The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
36 registered (1953 panel, 40_chevy, 2ton46, '54 3600, 2-Ton, 3B, 2 invisible), 570 Guests and 4 Spiders online.
Forum Stats
39,407 Registered Members
48 Forums
105,407 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
19chevy38, BF Finster, BigBambino22, crcmk7w, dmtexas, jay smith, Jim Williams 7w, Kevin W. Johnson, Noe_swede, pablos49
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#343041 - Thu Nov 29 2007 07:23 PM How to remove dash from 1951 Chevy 3100?
ChevyTruckKy Offline
Loc: KY
Hi all... well it's been one of those days. Just getting into the teardown of my 51 Chevy 3100 and we've discovered some major structural issues with the cab related to the floorboard, door frames, and firewall that make me think that all we can do at this point is part it out. I have another 1951 Chevy 3100 5-window cab that I believe is in better shape. So.. now that I have your sympathy... laugh.. laugh... I'd like to know if anyone has advice on the best way to remove the dashboard. I can see two bolts on each end of underside of dash but the rest appears to be welded in place. I'd like to remove dash as it and the gauges are all viable. Thanks in advance!!!
Top
#343044 - Thu Nov 29 2007 07:33 PM Re: How to remove dash from 1951 Chevy 3100? [Re: ChevyTruckKy]
delux54panel Offline
Loc: MARTINEZ,CA.
"SAWZALL"
_________________________
Marty
'54 Panel and '54 5 Window Pick up, in the Gallery
'52 Suburban
Top
#343097 - Thu Nov 29 2007 09:42 PM Re: How to remove dash from 1951 Chevy 3100? [Re: delux54panel]
OLTrucks Offline
Loc: Kansas City Mo. 64133
Acme little Giant Dash remover jell..............
Humm ok it is spot welded all around the windshield opening and has a couple of bkts. so pick your best way to remove spot welds.
Mike
Mike
re�store
Pronunciation: ri-'stOr,
Etymology: Middle Eng, from Latin restaurare to renew,rebuild
1 :GIVE BACK,RETURN
2 :to bring back to or put back into a former or original state:RENEW
Now is that what you did with a V8 and air bags ?
1951 Chevrolet Suburban
Oltrucks website
Top
#343103 - Thu Nov 29 2007 09:50 PM Re: How to remove dash from 1951 Chevy 3100? [Re: OLTrucks]
Loc: KY
Man.. you guys are tough on the new guy... i appreciate the humor and it sounds like there's not much to removing it! Thanks!
Top
#343116 - Thu Nov 29 2007 10:20 PM Re: How to remove dash from 1951 Chevy 3100? [Re: ChevyTruckKy]
ZooKeeper
Unregistered
not a fun job....
You could remove like it like delux54panel said but you need to cut it at the cowl to get the lip for the dash also. You still have to either use a cut off wheel or try to drill the spot welds out on the sides of the dash near the doors.
Like OLTrucks said you could drill all the spot welds out to remove it. But you still have to either use a cut off wheel or try to drill the spot welds out on the sides of the dash near the doors.
I did it the stone age way since I had no electric or air & was in the middle of whaet field in northern Kansas. I used a hammer & couple of very sharp chisels. Not pretty but it worked...Joe
Top
#343208 - Fri Nov 30 2007 09:15 AM Re: How to remove dash from 1951 Chevy 3100? [Re: ]
Brad Allen Offline
Loc: Salt Lake City, Utah
I don't know if you have access to the factory assembly manual but it has really good detail on the locations of brackets and number of spotwelds. I agree that cut-off wheel or spot weld cutter would be the way to go. If the existing cab is junk cut it out of the cab with a torch and then seperate it carefully at the original attachment points on a work table. I don't have a scanner but if you send me your address I could photocopy the pages showing the details.
Top
#343215 - Fri Nov 30 2007 09:57 AM Re: How to remove dash from 1951 Chevy 3100? [Re: Brad Allen]
atomarc Offline
Loc: Eureka, CA
ChevyTruckKy,
Generally speaking, the dash isn't removable. I guess I missed the gist in the posts that made it seem like no big deal.
To expound on my statement. You can remove dash #1 by chopping it up and taking it out in sections. Your donor dash #2 is left in the donor cab, and the cab is removed from the dash, so to say!
You now end up with a semi-intact dash to install in your dash-less cab!
I have done this procedure, and that is how I accomplished it. Because of the amount of spotwelds, and the tight quarters in the pillar and windshield area, something must be sacrificed in this procedure. You cannot come out of this task with a perfect dash and a perfect cab.
Stuart
Top
#343348 - Fri Nov 30 2007 02:59 PM Re: How to remove dash from 1951 Chevy 3100? [Re: atomarc]
OLTrucks Offline
Originally Posted By atomarc
ChevyTruckKy,
Stuart
Boy Howdy thats it right there
Mike
Mike
re�store
1 :GIVE BACK,RETURN
Oltrucks website
Top
#343438 - Fri Nov 30 2007 06:07 PM Re: How to remove dash from 1951 Chevy 3100? [Re: ChevyTruckKy]
Czechman Offline
Loc: Raleigh, NC
OH NO! I was really looking forward to seeing your progress on that one. I was wondering how bad it really was. By looking at the pictures in the Gallery she didn't look very encouraging. Sorry to hear it.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Top
#347704 - Tue Dec 11 2007 10:44 PM Re: How to remove dash from 1951 Chevy 3100? [Re: Czechman]
BIG CHEVY 3600 Offline
Loc: DALLAS/BLANCO TEXAS
I would avoid using the cutting torch. Talk about ugly results...
Jim
Big Chevy's Photobucket pix
FIRST START http://www.youtube.com/watch?v=Fb-4nPArk98
Modern ‘science’: the wonder of a
pre-determined mind…
The ‘baseline belief’ of astronomy:
“Any day now, we’ll pick up a tiny,
coded signal from outer space. Then
we’ll know for certain that there is
intelligence out there, because coded
information does not arise by chance”
The ‘baseline belief’ of biology:
The precisely coded genetic information in
every cell would fill many books…
but we know for certain that no intelligence
could have created life.”
Top
Page 1 of 2 1 2 >
Moderator:  Rusty46
