22007 Members
36 Forums
53834 Topics
Max Online: 180 @ Sun Mar 23 2008 10:37 AM
#590394 - Fri Nov 06 2009 06:24 PM
1940 separating hubs from drums...how?
Loc: iola,wi.
Hey guys, I'd like to remove the hubs from my drums. I don't see any rivits holding them together, and was wondering how to do it. Rather than beating on them and breaking something I thought I'd ask the experts! Thanks...Jeff
_________________________
It's not rust,...It's patina!
Top
#590446 - Fri Nov 06 2009 09:10 PM
Re: 1940 separating hubs from drums...how?
[Re: wahoo40]
Loc: DANVILLE IL
Without seeing how they are put together, I can only make a guess at what you need to do. There's a possibility that you may have to press out the wheel studs to remove the drum. Some are held on that way.
Top
#590457 - Fri Nov 06 2009 09:40 PM
[Re: LONGBOX55]
Loc: iola,wi.
Thanks longbox, I hadn't considered that.
Top
#590475 - Fri Nov 06 2009 11:03 PM
[Re: wahoo40]
Loc: B.C., Canada
you can also whack them out with a hammer. put the nuts on unil they are flush with the top of the stud, remeber flush so when you whack it with the hammer you are hitting them both squarely athe same time this way you do not screw up the threads on either one as you have to take the nut off to get it apart ron
Top
#590478 - Fri Nov 06 2009 11:06 PM
[Re: padresag]
Loc: DANVILLE IL
If you do go the hammer route, use a brass hammer. A steel hammer, even if you put the nuts on, may damage the threads.
Top
#590545 - Sat Nov 07 2009 10:15 AM
[Re: LONGBOX55]
Loc: Lee's Summit Mo. 64086
Hold the softer hammer on the studs and hit it with a bigger hammer. Joe
Top
#590621 - Sat Nov 07 2009 06:33 PM
[Re: Joe H]
Loc: iola,wi.
Got the hubs apart today with a press. Gave that chi-com press quite a workout. Glad I didn't have to hammer them, cause they were tight! Thanks for all the tips....BTW, Joe H got any pics of that 3 carb setup? Does it perform good? I'm putting a 250 in my 40 and just picked up an Offy intake with 3 carbs, just wondering what to expect.
Top
#590662 - Sat Nov 07 2009 10:04 PM
[Re: wahoo40]
Loc: wv
great tips! flush nuts, brass intermediate. i just ruined some threads on something else by non-flush, steel hammer method
Top
#590685 - Sat Nov 07 2009 10:56 PM
[Re: rednate]
Loc: B.C., Canada
you can always make a few different drivers for removing these kind of studs and for strg ends Take about a 2 or 3" section of 1" hex and drill it and tap it about 1/2" deep with corresponding thread and put it on until it bottoms and then give it a good whack with a hammer,done there are so many cheap tools out there now albeit"china" and if they are avail locally you can buy them. lots of them don't last that long, so they are ok for home use as you may mever use them again ron
Top
#590752 - Sun Nov 08 2009 09:09 AM
[Re: padresag]
Loc: wv
i follow you padre if i think 1" square or round, but, 1" hex? what's that?
Top
