The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
63 registered (49 3100, 1953 panel, 51cowboy, 2-Ton, 3B, 42465967, 2 invisible), 575 Guests and 4 Spiders online.
Forum Stats
39,395 Registered Members
48 Forums
105,329 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
48silverado, Anthony M, Big Tike, brown12202, CRexRun, Jim Meier, jkully, kruisin53, paul 49, shaxinator, Steven T, ultimatezlover
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#33869 - Mon Jan 26 2004 05:45 PM 235 Hydraulic lifters
Rickcapt Offline
Junior Member
Loc: Merritt Island, Florida
I am interested in changing the cam and liters in my 1957 235. It now has solid lifters and I can't get it to run quietly with the valve adjustment set to spec. Does anyone out there know if there is any problem with going to hydraulic lifters?
_________________________
1951 Chevy 3600, 1996 Yukon, 2000 Road King
It is easy to take liberty for granted, when you have never had it taken from you.
http://www.stovebolt.com/gallery.htm
Top
#33870 - Mon Jan 26 2004 07:20 PM Re: 235 Hydraulic lifters
Rickcapt Offline
Junior Member
I am a newbe here, after I posted the above question I searched the archives of this site and found a ton of info based on similar questions in the past. I need to check my engine to see if the block is drilled for hydraulic lifters.
Top
#33871 - Mon Jan 26 2004 07:24 PM Re: 235 Hydraulic lifters
chiphead Offline
Loc: Aiken, SC
If your engine block's lifter galley has been drilled by the factory for hyd lifters, you can use them and a hyd cam in your engine. There will be a hole drilled thru the center of all the lifter bosses to feed oil to the hyd lifters, if the block's been drilled. Not all '57 motors were drilled, so remove a lifter and inspect the block before you buy a hyd setup.
One word of caution- There have been reports by bolters here that even the hyd setups in 235s will make noise. Worn valvetrain parts, or the design of the 235 hyd lifter or camshaft lobe profile seem to contribute to the problem. 235s are noisy anyway. If my 235 is making noise and leaking oil, then its still running... grin
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Top
#33872 - Tue Jan 27 2004 04:11 PM Re: 235 Hydraulic lifters
ol' 55 Offline
Loc: Quartz Hill California
I'm still running hydraulic lifters in my 235'6.The truck runs real well in the garage and up and back off one of my back roads.Hopefully this summer I'll have her completely legal to go on some trips. Our Bro. down in Arizona (PATRICK) told me personally that hydraulics are a no no and that they make all kinds of noise.Mind haven't so far? GOOD LUCK. smile
Top
#33873 - Tue Jan 27 2004 04:48 PM Re: 235 Hydraulic lifters
53moneypit Offline
Loc: Smallville IN
RE: "our Bro down in AZ said hydraulic 235's are all noisy" well thats darn funny becau frown se he didn't have a bit of trouble selling me a new cam with hydraulic lifters, never said a word about any noise. Very strange. frown
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Top
#33874 - Tue Jan 27 2004 09:07 PM Re: 235 Hydraulic lifters
cujo8 Offline
Loc: Williamson, NY
Patrick also steered me away from a hydraulic setup for my 261, which was drilled for hydraulic lifters, so I went with the solid lifters and Howard's M4F cam. I am in the process of putting it all together now.
261 Rebuild: http://community.webshots.com/album/109150147dILZZr
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
Top
#33875 - Wed Jan 28 2004 06:47 PM Re: 235 Hydraulic lifters
4ontheFloor Offline
Loc: Forest Grove, OR
If your valve train is really noisy after your lifters are adjusted correctly then chances are you have a worn rocker arm or bent pushrod. All 235/261's are noiser than today's modern engines and noisier than flatheads of the same era but they should be pretty quiet, even with solid lifters. New rocker arms, a smooth rocker shaft, and new or reconditioned push rods and adjuster should make it quiet so it just sounds like 12 sewing machines running in synch and not a box full of hammers dropped down a flight of stairs.
If you want it to still be quieter than replace the valve and side cover with cast aluminum aftermarkets, they absorb the noise a bit better.
My 261 with a good valve adjustment is about the same volume at idle as the six cylinder BMW I have, which has an overhead cam engine with solid tappets.
Expect it to tap a bit when it is cold, it will until everything heats up and the clearances tighten.
Tapping valves are not necessarily bad, they don't cause any additional wear unless they are really loose. Valves that are too tight will blow out the seats in a hurry. If they get too quiet then start to worry.
Paint & Body Shop moderator
Top
#33876 - Wed Jan 28 2004 08:54 PM Re: 235 Hydraulic lifters
ape Offline
Loc: idaho
ol'55, why'd Patrrick's not like hydraulic lifters? just noise or other stuff too? I bought some from him in 98' and just got my truck running(261).Seems ok so far but it isn't close to broken in.
Top
#33877 - Thu Jan 29 2004 06:56 PM Re: 235 Hydraulic lifters
54 5-window 3100 Offline
Loc: Kansas City
I can't help with answers but I do have questions:
My '54 has block 3836233 and head 3836848. From a questionable reference source, that would be '55 or '56 engine parts. The paint on block and head do not match, they are different shades of blue that look like factory paint. The reference material lists the block as 235ci w/P.G. The engine runs well with lots of tapping even after adjustment. Is there any way to determine whether it has hydrualic lifters without taking it apart? I have adjusted the valves per the manual for solids. I know nothing about the history of this engine. I don't want to missadjust and burn valves.
Top
#33878 - Fri Jan 30 2004 09:10 AM Re: 235 Hydraulic lifters
chiphead Offline
Loc: Aiken, SC
The '54 210 and Bel-Air sedan engines with powerglide got hyd lifters. According to my shop manual, the '53 'Glide cars and '54 Stick cars got solids, which I have verified with the 54 solid-lifter motor that was in my Bel-Air.
But since your head has been swapped to a '56-newer "848" head, all bets are off. Easiest way to tell with engine assembled is to remove pushrod cover and look. I could suggest taking a valve past zero-lash and see if the motor misses, or hitting a pushrod with engine off and see if pushrod and lifter "gives" a little, but you might tear something up if done incorrectly
good luck
chip
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
