The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
61 registered (49nut, 5 Window 9434, 3B, 48bigtrucks, 1953 panel, 3 invisible), 681 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,693 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#410027 - Mon May 05 2008 04:57 PM 302 GMC AC Delco duel point distributor
cessna195 Offline
Apprentice
Loc: San Diego CA
I am in the process of installing a 302 GMC in my 1952 Chevy truck and just noticed that it has an AC Delco duel point distributor in it. Is this distributor stock or was it a high performance option you could get at the time. The distributor has an AC Delco metal tag on just like the distributor on the 235 Chevy engine that I took out of the truck but with a different part number. The distributor cap is also different (taller) and so is the rotor from the 235 distributor. What are the part numbers for the points, distributor cap and rotor if they need to be replaced? Also what is a dwell for a duel point distributor? Thanks for your help.
Top
#410061 - Mon May 05 2008 06:13 PM Re: 302 GMC AC Delco duel point distributor [Re: cessna195]
4ontheFloor Offline
Loc: Forest Grove, OR
I'm guessing it has one of the dual point conversion plates in it that fit both the 235 and the 302 distributor. These do not use the same points as original, and they have to move the condenser to the outside of the distributor. It would be easiest to take the points out and take them to a parts counter to match them. The other possibility is that it is a corvette 235 distributor.
I have one of these plates in my 261. I usually set it so it has 10 more degrees of dwell than stock, and the way to set it is to first block the leading points (the ones that open& close first) open with a piece of paper, then set the timing and dwell to stock using the trailing points. Then remove the paper and adjust the gap of the leading points to make the dwell come out to around 43-45. The ignition fires whenever both the points are open.
Edited by 4ontheFloor (Mon May 05 2008 06:14 PM)
_________________________
Paint & Body Shop moderator
Top
#410262 - Tue May 06 2008 08:18 AM Re: 302 GMC AC Delco duel point distributor [Re: 4ontheFloor]
cessna195 Offline
Apprentice
Loc: San Diego CA
4ontheFloor,
Thanks for the reply.
Top
#410275 - Tue May 06 2008 08:49 AM Re: 302 GMC AC Delco duel point distributor [Re: 4ontheFloor]
cessna195 Offline
Apprentice
Loc: San Diego CA
4ontheFloor,
I was just thinking. Would the box like covers over the points on my distributor be for radio suppression that would be required on a Corvette?
Top
#410329 - Tue May 06 2008 12:03 PM Re: 302 GMC AC Delco duel point distributor [Re: cessna195]
Harvester Offline
Loc: Tucson, Arizona
C195, I don't see any reason for extra shielding with an external ignition condensor. Corvettes needed the ignition shielding because of the fiberglass body. You have plenty of ferrous metal in your truck to provide radio noise suppression. Just keep the hood closed when you are listening to the radio with the engine running. If you have ignition noise in the radio, you might have to use resistor spark plug wires, or resistor spark plugs, but not both. I don't recall any particular radio trouble in the old vehicles that had metallic spark plug wires. I think resistor wire/resistor spark plug use was more to prevent interference with radio receivers located away from the vehicle.
Harvester
Top
#410512 - Tue May 06 2008 10:31 PM Re: 302 GMC AC Delco duel point distributor [Re: Harvester]
4ontheFloor Offline
The stock radios shipped with a ignition capacitor and one for the generator. Make sure there is a points condenser either inside the distributor or outside before you go assuming the one on the coil is for the radio- you need one in the circuit somewhere, and with two sets of points there isn't enough room in the dist. body for a condenser.
Could you post a picture? Mine doesn't have covers over the points. You may indeed have a vette distributor.
Top
#410593 - Wed May 07 2008 08:07 AM Re: 302 GMC AC Delco duel point distributor [Re: 4ontheFloor]
cessna195 Offline
Apprentice
Loc: San Diego CA
I will try to post a photo this weekend. The distributor has a points condenser mounted on the put side common to the distributor cap spring clamp fastener.
Top
#410642 - Wed May 07 2008 11:44 AM Re: 302 GMC AC Delco duel point distributor [Re: cessna195]
Harvester Offline
C195, the additional ignition capacitor for radio noise supression goes on the coil positive terminal- and one on the generator armature terminal, as 4onthefloor mentioned. Those capacitors are slightly larger than the igniton capacitor at the points. I think the noise supressor capacitors are in the range of .47-.5 mfd. Delco igniton capacitors/condensors are .18-.23 mfd, more or less matched to the ignition coil. Don't connect a second radio capacitor at the points/coil negative terminal, or you will have an over-capacity condition for the ignition system that will cause severe metal transfer on the points- from the breaker arm contact to the fixed contact.
Harvester
Top
#410695 - Wed May 07 2008 03:20 PM Re: 302 GMC AC Delco duel point distributor [Re: Harvester]
cessna195 Offline
Apprentice
Loc: San Diego CA
Harvester,
The points condenser that I am talking about is attached to the outside of the distributor and the lead is attached to the input terminal where the wire from the neg. side of the coil is attached to that in turn goes to the points. There is no room for the condenser inside the distributor under the distributor cap.
Top
#410698 - Wed May 07 2008 03:33 PM Re: 302 GMC AC Delco duel point distributor [Re: cessna195]
atomarc Offline
Loc: Eureka, CA
No self respecting hot rodder could miss a Mallory dual point distributor setup. I had one in '64. smile
http://www.speedwaymotors.com/pl/393,6905_Chevy-6-Cylinder-Dual-Point-Distributor.html
Stuart
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
