The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (tomctomc, 4D62ton, 29tons, thet904, bajones238), 471 Guests and 4 Spiders online.
Forum Stats
39,649 Registered Members
48 Forums
105,745 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
58chevrolet, 5isGood, Jake Van Vliet, Meo61, MyClean54, radarlover, rbarnes
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#364391 - Tue Jan 22 2008 08:30 PM 235 timing mark
philip t Offline
Loc: central nc
i put a hei dist. in my 46 this weekend the engine.it is a 52 235
i pulled the valve cover and plugs bumped the engine over until the intake valve closed, turned the motor with the fan looking through the spark plug hole until at tdc. the rotor was pointing at number one. i put in the hei and it fired up. now comes the weird part
i could not find the timing mark with the light so i stoped put number one back on tdc of the compression stroke crawled under pulled the dust cover and the steel ball on the fly wheel is 180
from the pointer. why?
Top
#364482 - Tue Jan 22 2008 10:30 PM Re: 235 timing mark [Re: philip t]
Jim Meier Offline
Loc: NW Ohio
Is this a trick question?
The steel ball is not 180 out, your distributor is.
Each cylinder hits TDC twice for one revolution of the crank.
The distributor turns at half the speed of the crankshaft.
If the steel ball is 180 out from the pointer you are in the number 6 cylinder firing position.
Top
#364509 - Tue Jan 22 2008 11:27 PM Re: 235 timing mark [Re: Jim Meier]
rustednuts Offline
Loc: Kingston, WA
If its a concern either pull and rotate the dizzy 180 degrees or swap the plug wires at the cap by rotating them out 3 plug positions over.
Jeff
_________________________
Hey guys, hows the weather? grin
Lifes to short to worry about how short life is.
1951 Oldsmobile Super 88 w/303 and hydramatic
My 1953 Chevrolet
1947.1 GMC Art Deco COE / 1947.1 Gallery
Top
#364516 - Tue Jan 22 2008 11:44 PM Re: 235 timing mark [Re: rustednuts]
atomarc Offline
Loc: Eureka, CA
philipdltx18,
I'm confused. The flywheel is keyed to the crank. If you had #1 at TDC and the pointer on the ball...and the truck started and ran, then all is as it should be.
As Jim Meier noted, things can be 180&deg out, BUT, the truck wouldn't start! You said it started, so it isn't 180&deg out!
Why isn't the ball where it's suppose to be..I don't know. Some important fact has been overlooked. When you put a light on #1 plug wire, the ball must light up, that's the only way this engine operates.
Stuart
Top
#364695 - Wed Jan 23 2008 11:58 AM Re: 235 timing mark [Re: philip t]
philip t Offline
Loc: central nc
i hear what you are saying jim but the piston only comes to tdc
on the compression stroke once. i rotated the engine until the intake valve closed then brought the piston up to tdc on 1 put in the dizzy the engine will run as it should but the ball on the flywheel is off
Top
#364700 - Wed Jan 23 2008 12:10 PM Re: 235 timing mark [Re: philip t]
atomarc Offline
Loc: Eureka, CA
I think there are several options here. You are looking at the incorrect mark on the flywheel, someone has altered the position of the flywheel on the crank (highly unlikely) or you are not clear on what you are seeing or the procedure you are using.
Keep us posted on this brain teaser!
Stuart
Top
#364737 - Wed Jan 23 2008 01:26 PM Re: 235 timing mark [Re: atomarc]
Jim Meier Offline
Loc: NW Ohio
Philipdltx18,
I'm sorry, I'm sorry, I'm sorry. I gave out some bum information.
Earlier in the afternoon I had a root canal and thought the pain killers had wore off. I guess they hadn't.
The pistons hit TDC twice for every revolution of the distributor. The crank will have rotated twice for every rotation of the distributor.
This means that when the steel ball lines up with the pointer it is either on or 180 out. You are static timing it right by watching when the intake valve closes.
I had a similar problem when I put my 235 back together. What I finally ended up doing was watching when the intake valve closed,
then continued to rotate the engine until the ball lined up with the pointer. Then I set the distributor to fire on number 1 cylinder.
Then I followed up by using a timing light when the engine was running to rock in the timing adjustment.
Top
#364885 - Wed Jan 23 2008 06:16 PM Re: 235 timing mark [Re: Jim Meier]
tclederman Offline
Loc: Jarvisburg, NC
Is it possible that some 235 clutch housings (car, maybe) had the timing hole on the carburetor/steering side of the engine (the flywheel would then be marked differently)? My question is probably ridiculous?
Top
#364924 - Wed Jan 23 2008 08:36 PM Re: 235 timing mark [Re: tclederman]
atomarc Offline
Loc: Eureka, CA
Tim,
I had a '54 Chevy car with a 235 and its peep hole for timing was on the conventional side...above the starter.
The ball is ALWAYS on the pointer when #1 is TDC. It might be TDC on exhaust or it might be TDC on compression, but the ball will always be on the pointer.
This wouldn't apply is someone mechanically altered the location of the flywheel to the crank, but there would be no reason to do this that I can think of...unless someone wanted to use a fresh section of ring gear and went through the trouble of drilling some new holes in the flywheel. I guess stranger things have happened huh!
Stuart
Top
#364956 - Wed Jan 23 2008 09:33 PM Re: 235 timing mark [Re: atomarc]
48bigtrucks Offline
Loc: Center Point, Iowa
Dumb question, are you turning the engine over in the correct direction while watching the intake valve close?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
