22007 Members
36 Forums
53851 Topics
Max Online: 180 @ Sun Mar 23 2008 10:37 AM
#589613 - Tue Nov 03 2009 11:25 PM
Tandem Big Bolts or needle in haystack?
Loc: New Zealand
Hi all, about every 5 years I'm on here hoping someone's found a tandem (twin screw) Chevy tractor unit from the mid 50's since all my looking of craigslist and farm auctions has turned up nothing. So has anyone who's been searching had any joy?
Top
#589616 - Tue Nov 03 2009 11:34 PM
Re: Tandem Big Bolts or needle in haystack?
[Re: aventino68]
Loc: Raleigh, North Carolina
You're in luck...Stovebolt member named 'BHMOTOMACH' in Charlotte, NC has an original mint condition 1956 Chevrolet twin screw tractor, even has a few pictures in some of his posts. Look him up!
James
Edited by oldiron57 (Wed Nov 04 2009 12:15 AM)
_________________________
1957 Chevrolet 6400 flatbed dump In the Gallery Webshot pix1942 Chevrolet 1 1/2 ton 1962 Chevrolet M80 tractor
Top
#589637 - Wed Nov 04 2009 02:36 AM
[Re: oldiron57]
Loc: Ramarama
See that a '57 tandem turned up late last year on craigslist and someone posted it on here. Did anyone go and have a look at it?
David Maybelle - '56 3100 Pickup,Blown BBC,5 Speed,IFS,4 link, just frt fenders to go Julie - '48 2 Ton Loadmaster, stock, 6 volt, flatbed w/hoist
Top
#589688 - Wed Nov 04 2009 10:21 AM
[Re: aventino68]
Loc: Nashville, TN
I think most of the twin screw rigs were conversions by aftermarket truck builders. I'm not sure when Chevy started offering factory-built dual drive rigs- - - -most of them had a non-driving "tag axle" if they needed an extra set of wheels for load-carrying capacity. I've seen a few pretty good adaptations of military twin screw rear ends. One I saw in a wrecking yard had a torque splitter and two driveshafts, not the conventional inter-axle differential. It was under a late 40's truck, either a 2-ton or maybe bigger. Jerry
Ignorance can be fixed; stupid is forever!
Top
#589693 - Wed Nov 04 2009 10:45 AM
[Re: Hotrod Lincoln]
Loc: B. C. Canada
Hy Guys, I believe that Chevy started offering factory tandems in 1956. They used a "power divider" behind the transmission, and two driveshafts from there back to the diffs. They mounted a pillow block on the forward diff which held the driveshaft to the rear diff in place, The two diffs were identical, and were the heaviest "corporate" diffs", not Eatons or Timkens. As to the tandem that showed up here last year, I bought it, it was in Oregon, and was an 8700 series.
Top
#589696 - Wed Nov 04 2009 10:49 AM
I believe 1956 was the first year Chevrolet had the twin screw tandem. The early tandems used a conventional 5 speed trans. followed by a combination auxiliary-power-divider type transmission with two rear drive shaft outputs. One drive shaft went to the front differential and the other went to the rear diff. It was quite complicated with several u-joints and many grease points involved. By 1960 Chevrolet had gone to the tandem setup that is now used, single driveline from back of the transmission through the power divider mounted in the front differential, short drive shaft between the rears and into the rear diff.
Jerry is right about most early tandems being a dead 'tag axle' type setup. Extra axles afforded more load capacity.
James
Top
#589700 - Wed Nov 04 2009 10:59 AM
[Re: oldiron57]
Apprentice
Loc: Charlotte,NC
The truck belongs to my Dad. He keeps it in Arizona. He spent a considerable amount of time and researching and restoring the 1956 Tandem. His efforts turned out fantastic. The truck was factory built and the tandem axles are "Genuine Chevrolet" as is the Allison 6 speed automatic tranny.
Top
#589855 - Wed Nov 04 2009 09:20 PM
[Re: Bill Marlow]
Loc: Virginia
Bhmotomach, that is a beautiful truck! You seldom see trucks of that vintage and that one looks perfect!
Red meat is not bad for you.........Fuzzy green meat is bad for you!
I know that you believe you understand what you think I said, But I am not sure you realize that what you heard is not what I meant!
1958 Chevy Spartan 100 firetruck in the Gallery
Top
#589941 - Thu Nov 05 2009 08:39 AM
[Re: Cannonball]
Loc: Ramarama
That is a fabulous truck indeed and I think it is in the Big Chev Trucks book I have. Still amazes me that it's the only one out there, I'd have more chance stumbling upon a parked up Big Tank Corvette or a COPO Camaro than a tandem with air and 348 big Chev truck.
Top
