I have a Zenith carb that fits a 270 GMC engine.It has an adjustment screw up top near where the air filter mounts at.What is the basic "starting out"point for the screw?I am familar with adjust screw near vacum hookup.Should I set it at 2 turns out?
the only adjustments on my two zeniths is the idle mixture adjustment screw. one of them i put an adjustable jet which is right above the vac advance connection. the idle mixture adjustment screw is on the rear of the carb facing the fire wall. not sure of which one your asking about i cant give you an answer.
next to the big nut that cletis's link shows is a round tag with a rivet head holding it in place. on that tag is the info for your carb. fyi the under the big nut is/was a gas filter. my carbs didnt have them and were removed earlier it is life.
