The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
15 registered (DaveV, brokenhead, cdandelivery, Cosmo, amsanto89, 49nut, 1 invisible), 242 Guests and 4 Spiders online.
Forum Stats
39,265 Registered Members
48 Forums
104,755 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
65 kid, mike in mo, ratmaster, ringgear
Image Posting Policy
New Reply
Topic Options
#591611 - Wed Nov 11 2009 08:59 AM Flarestat 105 wiring diagram
mad max Offline
Loc: Niagara Falls, Canada
I have an NOS switch but the plugs were cut off at some point in time. All I have is about 10 inches of wire (4 red and 1 blue). If anyone has a scan they can send me I'd really appreciate it.
Thanks, Doug
Top
#592121 - Fri Nov 13 2009 12:36 AM Re: Flarestat 105 wiring diagram [Re: mad max]
PapaJ Offline
Loc: Security, CO
Check out tech tips for signal-stats from cletis.
_________________________
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Top
#890607 - Fri Oct 19 2012 02:31 PM Re: Flarestat 105 wiring diagram [Re: PapaJ]
Todd W. White Offline
Loc: Sapulpa, Oklahoma USA!
I have just acquired a Signal-Stat 105Y78 Flasher setup (NOS), but it has no wiring instructions. I looked in the Tech Tips and couldn't find the one you're referring to. I'm wiring a 1965 Chevrolet C-10.
My unit has a part number on the original box as #2234058, and the label says it's a Flasher - Emergency Switch for a GMC. It has the following wires coming out of it, in this order:
* Orange: pigtail to flasher unit, which pigtail's to an inline fuse
* Yellow
* White
* Purple
* White
* Light Blue
* Dark Blue
* Purple
* Green
Other than the Orange, which is obviously the power lead, I have no idea what these do. I'd really like to wire them into my harness using connectors like a junk Model 105Y79 I have has on it (got at a salvage yard - was connected to a truck, but never installed in mine), except the "79" has only 6 wires coming out of it.
Can anyone help me?
THANKS in advance!
Edited by Todd W. White (Fri Oct 19 2012 02:41 PM)
Edit Reason: Additional info added.
1965 Chevrolet C-10 Fleetside
Top
#891127 - Sun Oct 21 2012 05:34 PM Re: Flarestat 105 wiring diagram [Re: mad max]
bump - anyone out there?
Top
#891268 - Mon Oct 22 2012 07:51 AM Re: Flarestat 105 wiring diagram [Re: mad max]
cletis Offline
Loc: Parker County Texas
The dark green, yellow, dark blue and light blue are tapped into the same color wires on the turn signal harness. The white wire of the turn harness is cut and one white wire from the flasher switch goes to one end and the other to the other end. Same for the purple wires. Orange goes to the flasher. "SPLICE WIRES AS SHOWN-SOLDER & TAPE" is on the 1964 instructions. I would solder and shrink wrap.
1954 GMC Suburban
My TRUCKS website
Top
#891426 - Tue Oct 23 2012 01:54 AM Re: Flarestat 105 wiring diagram [Re: mad max]
Where do I get a copy of the 1964 instructions?
- Todd
Top
#891466 - Tue Oct 23 2012 06:44 AM Re: Flarestat 105 wiring diagram [Re: mad max]
cletis Offline
I bought a switch with instructions.
1954 GMC Suburban
My TRUCKS website
Top
#891505 - Tue Oct 23 2012 11:05 AM Re: Flarestat 105 wiring diagram [Re: mad max]
Well, I tried to, as well.... smile
Top
#1177165 - Sun Aug 07 2016 09:39 PM Re: Flarestat 105 wiring diagram [Re: mad max]
vetnat Offline
Loc: Saskatchewan, Canada
Hi. Long shot on reviving an old thread. I have this flasher, also with the plugs cut off. I have been puzzling about the 2 white and 2 purple wires. Now I know! So, when it says to splice them into the turn signal harness, I assume this means into the harness going into the plug on the column, not the wires on the column themselves (ie. after the connector)?
So, would it be possible to just twist the 2 whites together and insert them into the terminal in the connector? I ask because I am modifying this switch to use in my 1961 GMC.
Top
Moderator:  Rusty Rod
