letting out gas, nobody was hurt but it was scary. Probably might have happened with either cable. Definitely a shade tree maneuver, but it gives you an answer pretty quick.
1953 Chevrolet 3600
Top
#592773 - Sun Nov 15 2009 05:47 PM Re: How do I test my 6 volt generator? [Re: FriedGreenTmater]
Loc: Bath, PA
I have a volt meter and can certainly check it that way, but what am I looking for on the meter? More voltage than the battery has by itself?
Top
#592807 - Sun Nov 15 2009 08:05 PM Re: How do I test my 6 volt generator? [Re: Spencer Rogers]
truckernix Offline
Loc: Bracebridge Ontario Canada
When the motor is running well above idle, you should see about 7.2 v or so.
1951 1 Ton Completed
Top
#592829 - Sun Nov 15 2009 09:08 PM Re: How do I test my 6 volt generator? [Re: Spencer Rogers]
Loc: Dellrose, TN
If the battery is very low on charge, the charging voltage at fast idle should be about 6.5 to 6.8 volts. As the battery charges up, the current flow should decrease (ammeter closer to center) and the voltage should go up. With a fully-charged battery, the charge current should be 5 to 8 amps, and the voltage should be around 7.2 to 7.5 volts volts.
Top
#593490 - Wed Nov 18 2009 07:37 AM Re: How do I test my 6 volt generator? [Re: truckernix]
Loc: Bath, PA
the challenge I have with this is that I will not get that reading. I use an 8 Volt battery, so the voltage is more than that when the battery is charged. Is there another location where I can check the output of the generator to see if I am getting that voltage?
Top
#593494 - Wed Nov 18 2009 07:55 AM Re: How do I test my 6 volt generator? [Re: Spencer Rogers]
Loc: Dellrose, TN
Dump the 8 volt, or find a pro who can adjust the regulator to charge it. Then buy a BUNCH of light bulbs, particularly headlights. With the regulator set properly, you'll fry lights at a record rate. An 8 volt battery is a solution to a nonexistent problem. Your voltage regulator setting needs to be 9 volts to keep an 8V battery charged.
Top
Page 1 of 2 1 2 >
Moderator:  Rusty Rod
