The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
60 registered (49nut, 5 Window 9434, 3B, 48bigtrucks, 1953 panel, 3 invisible), 685 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,693 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#130934 - Wed Apr 23 2003 08:32 AM Water temp sensor/small block?
Russntustin Offline
Loc: Southern Calif.
Can someone please tell me where a water temp sensor (mechanical or electric) goes on a chevy small block?? (older one)
Thanks alot... :confused:
Top
#130935 - Wed Apr 23 2003 09:53 AM Re: Water temp sensor/small block?
popcorn3023 Offline
Loc: Wabash, In.
Russntustin: 350 driver side right above front 2 sparkplugs. popcorn The Truth is Out There (Yes it is)
Top
#130936 - Wed Apr 23 2003 07:53 PM Re: Water temp sensor/small block?
Russntustin Offline
I feel like such an idiot with this....
The small block is a 327. I don't see anywhere above the front spark plugs...
There's a large 'plug' on top of the water pump...??
Top
#130937 - Wed Apr 23 2003 09:47 PM Re: Water temp sensor/small block?
Seon Offline
Loc: Lake Camanche, CA
Temp sender on a 327 is on top of the intake manifold, passenger side beside or in front of the radiator hose.
Top
#130938 - Wed Apr 23 2003 10:31 PM Re: Water temp sensor/small block?
gmc248 Offline
Loc: Shingle Springs, CA. USA
On the driver's side Cyl. head, there will be a plug (not a spark plug) in between the two front cylinders. If you have headers, it will be below the mounting plate; there might even be a cut-out for it. This is a good a place as any for temp sender.
_________________________
*** GMC ***
Top
#130939 - Wed Apr 23 2003 10:36 PM Re: Water temp sensor/small block?
squeeze Offline
Loc: Vancouver Island
some early small blocks had the temp sender in the water "goose neck" where the top rad hose attaches - not sure which
Top
#130940 - Sat Apr 26 2003 09:43 AM Re: Water temp sensor/small block?
Russntustin Offline
WOW! It's none of those places! The only place I see is a small (3/8") square plug on the intake just below the heater hose inlet...
Jeezlahweez...I didn't know they would change-up the location of this so many times...I'll go searching around.
Thank you guys.
Top
#130941 - Sat Apr 26 2003 10:51 AM Re: Water temp sensor/small block?
gmc248 Offline
Russntustin, what cylinder heads do you have? Do they have a "staggered" bolt pattern on the valve covers? If so, they are 265 heads; which don't have water jacketing around the spark plugs. They may/may not have the plug above/between the front two cylinders.
There should also be ports for your sender on either side of the thermostat housing, since this is the only coolant connection between the two banks of cylinders.
*** GMC ***
Top
#130942 - Sat Apr 26 2003 10:27 PM Re: Water temp sensor/small block?
squeeze Offline
Russ - looked at 5 of my 283's today - they all had the sender here - is that where ya mean you've got a plug? use it!!
Top
#130943 - Sun Apr 27 2003 10:01 AM Re: Water temp sensor/small block?
Russntustin Offline
I want to thank you guys...
GMC: No the valve cover bolts are not staggered,they are inline with each other.
Squeeze...thanks for the picture...This engine doesnt have that "place" for the sender.
I wish I knew more about the engine..the engine was put in by someone I'm not able to talk with.
The intake is a stock looking cast iron part.
So the area for the sending unit SHOULD BE on the INTAKE somewhere? I'll try and post a few pictures today.
THANKS ALOT FOR THE HELP!
Top
#130944 - Sun Apr 27 2003 10:43 AM Re: Water temp sensor/small block?
Russntustin Offline
Hey I posted a few pictures of the engine HERE . I don't know how to post individual pictures. (and boy does the engine look bad with flash!!)
Top
#130945 - Sun Apr 27 2003 12:23 PM Re: Water temp sensor/small block?
Tommy Offline
Loc: Metairie,La.
Russ, the sender was in the first runner on the manifold, that is the water passage on a small block, was also on the heads on later models, check the head on other side in between rear two cyl. the therm. housing also, you can probably get one of those housings from napa, or you could put the heater hose on the pump outlet and use the other one for the sender.
Tommy
Tommy
59 apache 1/2t
261 short stepside
Top
#130946 - Sun Apr 27 2003 07:18 PM Re: Water temp sensor/small block?
squeeze Offline
what Tommy said - just switch the heater hose around - that's a 4barrel intake? a 327 w/ 4 barrel manifold is where I've seen the temp sender in the thermostst housing, but that's also why that plug is on the pump.
Top
#130947 - Mon Apr 28 2003 08:25 AM Re: Water temp sensor/small block?
Russntustin Offline
So...I can put the heater hose where that plug is on top of the pump...and the sending unit where the hose is now..AHA!
Yes it is a four barrel manifold.
There's nothing on either head...
Would the sending unit work on top of the pump??
Is this a common water pump with that plug on top?? (I don't remember seeing that on others)
THANKS!!! grin grin
Top
#130948 - Mon Apr 28 2003 09:02 AM Re: Water temp sensor/small block?
squeeze Offline
Russ - don't think I've ever gotten a pump for a 283 that didn't have that plug, but if the sender is hangin in there it might interfere w/ the impeller or w/ water flow - also that'd put the sender on the incoming water, needs to be on the outgoing . . . .
a buck will get ya a street el from the plumbing store, which will put that location close enuff to the current one so heater hose fits ok, and the sender is same pipe thread as the rest - don't worry about the details, just do it!! grin
Top
#130949 - Tue Apr 29 2003 08:03 AM Re: Water temp sensor/small block?
Russntustin Offline
THANKS for the instruction. I am switching things around now.
Gotta go out and find a decent temp gauge now...
Thank you all for the help!
Top
Page 1 of 2 1 2 >
Moderator:  KCMongo
