Loc: Prosper, Texas
Let me get yall's thoughts on this. My 54 (6V +grnd) does not turn over. I have had the starter rebuilt thinking it was totally dead and installed a new and fully charged battery. The lights and horn work, but when I step on the starter the ammeter drops to 0. Any Ideas?
Loc: The Lost Pines
I've had the starter drive gear stay engaged in the flywheel and it acts like a dead starter. My solution was to put the truck in gear with the clutch released, then rock the truck forward and back. This turns the engine and flywheel, which releases the starter drive gear. Hope this helps.
Loc: Sandwich, IL
Sounds like who ever rebuilt your starter has one of the field coil leads shorted internally. Best take the starter out and get it up on the bench. Using jumper cables and your new battery see if the starter is operating correctly there before installing it in the truck. Denny Graham Sandwich, IL
Loc: Hays county Texas
Can you turn the engine by hand? When was the last time it ran?
_________________________
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
