Do you want to try to match the original color?
1912-1966 Chevrolet engine colors engine color: bock, head, oil pan, side cover, valve cover, water pump, timing gear cover. Same people include the clutch housing. Intake and exhaust manifolds (?? it will probably burn off).
black: fan blade and pump pulley, harmonic balancer (I think), generator, starter, coil, distributor, and road draft tube.
Tim
_________________________
1954Advance-Design.com 1954 3106 Carryall Suburban - part of the family for 38 years
1954 3104 5-window pickup w/Hydra-Matic
Z-series (54/55) GMC 350 (2-ton) COE
