The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Features | Search | Hoo-Ya Shop
Stovebolters Special
For new subscribers!
One year
Vintage Truck Magazine
for
$19.95
Regular price $29.95
Subscribe here
Discount Key Code: W07TSP
Who's Online
12 registered (Don G., 1953 panel, 54 3/4 dually, 46 Chev, backn37, 2 invisible), 10 Guests and 9 Spiders online.
Possibly Related Links:
Newest Members
toyjunk, SCcowboy, GUAGE, 67GmCBBv6, Neverdun
22007 Registered Users
Forum Stats
22007 Members
36 Forums
53853 Topics
Max Online: 180 @ Sun Mar 23 2008 10:37 AM
Image Posting Policy
Page 1 of 2 1 2 >
Topic Options
#589522 - Tue Nov 03 2009 08:38 PM 1940 Chevy T-5 Conv - Help with pedal mod
DelawareBolter Offline
Loc: Delaware
I have a 1940 half ton with 1954 235, hybrid T-5 installed with late model rear. Clutch install is completed. Now, unsure how to modify the pedal assembly to work with the T-5. It originally had the 3 speed which mounted the pedals to the bellhousing and side of transmission. The T-5 is wider than the 3 speed. The pedal bracket doesn't bolt up to the bellhousing. I assume we need to trim the boss’s off the transmission side of the pedal bracket. I also want to use a corvette dual master cylinder. Going with discs on the four corners. The pedal assembly will need to be modified to accept the corvette master cylinder. It appears the bracket will also need to be lengthened to get the needed clearance for the new master cylinder. The new master cylinder is wider than the original one. The bolt pattern of the new master cylinder is also different. I think it should also have additional bracing to support the weight and secure the entire pedal assembly. Somehow supported in part by way by the transmission. I don’t want the pedal bracket to break in an emergency braking situation.
I have a friend who is a GM mechanic working on this project for me. We did not want to begin hacking on the bracket until we had a tried and true plan. If we messed up this bracket we may trouble finding another. I was hoping that someone who has done the T-5 swap into a ‘39-46 would be willing to share their pedal bracket modifications with me. I would appreciate any pictures, diagrams, measurements, etc., anyone would have of their bracket.
Roland Warrington
Top
#589553 - Tue Nov 03 2009 09:20 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: DelawareBolter]
Scott Danforth Offline
Loc: Cheesehead in Paradise
in most cases, there is no "tried and true" path. Each combination of chassis, engine, trans, pedals, brakes, etc. is slightly different.
I myself will be switching to swing pedals with a bell crank and having the MC's under the cowl.
_________________________
Top
#589612 - Tue Nov 03 2009 11:22 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: Scott Danforth]
bigbadswingdaddy Offline
Loc: san francisco
larger deco trucks used a frame mounted master cylinder with a slightly different pedal configuration. The clutch and brake pedals still mount by the 3 holes on the bellhousing, however they are different from the 1/2 ton pedals. You can swap the pedal assembly and mount the MC on the frame away from the transmission
Top
#589617 - Tue Nov 03 2009 11:39 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: bigbadswingdaddy]
john romero Offline
Loc: west covina, california
if the original pedals mounted to the bellhousing make a new steel pedal bracket and weld it the the cast iron bellhousing
"THE CUT MASTER" 1949 SUBURBAN, 1947 ON D FLOOR FLEETMASTER,1954 DELUXE CAB, 54 CHEVY HARDTOP http://resurrectionvintageautoparts.webs.com/
Top
#589708 - Wed Nov 04 2009 11:36 AM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: john romero]
46forme Offline
Loc: Riverside, Ca
Roland, Here is what you need to do. You will need to grind down the mounting boss on the trans side, even with the mounting bracket. This is only true with the 3spd, the 4spd has no boss to worry about. The pedal bracket should now bolt up to the bell housing just like before. I didn't worry about the original mounting point that went into the side of the 3spd. Just make sure you use grade 8 bolts for the three mounting points into the bell housing this will be enough to hold the pedal assembly and the master cylinder. Check out John Sandoval's tech tip on the T5. Lots of good info there.
Now for the master cylinder. I used a dual master from a 69 mustang, which works real well. I had to fab a bracket to mount it but it isn't hard to do. I've got some pictures and a small write-up I can email you if you want it. Just shoot me an email and I'll get it to you.
George
gwells46@sbcglobal.net
Top
#589813 - Wed Nov 04 2009 07:30 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: 46forme]
Jeff Ogden Offline
Loc: Dayton Ohio
I had to cut off the part where it bolted to the 3 speed trans and I made a bracket to mount a modern master cylinder that bolted using the original master cylinder mounting holes.I then made a bracket to go from the rear original master cylinder mounting hole to a bolt that mounts the tailshaft housing on the T-5. I might have some pics of what I done.
Edited by Jeff Ogden (Wed Nov 04 2009 07:32 PM)
Edit Reason: spelling
1937 Chevy 1/2-ton pickup
Top
#591711 - Wed Nov 11 2009 03:34 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: Jeff Ogden]
Rob-Roy Offline
Apprentice
Loc: wilmington, nc
I cut off the two transmission mounting bosses to make clearance for the T5, but then found that the pedal assembly flexed quite a bit where it necks down at the bellhousing mount. I fixed that by running a 1/4" thick by 1" wide steel strap from the rear MC mounting bolt to the lower flange of the drivers side frame rail.
1938 HC half-ton - Buford
2006 Mustang - Pegasys
teardrop trailer & more pics of Buford
Top
#591780 - Wed Nov 11 2009 08:40 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: Rob-Roy]
Brian's40 Offline
Loc: Calgary Alberta Canada
If I could remember how to just give you the photos that you need, I would. Instead you will get the whole works. You will find what I did with my master cylinder and pedal mount. Glad to help if they are any use to you.
Brian
[url=HHP://community.webshots.com/user/Brians40?vhostcommunity][url=HHP://community.webshots.com/user/Brians40?vhostcommunity][url=HHP://community.webshots.com/user/Brians40?vhostcommunity]HHP://community.webshots.com/user/Brians40?vhostcommunity[/url][/url][/url]
Top
#591782 - Wed Nov 11 2009 08:42 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: Brian's40]
Brian's40 Offline
O.K. that didn't work. I'll find out how to do this again and I will resubmit.
Top
#591785 - Wed Nov 11 2009 08:58 PM Re: 1940 Chevy T-5 Conv - Help with pedal mod [Re: Brian's40]
Brian's40 Offline
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit
