The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
21 registered (dgrinnan, Bruce W., 2-Ton, DennisM, 53 green 1- ton, 1Plowboy, 1 invisible), 287 Guests and 7 Spiders online.
Forum Stats
39,265 Registered Members
48 Forums
104,755 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
65 kid, mike in mo, ratmaster, ringgear
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#540325 - Sat May 23 2009 04:13 PM Tire time, can I put tubes in my radials?
Mr. Lang Offline
Loc: Brentwood Bay, BC Canada
Thats the question. I NEED to put my porta walls on my wheels. No, its not on the truck, its on my Pontiac. I have a set of portawalls for the car, but need to use tubes I think. The local tire shop says I can't, because my radials will chew the tubes up. They say that they can mount them without using tubes, they assure me they've done this before.... Now, how does the tire seal against the wheel, with the portawall jammed down there? I thought these had to use tubes.
Anyone have some experience with this stuff here?
_________________________
Christopher
Pictures in Photodork
1949 GMC Panel Truck
1926 Model TT Truck
Top
#540329 - Sat May 23 2009 04:24 PM Re: Tire time, can I put tubes in my radials? [Re: Mr. Lang]
truckernix Offline
Loc: Bracebridge Ontario Canada
I have only heard what you have said. Maybe you need a set of bead lockers. LOL
1951 1 Ton Completed
Top
#540332 - Sat May 23 2009 04:36 PM Re: Tire time, can I put tubes in my radials? [Re: truckernix]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
You can get special tubes for radial tires. It's been many years but it seems we used to put porto-walls on with tubeless tires.
1956 Chevy 1/2-Ton Pickup
Top
#540338 - Sat May 23 2009 05:06 PM Re: Tire time, can I put tubes in my radials? [Re: Wrenchbender Ret.]
WE b OLD Online
Loc: marion, in. usa
i have tubes in my Michelin x tires and they have been in there since august of 1969 yes 69 and no problem except one went flat last year and i put a new tube in.
Ron, The Computer Greek
I love therefore I am.
1960 MGA Roadster
1954 3100 Chevy truck in the Gallery
2015 GMC terrain.
Pix on Photobucket
Top
#540358 - Sat May 23 2009 07:24 PM Re: Tire time, can I put tubes in my radials? [Re: WE b OLD]
LGriffin Offline
Loc: Oakdale, CA
Many years ago I time and distanced rallied. Radial tubes were required in all tires. It was considered a safety issue. IIRC the radial tubes were a bit more expensive.
Larry
I don't own a vehicle that isn't old enough to drink.
Top
#540384 - Sat May 23 2009 09:11 PM Re: Tire time, can I put tubes in my radials? [Re: LGriffin]
terry Offline
Loc: nashville,TN,U.S.A.
Check with Coker Tire in Chattanooga Tenn, they can advise you and of course sell you what will work best.
GLTya
Terry
Top
#540418 - Sat May 23 2009 11:56 PM Re: Tire time, can I put tubes in my radials? [Re: terry]
waldo53 Offline
Loc: ID
I'm running a set of Port-a-walls on my tubeless tires with no tubes. Been on there for 3 years with no problems whatsoever. The port-a-wall mounting lip gives an air-tight seal between the tire bead and the rim.
Top
#540427 - Sun May 24 2009 01:11 AM Re: Tire time, can I put tubes in my radials? [Re: waldo53]
crenwelge Offline
Loc: Fredericksburg, Texas
Port-a-walls will work if you have rims with a wide enough sealing area. Most manufacturers went to a wider wheel designed for tubeless tires in about 1957. The earlier rims were not really designed for tubeless tires and with Port-a-walls it becomes even a greater risk. Port-a-walls were the big thing when I was in high school. If you have the older rims, I would recommend a tube designed for a radial tire.
Top
#540486 - Sun May 24 2009 10:48 AM Re: Tire time, can I put tubes in my radials? [Re: crenwelge]
Mr. Lang Offline
Well, I guess I'll take them to the tire shop in the next week or so. I always seem to have bad luck when I break down and hire something out.
Thanks.
Christopher
1926 Model TT Truck
Top
#540581 - Sun May 24 2009 07:45 PM Re: Tire time, can I put tubes in my radials? [Re: Mr. Lang]
LONGBOX55 Offline
Loc: DANVILLE IL
"Radial tubes" are meant to be used in tube type radial tires, not in tubeless tires. I have personally seen what happens when a tube is put in a tubeless tire, especially when they are run a highway speeds. The friction between the tube ans tire inner liner causes exsessive heat, which leads to sidewall and tube failure, usually within 100 miles at highway speeds.
It should also be noted that with current DOT regulations, it is illegal to install tubes in tubless tires. That is why most tire shops (including the one I work at) will not do it.
Bill Burmeister
Top
Page 1 of 2 1 2 >
Moderator:  cletis
