The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
36 registered (1953 panel, 40_chevy, 2ton46, '54 3600, 2-Ton, 3B, 2 invisible), 570 Guests and 4 Spiders online.
Forum Stats
39,407 Registered Members
48 Forums
105,407 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
19chevy38, BF Finster, BigBambino22, crcmk7w, dmtexas, jay smith, Jim Williams 7w, Kevin W. Johnson, Noe_swede, pablos49
Image Posting Policy
Page 2 of 3 < 1 2 3 >
New Reply
Topic Options
#456802 - Sun Sep 28 2008 09:58 PM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
53flatbed Offline
Loc: Ridgeway, Virginia
i checked on 16.5 prices for tires and they are reallly high plus they will be 8-10 bi-ply rough ride, so i think the 16 inch would be better
_________________________
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
Top
#456895 - Mon Sep 29 2008 08:16 AM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
Brad Allen Offline
Loc: Salt Lake City, Utah
I purchased 1991 8-lug Chevy Suburban wheels in 16" for my truck be warned they will not clear the old style tie-rod ends (I have built my own pitman arm and modified my suspension to clear). In Salt Lake City there is a guy that deals in only used wheels and was really helpful in locating a matched set and in fitting applications. Don't know if you have that type of service available where you live but he was out near a large number of junkyards and knew wheels! He had also suggested and knew of the Dodge/Ford wheels that fit there just wasn't any available at the time I needed to get my truck moving. I think there is also a thread on the difficulty some people have had with the 16.5 applications sounds like in some areas they are difficult to find and expensive.
Top
#457097 - Mon Sep 29 2008 07:43 PM Re: what late model wheels will fit a 8 lug 53 chevy [Re: Brad Allen]
53flatbed Offline
i found some 2000 dodge ram 2500 wheels with the following specs,
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x6.5"
Offset - 4.75"
is the bolt size and offset ok?
Top
#457112 - Mon Sep 29 2008 08:09 PM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
Grigg Offline
Loc: Lexington, VA
Do you have one of your original wheels?
What do they measure?
How to they compare to the new wheels you are looking at?
Even with measuring it would be best to test fit the actual wheel before you commit to buy.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Top
#457250 - Tue Sep 30 2008 07:59 AM Re: what late model wheels will fit a 8 lug 53 chevy [Re: Grigg]
Ghostrider Offline
Loc: Binghamton, NY
It's not likely those 6.5" wide rims will fit without a spacer.
You need to get under the front of your truck with a tape measure to see what you've got to work with.
Steve
'49 3800
'52 3600
Top
#457741 - Wed Oct 01 2008 07:38 PM Re: what late model wheels will fit a 8 lug 53 chevy [Re: Ghostrider]
53flatbed Offline
well you were right. the rear wheel fit okay, the front, the tie rod end is hitting, these are inset about 1" to much, I just need to get a pair of spacers or adapters., the wheels are gona look really good. i polished them and they look like new money.
Edited by 53flatbed (Fri Oct 03 2008 06:04 PM)
Top
#889339 - Sun Oct 14 2012 10:24 AM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
Greg & Ginger Offline
Loc: Texas
I found 16x6 8 lug rims of a Dodge Van, just not sure of the offset. The listing was for 16x6, 8 lug, 6 1/2, what's the 6 1/2?
Greg & Ginger
1953 Chevy 3600
Top
#889342 - Sun Oct 14 2012 10:40 AM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
LONGBOX55 Offline
Loc: DANVILLE IL
The 6 1/2 is the size of the bolt pattern.
Bill Burmeister
Top
#889346 - Sun Oct 14 2012 10:59 AM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
DMGfifty Offline
Loc: Oregon Coast
I went with new steel wheels. They are made by dexstar and even powder coated on BOTH sides. Less then $50 each. I thought that was a great deal. They are well made, balanced out great and made in USA!
wheels
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Top
#889361 - Sun Oct 14 2012 12:18 PM Re: what late model wheels will fit a 8 lug 53 chevy [Re: 53flatbed]
JiMerit Boltr#43 Offline
Loc: olTruck(Turlock), CA
I've been through this ordeal with my 53, found lots of rims that bolted on but there were several issues that made this swap a bit complicated. I had a few modern 8 lug rims in the shop that would bolt on but only one had a large enough center that would allow my big 3/4 ton caps to fit and those were 16" off a Ford Econoline (these Ford rims have a really small Ford oval logo stamped on the rim hard to see). All makes seamed to hit the tie rod, then I learned that the 1 ton tie rod had modern ends and it's a bolt-on swap. A better fit but still needed to do a bit of grinding on this new end to make it clear the rim. Once the Fords were mounted and fitting fine I added aftermarket hub cap clips from Chevs of the 40s, holds the big caps just fine. Another problem when fitting the original caps is on the back where the large hub sticks out to far to let the caps fit, cured this with a spacer, moving the rim out just enough.
1946 1/2-Ton Chevy
Top
Moderator:  53moneypit, Woogeroo
