The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
30 registered (53 green 1- ton, BC52, Chilidogg, Bills Auto Works, Cosmo, DinoKruzOrdinanc, 2 invisible), 443 Guests and 4 Spiders online.
Forum Stats
39,277 Registered Members
48 Forums
104,811 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
Jimmymack68, kc0kfg, Nic-Rebel450CA, tommy65gmc
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#245980 - Sun Sep 17 2006 06:57 AM "C" Knob and Locking Hubs
Bill Cain Offline
Loc: Buffalo, WY
3 months ago I had the good fortune to buy a '64 Chevy Suburban K10. Everything works. Good paint, 350 with holly 4 barrel. This truck is very solid. Some rust on the floor,engine compartment and frame. Bumpers and grille need paint, but other than that the truck doesn't need any work. Even the tires and wheels are good. I'll post some photos when I get the bumpers and grille painted. I have a couple of questions. 1. There is a small black knob to the left of and just below instrument panel, has "C" on it. What is it for? 2. I need a source where I can find new locking hubs. PS. This truck is NOT FOR SALE!
_________________________
1964 Chevrolet K-10 Suburban
Top
#245981 - Mon Sep 18 2006 12:22 AM Re: "C" Knob and Locking Hubs
64K10 Offline
Apprentice
Loc: Pleasanton, California
'64 - For the 6 lug, 1/2 Dana 44 closed knuckle hubs check out Mile Marker.
As for the "C" knob... is it mechanical or electrical?
What front axle and transfer case is in the Burb?
Should be a Dana 44 - 5F and a Rockwell T-221 if it's stock.
64K10
Top
#245982 - Mon Sep 18 2006 06:11 AM Re: "C" Knob and Locking Hubs
Bill Cain Offline
Loc: Buffalo, WY
64K10- What I know about vehicles wouldn't fill a sheet from a sticky pad. The "C" knob is mechnical. Does cowl mean anything? Also, I have no idea what
the front differential is or the transfer case, but I think it's original. At present, I don't have a lot of time to spend on the truck, as I am working about 70 hours a week, with Sunday my only day off. Right now the Burb sits in the garage. My daily driver is a '72 Landcruiser.
Top
#245983 - Mon Sep 18 2006 07:28 AM Re: "C" Knob and Locking Hubs
Roy Rodgers Offline
Loc: Ranger, Texas
The "C" knob used to be for a choke that was operated manually. Should be next to the headlight switch. There is a good chance it is no longer hooked up since that truck now has a 350 in it.
Top
#245984 - Tue Sep 19 2006 12:02 AM Re: "C" Knob and Locking Hubs
64K10 Offline
Apprentice
Sounds like the knob/cable may have been replaced.
No "C" on the '64 knob, not sure about the '60 - '63 ones. Knobs L to R - Headlights, Wiper, Choke (Steering Wheel) Ign switch, Lighter
As a side note, from the paperwork I found in my truck, looks like it lived in Cody, then went to DuBois, then out here to Kalifornia in the late '60s. Last time I was in Buffalo was in 2000 on my way to Sturgis.
64K10
Top
#245985 - Tue Sep 19 2006 06:21 AM Re: "C" Knob and Locking Hubs
Bill Cain Offline
Loc: Buffalo, WY
The "C" knob. From steering column going left. Choke, wiper then light switch. From the light switch, go left 3 and one half inches, then down two inches. There is the location of the "C" knob. It's on the dash, but not on the instrument panel. And from all apperances, it is original equipmemt. Also, I checked with Mile Marker, they do not list a locking hub for a '64 Burb. LMC has a hub listed that works for a 60-66 K10, but when I phoned them, they could not tell me if it would work on a Burb. They suggested I ask a local mechanic. Right! A mechanic in Buffalo, Wyoming is going to know if a hub that works on a '64 pickup will work on a '64 Burb. What with so many '64 pickups and Burbs running around Buffalo, Wyoming. I think not. I have e-mailed everyone at Stovebolt with a photo of a Burb and had no response. Someone out there has to know where I can find hubs.
Top
#245986 - Tue Sep 19 2006 09:42 PM Re: "C" Knob and Locking Hubs
LONGBOX55 Offline
Loc: DANVILLE IL
You might try Warn for hubs, they did make them for 4x4s back then, should still be availible as the diff should be a Spicer 44.
Bill Burmeister
Top
#245987 - Tue Sep 19 2006 10:09 PM Re: "C" Knob and Locking Hubs
LONGBOX55 Offline
Loc: DANVILLE IL
I have to correct myself, Warn does not list anything before '69 for 1/2 ton. Mile marker does list one, the Selectro Classic part # 11001-01, and Summit lists a Milemarker part # MMK-103 as fitting as well for '60-'68. They list for $66.39 for a pair.
Bill Burmeister
Top
#245988 - Wed Sep 20 2006 07:04 AM Re: "C" Knob and Locking Hubs
Bill Cain Offline
Loc: Buffalo, WY
LONGBOX55, Bill,
Mile Marker lists the 11001-01 for '60-68 pickups. How can I determine if these hubs will work on my Burb?
Top
#245989 - Wed Sep 20 2006 04:44 PM Re: "C" Knob and Locking Hubs
64K10 Offline
Apprentice
'64,
First you need to identify that you have the original Dana 44 axle. Look at the front diff cover and to the lower right on the housing you will find some casting numbers "44 - 5F". This is for the 1/2T - 6 lug, closed knuckle axle. This casting number is also on the driveshaft side of the housing. You'll probably have to clean the diff housing with a wire brush to read the numbers.
If your truck has 8 lugs and is really a K10 (and not a K20) someone has put 3/4T axles under it.
Is your transfercase in the center of the truck or attached to the tranny? Stock tranny is the SM420, with reverse to the left and down.
Post some pics of the truck, axle, and the "c" knob...
64K10
Top
Page 1 of 2 1 2 >
Moderator:  tclederman, Tony'N Weatherford
