The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (TPR57C, tomctomc, Mickey3100, Organbuilder, greenie-reddy), 523 Guests and 4 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
Page 1 of 5 1 2 3 4 5 >
New Reply
Topic Options
#215167 - Tue Sep 05 2006 11:27 AM My PB Blaster vs. Kroil test
Builder Offline
Loc: Minnehaha County, South Dakota
Friday I brought home a 1957 Corvette engine. When I took it apart, the right bank of pistons were all stuck. One of the worst ones had a pile of white and yellow crystalized corrosion filling the cylinder. It reminded me of a severely corroded battery terminal. I decided to test the PB Blaster and Kroil on the motor to find out which one actually worked the best.
For the sake of clarity I will number the cylinders 1-2-3-4.
The two outside cylinders (1 and 4) had the most corrosion, and I assumed they would be the toughest pistons to remove. The two center cylinders were stuck and not quite as bad.
Cylinders 1 and 4 seemed to be the worse of the four, and I decided that since the Kroil was the most expensive I would give it the task of the worse cylinder (#1). I also chose to use kroil in the number 2 cylinder. PB Blaster was used in 3 and 4, with 4 being the worse of those two.
First I took a 2" wire wheel on my die grinder and removed as much rust and corrosion from the tops of the pistons and I cleaned the tops of the cylinders too. I then propped the block so the right bank of pistons were level.
I then sprayed Kroil into cylinders 1 and 2 until the top of the piston was covered, then the same to 3 and 4 with the PB Blaster. I noticed the PB Blaster was bubbling a little around the edges of the piston. It reminded me of carbonated beverage when you pour it in a glass. I let them both sit for about 18 hours. All the cylinders looked like they had the same amounts of penetrant on top of the pistons when I returned.
First I took a wood 2 x 2 and hammered the two center pistons (2 and 3) down into the bore. Both came loose relatively easy. I pounded them from the bottom and they both came out of the cylinders fairly easy and with reletively equal force.
I pounded on the tops of the 1 and 4 pistons to see if they would loosen up. The number 1 cylinder with Kroil started to move so I continued to work on it. I got it far enough down the cylinder to see where the rings has set against the cylinders. I took my wire wheel and cleaned up the cylinder again and then pounded the piston from the bottom and it came out of the cylinder.
I then turned my attention to #4 with the PB Blaster. I pounded and pounded on the top and bottom of the piston and it would not move. I sprayed some more PB Blaster on top of the piston and waited about 15 minutes and pounded again. The piston did not move.
I decided that I had better prop the motor up again and let it soak another day. I was already leaning towards the Kroil as being the better of the two, and I sprayed some Kroil in the #4 cylinder.
After 10 minutes I took the 2 x 2 and hit it with the hammer. The piston moved on the first hit. After moving the piston down far enough, I again cleaned the cylinder with the wire brush. I pounded from the bottom and got the piston out.
Now you could say that all the pounding on the #4 PB Blaster piston helped loosen it up before switching to the Kroil, but I really believe that the Kroil did a better job of penetrating and loosening up the pistons. I also looked at the cylinders afterwards too. The PB blaster cylinder showed deeper scores in the cylinder walls from the hard deposits left behind.
I also noticed the lubrication of the kroil was much higher. The PB Blaster seemed dryer and less oil like.
My test finds Kroil superior to PB Blaster.
_________________________
Supporting Stovebolt Servicemembers
Read all about the IRWIPI - Triple Dog Dare!
Top
#215168 - Tue Sep 05 2006 12:22 PM Re: My PB Blaster vs. Kroil test
dad6timz Offline
Loc: simpsonville sc
I always thought PB was the best but I will now try Kroil. I'm always willing to try new stuff.
The crew that works on the \'42 --Sara, Hannah and Abby
Top
#215169 - Tue Sep 05 2006 12:55 PM Re: My PB Blaster vs. Kroil test
cletis Offline
Loc: Parker County Texas
Thanks for the report. Very thorough and easy to comprehend.
1954 GMC Suburban
My TRUCKS website
Top
#215170 - Tue Sep 05 2006 04:56 PM Re: My PB Blaster vs. Kroil test
49 geezer Offline
Loc: Hedgesville, WV
Started using Kroil after my F in Law recommended it. They used it at the Celanese plant in western Maryland all the time. Never been happier with a product.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Top
#215171 - Tue Sep 05 2006 10:05 PM Re: My PB Blaster vs. Kroil test
Packrat Offline
Loc: Upper Michigan
Where can a guy buy Kroil? I have s stuck 350 in my 48 coupe. I have kept the cylinders full of PB for the last 3 or 4 weeks and tried to turn the engine with a bar on the flywheel but no luck. I was trying to get away without pulling the heads. It looks like I might have to pull it apart and use the wooden block. I have tried to find Kroil but no luck. Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
Top
#215172 - Tue Sep 05 2006 10:06 PM Re: My PB Blaster vs. Kroil test
Packrat Offline
Loc: Upper Michigan
Top
#215173 - Wed Sep 06 2006 01:23 AM Re: My PB Blaster vs. Kroil test
J Lucas Offline
Loc: South Omaha, Nebraska
I have been impressed with PB Blaster, looks like I will have to check out Kroil.
Thanks for the tip.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos!
Top
#215174 - Wed Sep 06 2006 01:55 AM Re: My PB Blaster vs. Kroil test
Inky05 Offline
Loc: N.E. Pennsylvania
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
Top
#215175 - Wed Sep 06 2006 08:43 AM Re: My PB Blaster vs. Kroil test
Achipmunk Offline
Loc: Boiling Springs, S. C. 29316
packrat, most industrial supplies carry it and "some" parts houses. I use to get it in a can like WD-40 but now I can only find it in a larger can and use my own squirt bottle. Its the best stuff around. The plant I worked at for many many years tried it all.....and ended up using Kroil to. I have a quart of it!!
Pictures in my Photobucket
Top
#215176 - Wed Sep 06 2006 10:02 AM Re: My PB Blaster vs. Kroil test
Billybolt Offline
Loc: Bay Area, CA
sea foam
Test this stuff out. Its expensive but good. It even sprays upside down.
Sea foam, Deep Creep
Top
Moderator:  cletis
