The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
38 registered (agedhorse, Bills Auto Works, cletis, carbking, 42465967, 1 invisible), 537 Guests and 5 Spiders online.
Forum Stats
39,635 Registered Members
48 Forums
105,677 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
/NC\ TechY, brujones1, Daniel_Clark, doddi, Fla54Chevy3100, GeneWiseman, TylerLarson55
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#510742 - Thu Feb 26 2009 10:06 AM HELP! Gear lube oil for a T5 transmission?
3600Chevy Offline
Loc: Lawrence, Kansas
Help! I have been told to use anything from ATF to 80-90 gear lube to 10-40 motor oil. The transmission is a 1983 S-10 manual 5 speed or T5 and I have it in a 53 Chevy truck with a 261 engine.
Could somebody tell me what gear oil to use?
Top
#510749 - Thu Feb 26 2009 10:31 AM Re: HELP! Gear lube oil for a T5 transmission? [Re: 3600Chevy]
Barney 52 Offline
Loc: Sask Canada
I just rebuilt my son's 88 Trans am. 82-84, 80w-90 gl, 85-92 dexron. I think an s-10 would use the same.
_________________________
New deal for old steel
Top
#510782 - Thu Feb 26 2009 11:40 AM Re: HELP! Gear lube oil for a T5 transmission? [Re: Barney 52]
atomarc Offline
Loc: Eureka, CA
3600Chevy,
I rebuilt my sons T-5 in his S-10 pickup. I had the same question. There are two different transmissions, World Class (WC) and Non-World Class (NWC). They have different synchro sleeves I believe. One has brass and the other Kevlar.
According to the assembly manual, the NWC uses gear lube and the WC uses ATF. These lubricants are compatible with the synchro sleeve material.
On the other hand, if you read all the dope on the 'net', almost everyone uses ATF as the heavier gear lube causes the transmission to be stiff and difficult to shift, especially when cold.
ATF has one of the highest viscosity index ratings of any oil made, so whatever box you have, this oil would certainly not lead to its destruction.
Lots of folks on this site have installed this transmission in their trucks, so I'll bet you get some hands on advice in short order.
Stuart
Top
#510801 - Thu Feb 26 2009 12:43 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: atomarc]
Happy Birthday Fla54Chevy3100 Offline
Loc: Central Florida
After doing my homework and checking with several performance transmission builders....the recommendation was for 70w gear oil in a NWC T5 and ATF in the WC boxes. Based on that, I've been running 70w in my 85 NWC .72 OD T5. The transmission has shifted with no issues. At 3K I drained the box and filtered the oil in a search for any brass from the synchros.....the oil showed no evidence of any metallic residue. I'm currently at 8000 miles with no issues.
Stuart mentioned "stiffness" in shifting and on several mornings when the temps got down into the 30's and 40"s you can feel the extra resistance until the engine/tranny heats up. However, the T5 has never ground between shifts, even on the coldest mornings.
I recently picked up a NWC T5 (brass synchros) from behind a 305 cid Camaro which had been run on ATF. In draining the box and filtering for metallic residue I found none. In opening up the box to make the hybrid conversion I noted that the synchronizes showed no wear/damage.
So what oil am I going to run in this NWC brass synchro hybrid transmission? 70w synthetic gear oil. However, this is primarily because our normal temperatures are higher than average, and I'm going to be running it behind a more powerful engine. Do I think ATF will lead to premature failure in a brass synchro NWC transmission? I don't think so, although the performance transmission builders disagreed.
I'm sure there are some out there that are running ATF in their NWC T5's that will have insights to add. One thing absolutely for sure....if you're running the synthetic synchro/needle bearing WC T5, ATF is the way to go.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Top
#510955 - Thu Feb 26 2009 09:44 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: 3600Chevy]
28chevys Offline
Loc: colorado,usa
I running 10w-40 synthetic motor oil. My transmission rebuilder said it was best.
Top
#510993 - Thu Feb 26 2009 11:15 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: 28chevys]
6cylindersovertexas Offline
Loc: Beautiful Uptown Hurst, TX, on...
I think the longer this post is up on the board, the longer you will get opinions on what to run in the T-5 tranny you have. Here is my two cents.
I'm running a 85-86 S-10 T-5. When I wanted to find out what to run in it, I came to this board and at that ime I never could get a definitive answer - like this thread. I decided to go to eBay and by an Owner's Manual for an 85 S-10 Blazer and see what the manual said. It said ATF Dexron III which is now Dexron IV.
Case closed.
See Joe Fuchs' 1937 Chevrolet 1/2 Ton Pick Up on Facebook at The Top Of My Page. Go to: Joe Fuchs on Facebook
Top
#511092 - Fri Feb 27 2009 09:06 AM Re: HELP! Gear lube oil for a T5 transmission? [Re: 6cylindersovertexas]
3600Chevy Offline
After all the recommendations and the additional research on the internet I have decided to use 70w gear lube. Which has the same viscosity of 5-30 motor oil but will not break down as quickly as motor oil. ATF is thin, works well at low temps, and is good for a slight decrease in drag [better economy]. But I think the 70w gear oil would be better for shifting and wear.
Thank you all for your advise.
Top
#513579 - Thu Mar 05 2009 01:32 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: 3600Chevy]
I just had a conversation with Corey Crump at Standard Transmission in Fort Worth. Standard has been in business for a many years and they set up at most all of our local swap meets. They are representatives for Hurst Performance and work on and carry a complete lines of transmissions and parts including the Tremac and all of the Borg Warner transmissions, including the T-5's we use.
I asked Corey what oil or grease they recommend as a lubricant for the T-5. He told me definitely ATF because the construction passages and tolerances are so close on the T-5 that oil of any weight will just not flow into these passages to lubricate the transmission. I questioned him about gear oil and he said "No!"
Everytime I get into this conversation, I always end up with the same answer and I would recommend that those of you who refuse to accept ATF as being correct for your T-5 rethink your approach to these transmissions and use what is recommended by the peole who build them, use them and rebuild them.
Top
#513656 - Thu Mar 05 2009 04:20 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: 6cylindersovertexas]
LONGBOX55 Offline
Loc: DANVILLE IL
ATF is the correct ;ube. I have the '85 S 10 manual handy (seeing as I own an S 10), it says ATF. The lube spec books at work say the same thing for all applications of the T5, exept for the '87 Firebird/Camaro, which calls for gear oil.
Bill Burmeister
Top
#513681 - Thu Mar 05 2009 06:11 PM Re: HELP! Gear lube oil for a T5 transmission? [Re: LONGBOX55]
waldo53 Offline
Loc: ID
Ditto on the ATF. My T-5 is an '89 NWC and after listening to differing opinions from all the "experts" I decided to go to the "horses mouth" as they say, the owners manual. Sure 'nuff, right there it says ATF. You can find a lot of these manuals at your friendly corner library.
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
