The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (jacksont, Super55, 1 invisible), 433 Guests and 5 Spiders online.
Forum Stats
39,267 Registered Members
48 Forums
104,774 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
1 Dollar, aerotruk63, GTA Scott, mb53, Norman Meloche, pauldumont, rscott, steven simpson, thor
Image Posting Policy
New Reply
Topic Options
#419920 - Wed Jun 04 2008 03:55 PM Starting an engine after sitting for 20 years
46 HalfTon Offline
Loc: Ontario Canada
I am restoring a 1946 chev 1/2 ton which has a 1957 235 in it. This engine has not been running for 20+ years. What checks and preparations should I do before I crank it over to assure nothing will break or blow up when I crank it over. The engine turns easily and I took off the oil pan and valve cover and the engine is nice and wet on both ends.
_________________________
1946 Chevy Half-ton
More pix on Flickr
Top
#419934 - Wed Jun 04 2008 04:50 PM Re: Starting an engine after sitting for 20 years [Re: 46 HalfTon]
speed 6351 Offline
Loc: Elko, Nv.
You should start by checking the valve adjustments,remove the carb and clean it out good,maybe install a rebuild kit,test the fuel pump function to be sure the diaphragm isn't cracked,if the plugs and or wires look less than great,replace 'em,same for the cap and rotor,check the points condition and adjustment,I'd replace the thermostat and give it fresh antifreeze just for safety sake,make sure you get fresh gas to the engine,whether that means draining,cleaning,and re-filling the tank or bypassing it to pull gas from a temporary tank,if the fanbelt's not in good shape,now's the time to change it,make sure your battery connections are clean and tight,if you have the facilities for it,pull the distributor and "pre-lube" the engine with a dummy shaft and a drill.(This is kind of a project in itself,but if the engine hasn't been cranked more that a couple of revolutions for 20 years,the bearings and seals are probably dry. Starting it up this way could damage the bearing surfaces. Some of this is a judgement call;(i.e.if you know for a fact the engine last ran perfectly,you can probably skip the valve adjustments,maybe the plugs-you see where I'm going with this? Assuming the engine is known to be in good condition and was in proper tune when parked,the bare minimums it needs to run again are fresh gas,good spark,good electrical connections and good battery,clean oil,good coolant mixed at 50/50 ratio. With these things,it should start,run,and live a long life.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Top
#419935 - Wed Jun 04 2008 04:51 PM Re: Starting an engine after sitting for 20 years [Re: speed 6351]
speed 6351 Offline
Loc: Elko, Nv.
AND,BTW--Welcome to the 'Bolt!!
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
Top
#419984 - Wed Jun 04 2008 07:18 PM Re: Starting an engine after sitting for 20 years [Re: 46 HalfTon]
Tiny Offline
Loc: South Central Kansas
Disassemble & clean the carb. Replace or rebuild the fuel pump. Change the oil. Pull the plugs so it isn't too hard on the starter, pull the valve cover & disconnect the rocker oil line and crank the engine long enough to get oil to the rockers (10-15 sec.). This verifies the oil pump is working and the line to the rockers isn't blocked. Reconnect the rocker oil line & reinstall the plugs. Using a remote gas source such as a lawnmower tank connected to the fuel pump, start the engine. Let it warm up. Once warm shut it off & check/set your valve lash. Change the oil again.
I can't stress enough to NOT put gas into, or run your engine on gas out of, the original tank until it's completely cleaned of all traces of old gas. Good luck.
Sweetie Before
Sweetie Now
Sweetie In Skirts
Top
#420176 - Thu Jun 05 2008 09:27 AM Re: Starting an engine after sitting for 20 years [Re: Tiny]
46 HalfTon Offline
Loc: Ontario Canada
Thanks a lot for all your help!
Fan belt replaced
Carb cleaned, rebuilt and professionally adjusted
All plugs, wires, distributer, points, condensor replaced
Gas tank is sitting on the garage floor under the truck...was going to use a temp supply
Oil pan has been removed, cleaned out and replaced
Oil pump screen has been removed cleaned and replaced
My one question is the oil supply to the rocker arms and valves comes out of the head and it curved around the rocker arm shaft and pointed down towards the head again. Right at the bend in it above the rocker shaft there is a notch cut out of the inside of the bend and the line is pinched there. It doesn't look as though it is pinched closed but definitly pinched a great deal. Is this supposed to be like this?
Thank you for the welcome and your great amount of help!
1946 Chevy Half-ton
More pix on Flickr
Top
#420178 - Thu Jun 05 2008 09:28 AM Re: Starting an engine after sitting for 20 years [Re: 46 HalfTon]
46 HalfTon Offline
Loc: Ontario Canada
Speed 6351,
Do you have the 235 in your 57 GMC 1/2 ton?
1946 Chevy Half-ton
More pix on Flickr
Top
#420226 - Thu Jun 05 2008 01:00 PM Re: Starting an engine after sitting for 20 years [Re: 46 HalfTon]
Tiny Offline
The oil line should be connected to a fitting that rests between the rocker shafts. The oil feeds into this fitting then into the rocker shafts. On my 38 it's held in place by spring tension. Once the rockers shafts are full of oil the "excess" exits via a hole in the oil line and/or the notch in the top of the line above the fitting. Some folks tried to increase oil pressure to the rockers by crimping the line shut. As long as the oil line is connected to the fitting & the fitting is connected to the shafts you should be good to go.
Sweetie Before
Sweetie Now
Sweetie In Skirts
Top
Moderator:  53moneypit, Woogeroo
