The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (TPR57C, tomctomc, Mickey3100, Organbuilder, greenie-reddy), 523 Guests and 4 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
New Reply
Topic Options
#530334 - Mon Apr 20 2009 09:38 AM Headers, and intake for 292
coal Offline
Loc: Montana
I,m interested in putting headers, and offy intake on my 292, I assume I will have to heat it with water for drivability, not sure whether a small 4 barrel, or should it run a 2 barrel. Also which headers would be the best, cast type, or tubular. It will be in my 65 k20 and may be used for some light hauling would I be better off with this cool setup, or just rebuilding it stock.
Thanks, Coal
Top
#530350 - Mon Apr 20 2009 10:26 AM Re: Headers, and intake for 292 [Re: coal]
Hot Rod Dad Offline
Loc: Taos, NM
Check out www.speedwaymotors.com They've got some header choices in both cast iron and tubular for the two different type of Stovebolt engines.
Cast iron is going to be more trouble-free and a lot quieter. Tubular is just plain noisier. It's not a bad sound, but they do make more noise. For that many cubic inches, I'd probably err toward a small cfm 4 barrel carb.
Top
#530931 - Tue Apr 21 2009 09:41 PM Re: setup Headers, and intake for 292 - 1951 [Re: carolines truck]
Roadmarks Offline
Loc: Raleigh NC USA
Hey coal,
Everybody has their own way of doing things, so take all these opinions with a grain of salt. I am going with the Offenhauser intake, A 390cfm Holley, and a set of long tubular headers. There is no way my ears can tell the difference between one type of header and another. I am also building my own cold air box to feed the Holley. More important than carb and headers will be switching out your old distributor for a '75 or later HEI! The HEI makes a huge difference in starting, idle, and overall performance.
Best wishes,
Les
_________________________
1956 Chevy Panel
1969 Chevy C20 Panel Truck
1971 Chevy C-10
More pix on Photobucket
"The Urban Home for Wayward Trucks"
Top
#531813 - Fri Apr 24 2009 04:33 PM Re: setup Headers, and intake for 292 - 1951 [Re: Roadmarks]
Arpee Offline
Loc: Box Elder, SD
Hi Coal - I did almost the same thing with my '64 C20. It was originally a 292 3 speed on the column. The motor was really tired so when we did the rebuild we used "propane" pistons, added a very mild cam, Clifford 4 bl intake and Hedman headers. (He's "Otis" in the Gallery.) We also changed the 3 speed to a 5 speed and it works great as a driver. We do tow a trailer with our '56 Chevy on it and it does OK - it works hard on hills or fighting strong winds. When we put the engine together I had a 465 cfm Holley carb that I figured would be pretty close to what it would need so thats what we ran it with. It ran OK but seemed a little weak at lower rpm and didn't seem to have "crisp" throttle response. The plugs looked really white but I was thinking maybe they were a heat range too hot. On a whim I tried a different carb. I had a box stock Edlebrock 600 which I figured would be too much for it but thought I'd see what it would do. I was amazed. It ran MUCH better - throttle response was better it would pull from low rpm better and the plugs were tan. I know that on paper that is way too big a carb for that engine - I also know the engine runs way better than it did with the smaller carb and the fuel mileage is the same. For what it's worth...
1964 Chevrolet C-20 Fleetside, Otis
1950 Chevy 1/2-Ton, Kirby
1950 Chevy 1/2-Ton Shortbed, Walter
Top
#532209 - Sat Apr 25 2009 09:59 PM Re: setup Headers, and intake for 292 - 1951 [Re: Arpee]
Oregoon Offline
Loc: Republic of Southeast Portlan...
Keep us updated. I'm going the same route eventually. My 292 is getting a rebuild later this year, and headers/intake are in the works.
Top
#534731 - Mon May 04 2009 10:24 AM Re: setup Headers, and intake for 292 - 1951 [Re: Oregoon]
carolines truck Offline
Loc: nor cal
Jim & Caroline
The highway is for gamblers
Better use your good sense."
Gooday
that's my 1ยข answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Lucinda Otter-Purr our 51-3104 bolt
http://s67.photobucket.com/albums/h298/1951otter/?start=all
Inliner #4655
Every Shaver
Now Can Snore
Six More Minutes
Than Before ...
Half A Pound for
Half a Dollar
Spread On Thin
Above the Collar
BURMA-SHAVE
Top
#535528 - Wed May 06 2009 10:57 PM Re: Headers, and intake for 292 [Re: coal]
coal Offline
Loc: Montana
appriciate all the advice and anymore that someone would what to lend!
Top
#540022 - Fri May 22 2009 11:12 AM Re: Headers, and intake for 292 [Re: coal]
Arpee Offline
Loc: Box Elder, SD
I know it goes against everything the "experts" say but I have a Clifford 4 barrel intake on the 292 in Otis ('64 C20, long box) and have never hooked up the water heat to the manifold. We live in South Dakota and don't drive him a lot in the dead of winter but in plenty of cold weather and have never had a problem. No explanation as to why but have run it for several years without a problem. For what it's worth...
Top
Moderator:  KCMongo
