The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (Gabes-trucks, Cosmo, 1 invisible), 408 Guests and 4 Spiders online.
Forum Stats
39,284 Registered Members
48 Forums
104,820 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
35pickup, 68haywagon, Bubbles, buxman66, Franklin C. Cooley, Larry Shaddy, LimeyC10, mark8544, mike boyle, Pee-Wee, peter 60 stepsid
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#149275 - Sun Nov 26 2006 06:43 AM Removing Dump Body
Pete/ME Offline
Loc: Whitefield, Maine
I'm about to take the dump body off my '48 2t. Have to do it single handed, so I'm going to wedge the raise lever back and hoist the body with my tractor's loader and bock it up so I can get at the ram, hoses and subframe. Lower the body, jack up everything on 6X6's crosswise and set it on oil drums and pull the truck out from underneath. Sound reasonable?
Top
#149276 - Sun Nov 26 2006 11:46 AM Re: Removing Dump Body
53moneypit Offline
Loc: Smallville IN
You should not have to raise the body to remove it. Hoses needn't be removed from the cylinder, only at the pump if it is remote from the cylinder. If it is manifold mounted to the cylinder then you need only remove the driveshaft from the PTO, disconnect the subframe attachment plates & bolts to the frame and lift it off as a unit.
I have more years of experience with this sort of thing than I care to remember and it isn't difficult, just be careful and have the proper equipment. Don't take any chances with this kind of weight as it is very unforgiving.
_________________________
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Top
#149277 - Sun Nov 26 2006 06:33 PM Re: Removing Dump Body
48bigtrucks Offline
Loc: Center Point, Iowa
I would remove the bed first, then the lift equipment,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Top
#149278 - Mon Nov 27 2006 05:39 AM Re: Removing Dump Body
Pete/ME Offline
53moneypit, sure enough, (my last truck project was a '64) crawled under and it's just as you said. Pump and ram stay with the subframe. Now comes the fun part. Guess I'll pull it back to the balance point, let it slide down 'til it hits the ground, build some ricking under the front, and then pull the truck forward. Lift up the back end on some more ricking. Thanks.
Top
#149279 - Mon Nov 27 2006 05:42 PM Re: Removing Dump Body
rickdb1 Offline
Junior Member
Loc: Lake City, Colorado
Whatever you do, think about it twice before you make your next move. Alot of weight to be slinging around....
Rick
1952 Chevy 2-Ton with Dump Bed
Top
#149280 - Mon Nov 27 2006 10:42 PM Re: Removing Dump Body
OldSub Offline
Loc: Seattle, Washington
If you really have to do it alone can you at least find a spotter to watch and dial 911 if something goes wrong?
Or get someone here waiting to get news that you've finished successfully, and equiped with a local emergency number? Take your cell phone underneath too.
I've heard of a few too many serious injuries with this kind of project and we sure don't want you to be the next!
Its true, I really don't do anything but browse the Internet looking for trouble...
Steve@OldSub.com . www.OldSub.com . www.MaxwellGarage.com . www.OldGasTowRigs.com
'55 1st GMC Suburban . '54 GMC 250 trailer puller project. '54 GMC 250 Hydra-Matic . '54 Chevy 3100 . '47 Chevy COE . and more...
Top
#149281 - Tue Nov 28 2006 06:12 AM Re: Removing Dump Body
Pete/ME Offline
Thanks guys. I do tend to be a little impulsive. The latest plan is to detach subframe, build serious ricking (I used to jack up houses to replace sills) on both sides of the truck, SLOWLY RAISE the frame and body up until I can slide 6 X 6's under everything, and then pull the truck out. That way, if it goes south, I'm no where near the thing...safety first, right?
Top
#149282 - Tue Nov 28 2006 10:56 AM Re: Removing Dump Body
Burgie Offline
Loc: Colorado Springs
When it came time to remove the dump body from my 1964 Chevy C60 I ended up renting a heavy duty fork lift from our local rental place here in town. The fork lift had a 10-ton capacity and 9 foot long forks. It was $150 for 4 hours, but it was the safest (and easiest) way to remove the bed from my truck. (That's another problem about being 2000 miles from home. If I were home I would have used my brothers Cat 235 excavator to lift it off...free of charge too grin grin )
I lifted the whole assembly off at once...bed, rails, hydraulic assembly...everything. After all the bolts were removed...I came in from the back of the truck, spread the forks and then drove in. There was sufficient space between the bed and rear tires to allow the forks to slide right in. Having the fork lift allowed me the opportunity to place the bed exactly where I wanted it too!!!
That's the problem with owning a Big Bolt...every time you need to do something it's always much harder or more costly...but I value my safety...so I paid the money and did it the right way smile smile smile . I can save money in other areas of the restoration...
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
Burgie's 1964 Chevy C60 Restoration Site
Top
#149283 - Tue Nov 28 2006 02:11 PM Re: Removing Dump Body
OldSub Offline
Quote:
There is a rental place about a quarter mile from me. I hadn't thought of renting a fork lift! Thanks for that idea.
Top
#149284 - Tue Nov 28 2006 02:42 PM Re: Removing Dump Body
HevyHauler Offline
Loc: Washington State
I have friends with selfloader log trucks. For prodjects like that it's worth $100.00 and a case of beer. And I always help them drink the beer. :p
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Top
Page 1 of 2 1 2 >
Moderator:  69Cuda, Grigg
