The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (tomctomc, 4D62ton, 29tons, thet904, bajones238), 471 Guests and 4 Spiders online.
Forum Stats
39,649 Registered Members
48 Forums
105,745 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
58chevrolet, 5isGood, Jake Van Vliet, Meo61, MyClean54, radarlover, rbarnes
Image Posting Policy
New Reply
Topic Options
#444087 - Thu Aug 21 2008 12:08 PM 250 with integral manifold
jfnar Offline
Loc: Arkansas
I've done a search and found conflicting info. Hopefully someone can clear this up. I have a 250 with the integral manifold. Can I change the head with an older one that has separate intake manifold? Some posts say yes and some say it can't be done. Has anyone done this? Thanks.
_________________________
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Top
#444095 - Thu Aug 21 2008 12:36 PM Re: 250 with integral manifold [Re: jfnar]
Lonnie Gallaher Offline
Loc: San Bernardino, Ca, USA
Reliable sources state that the earlier head will interchange.
54 Chevy build pics.
Top
#444108 - Thu Aug 21 2008 12:59 PM Re: 250 with integral manifold [Re: Lonnie Gallaher]
Hotrod Lincoln Offline
Loc: Dellrose, TN
Yes, and it's done all the time. The integral-manifold head is only good as an anchor for a small to medium-sized boat, or maybe a big doorstop.
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#444586 - Fri Aug 22 2008 10:43 AM Re: 250 with integral manifold [Re: ]
Joe H Offline
Loc: Lee's Summit Mo. 64086
The exhaust on the integral head has two outlets doesn't it? That will be the only difference.
The early heads are all the same so look for any 230,250,292. The real early 194's have a smaller combustion chamber and will bump the compression up to approx. 9 to 1. They are hard to come by but worth a look if you are in a older yard. The 292's use bigger exhaust manifold outlets, 2.5" instead of 2.25", and can be identified by the three bolt outlet. The smaller outlet only uses two bolts.
There is no difference in the main head, so really the first one that looks good should be fine.
You can always have bigger valves put in when getting a valve job, small block Chevy valves go right in and are pretty cheap to buy.
Joe
1937 Chevrolet Inline-powered Streetrod
Top
Moderator:  53moneypit, Woogeroo
