The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
63 registered (49 3100, 1953 panel, 51cowboy, 2-Ton, 3B, 42465967, 2 invisible), 575 Guests and 4 Spiders online.
Forum Stats
39,395 Registered Members
48 Forums
105,329 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
48silverado, Anthony M, Big Tike, brown12202, CRexRun, Jim Meier, jkully, kruisin53, paul 49, shaxinator, Steven T, ultimatezlover
Image Posting Policy
New Reply
Topic Options
#403014 - Wed Apr 16 2008 12:35 PM Help me identify Turbo 350 Tranny
Achipmunk Online
Loc: Boiling Springs, S. C. 29316
I've got a 350 automatic tranny that I would like to know what year model it is. (if it is indeed a 350 as i was told.
I can't find any numbers on it except for a stamping which is "13" with a "T" underneath it on both sides of the tranny. The only real number I could find was the one on the short tail shaft wich is 8640326, as best as I can make out and its probably the casting # just for that piece.
The bottom pan is NOT square. The back passenger side corner is cut at an angle and the back edge of the pan has a "slant/bevel" to it. Can anyone help me know what I have??
I'm probably dreaming but was hoping it could possible be one of the 350's with lockup. HELP, before I hook it to my engine and drop it in the chassis.
_________________________
Pictures in my Photobucket
Top
#403060 - Wed Apr 16 2008 03:04 PM Re: Help me identify Turbo 350 Tranny [Re: Achipmunk]
Hotrod Lincoln Online
Loc: Dellrose, TN
There is a very simple way to identify the 350C, which is the lockup version. There will be an electrical connector above, and just to the rear of the manual shift linkage on the driver's side of the transmission, and the input shaft where the torque converter slips on will be hollow, with an "O" ring in a groove about 1/4" back from the front end of the shaft. Standard 350's do not have the O ring, and the input shaft is solid. The pan shape you're describing fits both 350's and the "C" model lockup type. If it looks like a 350, but does not have a vacuum modulator, just a TV cable, you've got a Turbo 250.
What would a bulldog cross-bred with a Shi Tzu be called?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#403113 - Wed Apr 16 2008 05:46 PM Re: Help me identify Turbo 350 Tranny [Re: Hotrod Lincoln]
jockbolter50 Offline
Loc: Scotland
The numbers you are looking for should be stamped on the 'pan' itself, assuming it's got it's original pan and it's a Chevy 350.
Buick also built TH350's .There should be a 6 digit # on the right vertical face of the pan.
If you can find these #. Post them and I'll see if I can decipher them for you! As 'Hotrod' said 350c's have a connector just near the shift linkage.
Jock. thumbs_up
You may also find marks on the bellhousing. Usually 1# and 2 letters.
Edited by jockbolter50 (Wed Apr 16 2008 05:53 PM)
More pix on Flickr .
Top
#403289 - Wed Apr 16 2008 10:27 PM Re: Help me identify Turbo 350 Tranny [Re: jockbolter50]
Achipmunk Online
HotRodLincoln: how stupid of me....Duhhh! I put a 700R4 in my 37 and know about the electrical connector! It is NOT a lock up.
It has the tv cable AND the vacumn modulator so I guess its just a plain 350.
Jock, I rolled it over as far as I could without the fluid running everywhere and the bottom of the pan is dirty and rusty. Tomorrow morning I will try clean it off and see if I can find any numbers. I absolutely couldn't find any numbers anywhere on the bellhousing.
Thanks for taking the time to respond guys and I will look on the bottom of the pan tomorrow and get back to you.
Top
#403344 - Thu Apr 17 2008 02:20 AM Re: Help me identify Turbo 350 Tranny [Re: Achipmunk]
Loc: Scotland
It's just amazing how a 'small' amount of ATF can spread out to look like a Major Eco disaster!! eek I've still got the stains on my garage floor!
It's 7:15am here so I guess i'd better get ready for work!
Catch up with you later. Jock.
P.S. The bellhousing marks were usually an Ink stamp or a self adhesive label. Not much chance of them surviving under a car/truck for 15/20 years! grin
Top
#403366 - Thu Apr 17 2008 07:55 AM Re: Help me identify Turbo 350 Tranny [Re: jockbolter50]
TC's Truck Parts Offline
Loc: 7154 Creek Rd. Hazelhurst, Wi....
The th350 pan is as you described - it has the angle in it. Also the vacuum modulator is on the back of the case, not like a 400 which is on the side. A th350 lockup has a square female electrical plug on the side which a normal 350 doesn't.
Top
#405201 - Mon Apr 21 2008 10:21 PM Re: Help me identify Turbo 350 Tranny [Re: TC's Truck Parts]
Achipmunk Online
Thanks guys. I finally got out to the shop Saturday and cleaned it up real good.
jockbolter50: no numbers on the pan. It appears I have just a plain jane turbo 350 tanny. No lockout, modulator on the back and no electrical plug.
I'm gonna use it anyway!! It was working good in the previous truck. I was just hoping it was something else! I may go by the "tranny man" who is a friend of mine and see what he has laying around. I want to "do it once, do it right" kind of thing and just don't think the regular 350 tranny is right for the panel and especially since I'm running a 3:90 rear gear out of a 55 /56 pickup in the 52 housing.
Any comments from you guys appreciated as I do not know all the gear ratio lingo for "final gear" by figuring out the tranny ratio to the rear end to get the "final road ratio".
Its late. Am I making any sense?
Top
#405216 - Mon Apr 21 2008 10:46 PM Re: Help me identify Turbo 350 Tranny [Re: Achipmunk]
Loc: Dellrose, TN
High gear on the TH 350 is 1:1, just like top gear in a 3-speed standard trans. The only gear ratio involved in highway travel will be the rear axle ratio, with top speed determined by engine RPM and tire size.
The automatic trans will have better acceleration from a stop than a standard shift, because the torque converter doubles the engine torque just before the vehicle starts to move.
Top
Moderator:  53moneypit, Woogeroo
