The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
46 registered (52Carl, 1953 panel, 51cowboy, 49nut, ApacheFiend, 57chevy2ton, 2 invisible), 616 Guests and 5 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,762 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
New Reply
Topic Options
#346507 - Sat Dec 08 2007 10:49 PM Chevy Intake Manifold Casting Number Look Up?
Rusty Bucket Offline
Apprentice
Loc: Berkeley, California
My 1959 Apache has a rebuilt 283 (casting # 3737739 mfg. between 1958-1964)with a Iskenderian 3/4 racing cam and a quadrajet carb instead of the origninal Rochester 4G. Also added on four-pipe exhaust headers and dual exhaust. Anyway, the intake manifold has a casting number of 8876864 w/ "GM1" below it. Where can I look up the info on this intake manifold? Couldn't find anything in archives or the Jim Carter Chevy on-line parts book.
Also, if you know, would it be OK to replace the four-pipe exhaust headers and leave everything else as is? Doesn't seem like the volume of exhaust output would be much different, but what do I know?
Thanks.
_________________________
Gregg
1959 Chevy Apache 3100
Top
#346525 - Sat Dec 08 2007 11:44 PM Re: Chevy Intake Manifold Casting Number Look Up? [Re: Rusty Bucket]
Flxible Offline
Boltergeist
Loc: north of the 49th
my book shows 3737739 as 58-61, truck or car, and that's the most desireable block - may be original to the truck, if your vin starts with a V
the intake casting numbers don't mean a lot - same number may have been machined differently for different applications - should have a date code on it tho' that'll maybe tell if it's original to the engine, "letter[month]/2numbers[day]/one number[year]" ... might have to guess if 5 or 6 is 50s, 60s, 70s
yes, you can return to the original style ramshorn exhaust manifolds, they breathe pretty well - could also do a crossover to get back to single exhaust, tho' you'd have to have that custom made prolly, doubt the original Y pipe could be found
Top
#346647 - Sun Dec 09 2007 11:41 AM Re: Chevy Intake Manifold Casting Number Look Up? [Re: Flxible]
rfs56trk Offline
Loc: Seal Beach, CA
Gregg,
If it has a Q-jet and manifold it has to be 66 up. Also a 58 V-8 light duty truck did not come with a 4 jet or any other 4 bl carb. A 4 bl was offered in a car but trucks had a 2 bl.
As Bill said check the date code, that should narrow it down, also the Q-jet will have a number which will identify the year and application.
Fred
Top
#346861 - Sun Dec 09 2007 10:01 PM Re: Chevy Intake Manifold Casting Number Look Up? [Re: rfs56trk]
Apprentice
OK, thanks, guys. I'm going to go to the rams horn exhaust manifolds for sure, if for no other reason than that the current four-pipe header is tight up against the steering gear box; can't even adjust the gear box, and all that heat can't be good for it,either. I'll check the intake manifold for a date, but I know it's not original because, as Fred pointed out, the Q-jets are 66 and up. I rebuilt the Q-jet, and the number look up showed it to be a '73. Hmmm, I'd like to ditch the dual exhaust, but if the Y pipe for the cross-over can't be found may just leave it as is. Sounds good, anyway, with that racing cam.
You guys are a wealth of info. Mucas Grasias.
Gregg
Top
#347047 - Mon Dec 10 2007 12:14 PM Re: Chevy Intake Manifold Casting Number Look Up? [Re: Rusty Bucket]
rfs56trk Offline
Loc: Seal Beach, CA
They had the problems worked out on Q-jets by 73. Should be a good one. The application is likely to be for a 350 engine.
Fred
Top
Moderator:  53moneypit, Woogeroo
