22007 Members
36 Forums
53849 Topics
Max Online: 180 @ Sun Mar 23 2008 10:37 AM
#588266 - Fri Oct 30 2009 11:25 PM
Dashboard question
Apprentice
Loc: northern Illinois
I'm working on my 54 and was looking at removing the dash, hoping it would be easier to work on. Is that possible? I pulled the trim strip off that runs under the windshield and felt around but is seems like it's part of the firewall. Can you remove the dash without cutting?
_________________________
Brian Hill
Top
#588275 - Fri Oct 30 2009 11:57 PM
Re: Dashboard question
[Re: brihill18]
Loc: Oakwood, Ontario Canada
Not on my '53. The 54s are likely the same. I see your point about it being easier to work on, though.
Top
#588279 - Sat Oct 31 2009 12:08 AM
[Re: 1953 panel]
Loc: MARTINEZ,CA.
To remove the dashboard,it will have to be cut out. Sawzall, torch, air chizel,,etc......... Theyre spot welded in all the way around,and in some places welded solid. On a 54 if you remove the gauge cluster,speedo,heater and glove box youll have plenty of room to work under there. On 47-53 you can also remove the radio delete plate(or radio)and the speaker grille along with the above mentioned other parts for plenty of access. Have fun.......................
Top
#588586 - Sat Oct 31 2009 11:25 PM
[Re: delux54panel]
Apprentice
Yeah, thanks. 6'4" with big hands. Looking forward to it.
Brian Hill
Top
#589293 - Tue Nov 03 2009 03:46 AM
[Re: brihill18]
Apprentice
Loc: Port Orchard, WA. USA
Take out the seat or the rear window so you can put your feet through the window opening while your back is on the seat and your knees rest on the top of the seat back; your neck along the leading edge of the seat while your face is under the dash. Or find a youngster who is more limber and shorter...
Top
#589322 - Tue Nov 03 2009 08:17 AM
[Re: Doug9656]
Loc: houston
I rebuilt my gauge clusters last week, my neck is still sore from removing and replacing them. It's a job for a contortionist. Good luck
Top
#589332 - Tue Nov 03 2009 09:27 AM
[Re: geb]
Loc: colorado
The gauges were the last thing removed from my cab on dis-assembly and the first thing back in on reassembly. Remove all the rest of the truck and they will still be hard to get at.
Top
#589342 - Tue Nov 03 2009 09:53 AM
[Re: FriedGreenTmater]
Loc: Salt Lake City, Utah
One other way not mentioned here is you can remove the cowl vent and gain access that way. On 54 it actually works pretty good and you can reach in. You don't have to remove the arm only the vent if you want. The down side is the 5 small bolts often break if they have not been sprayed with penetrating oil the day before.It is also helpful to remove the seat and frame to do this job you get a lot more room. 47-53 guages have a 4 small nuts on each gauge, 54-55 has small pan nuts and only three on each gauge holding them in.
Edited by Brad Allen (Tue Nov 03 2009 09:54 AM)
Top
#589362 - Tue Nov 03 2009 11:43 AM
[Re: Brad Allen]
Loc: Castleton, NY
I don't this it has been mentioned above (but this mentioned in old posts on this subject), your back will appreciate the pedals being disconnected (if possible), so they can drop to the floor.
Tim
1954Advance-Design.com 1954 3106 Carryall Suburban - part of the family for 38 years 1954 3104 5-window pickup w/Hydra-Matic Z-series (54/55) GMC 350 (2-ton) COE
Top
