The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (Drmike, Jose.a909, borpa11, tomctomc, apache3600), 380 Guests and 4 Spiders online.
Forum Stats
39,419 Registered Members
48 Forums
105,447 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
250supersix, 48 Chevrolet 1 Ton Panel, 59lover, Alan de la Garza, Mark Lewis, preacherman
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#329686 - Sun Oct 28 2007 07:11 PM 6 cyl.pullys
hot rod Offline
Loc: Iowa
Does anyone know how to put a power steering pump and air compressor and alt. on a 56 Chevy 6 cyl. engine? Thanks
Top
#329797 - Sun Oct 28 2007 09:58 PM Re: 6 cyl.pullys [Re: hot rod]
Tabasco Offline
Loc: Parker County, Texas
I can help with two out of three. Here is a link... Alan Grove
Top
#329828 - Sun Oct 28 2007 10:35 PM Re: 6 cyl.pullys [Re: Tabasco]
Fla54Chevy3100 Offline
Loc: Central Florida
Adding all three will require that you use a 2 groove harmonic balancer. Some of the early engines had them but they are rare and of course, 50 years old.
On my 235, I bought a modified 250 H/B from Buffalo Enterprises in Washington state....it was pricey, needed to be rebalanced but it gives me the option to run all three. The mounts you can buy from Alan Grove and Old air (as well as others) are set up for stock exhaust manifolds and require some modification if you're running Fentons. I've got some pics in my "Webshots" albums of the install....I run the pass. side alternator belt(1) over the waterpump on the inside groove and the a/c compressor directly off the front groove. My Saginaw p/s pump will run off the front groove of the 2 groove A/C compressor when I get around to adding it. Be advised that you'll be hard pressed to buy all the brackets to bolt on without some fabrication.
Dave
_________________________
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Top
#329965 - Mon Oct 29 2007 09:18 AM Re: 6 cyl.pullys [Re: Fla54Chevy3100]
hot rod Offline
Loc: Iowa
Dave, thanks this helps, but you had to have the new 250 H/B rebalanced? How do you that? I just thought you put it on? Help?I also never thought of running the P/S pump off of the second grove of the compressor! Thanks again
Top
#330032 - Mon Oct 29 2007 12:09 PM Re: 6 cyl.pullys [Re: hot rod]
Getting the H/B rebalanced was recommended by Steve (of Buffalo Enterprises) so I took it as a "must". The problem I had in finding a shop that could do the balance, was that the center hole was so close to the average performance shop's arbor diameter, that the centering cones wouldn't chuck up. I finally found an old timer in a little performance shop who turned down a couple cones that would center the balancer on his arbor shaft. He took it as a challenge and was more than fair in pricing his work. The end result was down to 3/10ths of a gram and there was noticeable metal removed. Steve wasn't kidding when he said to rebalance!
As for the pulley arrangement...running a single belt over the early waterpump/adaptor plate combo, gives me less stress on the pump bearings and the proper pump speed. The adaptor plate centers the fan in the radiator and overheating, even with the a/c is no longer, part of the equation.
Dave
Top
#330235 - Mon Oct 29 2007 07:21 PM Re: 6 cyl.pullys [Re: Fla54Chevy3100]
hot rod Offline
Loc: Iowa
Dave, so I just take the new 250 H/balancer to a machine shop and have IT balanced, Right? Thanks
Top
#330339 - Mon Oct 29 2007 10:19 PM Re: 6 cyl.pullys [Re: hot rod]
Just to make sure we're on the same page....the 250 balancer from Buffalo is machined to fit the 235 engine and you have to get it rebalanced. He shortens the snout, reduces the diameter of the seal area and provides a felpro "quick sleeve" so you've got a good timing cover seal fit, and cuts in the second 3/8" groove.
You have to scout out a machine shop that can balance it. If you can't get it rebalanced you'll wind up with a $200. paper weight.
I'd get a confirmation from a machine shop that they would be able to balance it before I ordered it from Buffalo.
Dave
Top
#330358 - Mon Oct 29 2007 10:42 PM Re: 6 cyl.pullys [Re: Fla54Chevy3100]
bigmacdaddy Offline
Loc: Seattle
I also bought the 2 groove pulley from Buffalo. I'm building a 261 and had it balanced w/ the crank, flywheel, and gear as an assembly. Easy to do (or have done) when the engine hasn't been assembled.
My Webshot Photos
62 Fleetside 4spd 235 w/O.D. posi 3:90
90 Subaru Legacy Wagon AWD 2.2 5sp
13 Ram Tradesman C/V
http://www.stovebolt.com/gallery/madia_matt_1962.html
Top
#330515 - Tue Oct 30 2007 09:04 AM Re: 6 cyl.pullys [Re: bigmacdaddy]
hot rod Offline
Loc: Iowa
AHH, now I get it. OK , I'll check with my guys first about it.My engine has been rebuilt and I want to use it in this 42 1/2 ton,so I have to find a way. I also tried to find Buffalo on the net and it said the site wasn't ready yet? If I call them do they have a catalog? Thanks again for all the info. Larry
Top
#330683 - Tue Oct 30 2007 03:42 PM Re: 6 cyl.pullys [Re: hot rod]
Buffalo (Steve) Enterprises has a web page but the only way you can reach him is by calling him at his shop (360) 652-7684. You will probably get his answering machine....he's (by preference) without computer or cell phone, working his magic on a fairly broad spectrum of specialty parts for Inliners. However, he is great about returning calls.
You might ask him about balancing....he had a local guy who did balancing but metioned he was either dead or out of business. If there was any way of getting it balanced up at his end it would be worth the effort. As BigMacdaddy pointed out, the best way would be with the complete assembly....your local performance shops may run into the same "chucking up" problems I had when just doing the stand-alone balancer.
Dave
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
