The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
33 registered (49 3100, 54CarryAll, BBPanel, 46forme, 3 invisible), 601 Guests and 4 Spiders online.
Forum Stats
39,641 Registered Members
48 Forums
105,719 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
jesi, jonflores, Kens 50 PU, Zulu Pete
Image Posting Policy
Page 2 of 3 < 1 2 3 >
New Reply
Topic Options
#585787 - Fri Oct 23 2009 03:16 AM Re: Fan shroud for '63-'66? [Re: 4-5-6 Chevy Trucks]
todjob2000 Offline
Loc: Wa state
I have never seen a shroud for a 6 cyl or even seen brackets to put one on even working in a wrecking yard 20 years ago when they were still all over the place, I'd like to see a picture of one if any one has one or knows where to go.
Top
#585895 - Fri Oct 23 2009 02:14 PM Re: Fan shroud for '63-'66? [Re: 4-5-6 Chevy Trucks]
ratskin Offline
Loc: Illinois
What is the depth of the V8 as compared to the I6? I've got an original that wouldn't line up on my V8, so I assume it's for a 6.
Top
#586603 - Sun Oct 25 2009 09:43 PM Re: Fan shroud for '63-'66? [Re: Brad54]
ctrworker Offline
Loc: southern nm usa
can anybody post info on 60-62 shrouds ? I need one on my 62, but never seen them, as well. thanks
_________________________
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
Top
#587165 - Tue Oct 27 2009 07:18 PM Re: Fan shroud for '63-'66? [Re: ctrworker]
DThela Offline
Loc: Rhode Island
you need 2 shrouds ctrworker, (one for me)!
1963 GMC Suburban
Top
#587295 - Wed Oct 28 2009 03:34 AM Re: Fan shroud for '63-'66? [Re: ratskin]
66Bomber Offline
Loc: Oakdale, CA
I dunno, I bought one of the reproduction shrouds for my '66, and had to heavily modify it to fit. I'm running a 350 on factory mounts with a long water pump, factory fan, and fan clutch. The radiator is a heavy-duty "Desert Cooler" down flow model by US Radiator. The truck came with a six, but I ordered the radiator for the V8 when I did the swap.
I think the extra thickness of the aftermarket radiator might have something to do with the problems I experienced, as I had to remove about 1" of depth, but I also had problems with the shroud sitting at the wrong height on the radiator (fan would hit the bottom of the opening). Got it all together after lots of trial fitting and cutting/grinding though...
Top
#587748 - Thu Oct 29 2009 02:55 PM Re: Fan shroud for '63-'66? [Re: 4-5-6 Chevy Trucks]
JAMES MANSELL Offline
Loc: Port Coquitlam BC
My 65 has no shroud but it does have a gaurd on the top of the rad..I have a pic of it below hard to see though
Edited by ambear (Thu Oct 29 2009 02:57 PM)
Top
#587886 - Thu Oct 29 2009 09:49 PM Re: Fan shroud for '63-'66? [Re: 4-5-6 Chevy Trucks]
Doug 57 Offline
Loc: Booger Hollow (near Clayton, G...
My 1966 with a 283 has an original fan shroud, and is made of fiberglass. I have owned two 1966 trucks that had the inline 6, and both did not have fan shrouds. I never had any cooling problems with either of those 6 cylinder engines.
Brad,
Let me know if you need a picture of the fan shroud in my 1966 C-10. I can take a picture, and e-mail it to you.
Top
#589118 - Mon Nov 02 2009 05:19 PM Re: Fan shroud for '63-'66? [Re: Brad54]
jon1963 Offline
Loc: fayetteville, nc
I have a 1963 shroud, but it is for the 6cyl. I would let it go cheap, as I just converted my truck to a 3core radiator
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Top
#589128 - Mon Nov 02 2009 06:14 PM Re: Fan shroud for '63-'66? [Re: jon1963]
k10 Offline
Loc: NH
The fan shrouds for a 60-62 V-8 truck are metal. They look like this one. 6 cylinders never had shrouds.
http://cgi.ebay.com/ebaymotors/1959-1963...=item2c51842017
The one shown is for a 409 car. I've forgotten the "code", but the number of ribs around the shroud tells you if the shroud is for a 283 or a 409. I have a 409 in my 60 GMC and I purchased a repro shroud and cut it down about an inch and a half. It works fine and looks original. I had purchased a shroud from LMC for my application and it was a fiberglas piece for a crossflow radiator. POS! Not for an original radiator. So if you have an aftermarket rad, go with LMC. If you want an original style go with the metal one.
Edited by k10 (Mon Nov 02 2009 06:15 PM)
Top
#590202 - Thu Nov 05 2009 11:20 PM Re: Fan shroud for '63-'66? [Re: todjob2000]
4-5-6 Chevy Trucks Offline
Loc: Kansas City, KS
I have a couple six cylinder fan shroud extensions, that the original fan shroud attached to. I don't have a photo on my computer, but I will take a few and post them. I have seen them loose, as well as, installed in factory-equipped six cylinder trucks...and I never worked in a salvage yard, but I have owned, collected and restored '60-'66 Chevy trucks since 1981.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
Kansas City, KS 66105
913-207-7789
4-5-6chevytrucks@sbcglobal.net
Photos: http://www.flickr.com/photos/4-5-6chevytrucks/sets/
Custom Parts: http://www.flickr.com/photos/4-5-6chevytrucks/sets/72157627022818563/
www.4-5-6chevytrucks.com
Top
Moderator:  Hambone, sixtyfive c-10
